path: root/board/vpac270
2014-08-30arm: Add missing .vectors section to linker scriptsBenoît Thébaudeau
Commit 41623c9 'arm: move exception handling out of start.S files' missed some linker scripts. Hence, some boards no longer had exception handling linked since this commit. Restore the original behavior by adding the .vectors section to these linker scripts. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau.dev@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-02-26arm: make _end compiler-generatedAlbert ARIBAUD
This prevents references to _end from generating absolute relocation records. This change is binary invariant for ARM targets. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2014-01-13ARM: pxa: Fix OneNAND SPL buildsMarek Vasut
The OneNAND SPL used on PXA is slightly obscure. Due to the OneNAND limitation, where we have only the first 1KiB of the OneNAND available upon power-up as a memory-mapped area, from which the CPU starts executing, we place only the most essential code into this first 1KiB . This code copies the rest of the SPL into SRAM and jumps to it. This code is stored in section .text.0 . The rest of the SPL is stored in section .text.1 . When running the OBJCOPY on the SPL, it will preserve only .text section, but the .text.0 and .text.1 are stripped away from the result, thus making the SPL binary empty. The patch adds additional -j parameters to the OBJCOPY for PXA during the SPL build, which will preserve the .text.0 and .text.1 sections. Moreover, this patch also adds missing functions into the .text.0 section, since otherwise the PXA270 with 1KiB-window OneNAND won't be able to boot. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Albert Aribaud <albert.u.boot@aribaud.net> Cc: Tom Rini <trini@ti.com>
2013-12-10Merge branch 'u-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/armv7/rmobile/Makefile doc/README.scrapyard Needed manual fix: arch/arm/cpu/armv7/omap-common/Makefile board/compulab/cm_t335/u-boot.lds
2013-12-07arm: keep all sections in ELF fileAlbert ARIBAUD
Current LDS files /DISCARD/ a lot of sections when linking ELF files, causing diagnostic tools such as readelf or objdump to produce partial output. Keep all section at link stage, filter only at objcopy time so that .bin remains minimal. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-11-17Makefile: rename all libraries to built-in.oMasahiro Yamada
2013-10-20usb: rename board_usb_init_type to usb_init_typeTroy Kisky
This will be used by usb_lowlevel_init so it will no longer be used by only board specific functions. Move definition of enum usb_init_type higher in file so that it will be available for usb_low_level_init. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-06-21remove all references to .dynsymAlbert ARIBAUD
Discard all .dynsym sections from linker scripts Remove all __dynsym_start definitions from linker scripts Remove all __dynsym_start references from the codebase Note: this touches include/asm-generic/sections.h, which is not ARM-specific, but actual uses of __dynsym_start are only in ARM, so this patch can safely go through the ARM repository. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Tested-by: Lubomir Popov <lpopov@mm-sol.com> Tested-by: Jeroen Hofstee <jeroen@myspectrum.nl> Reviewed-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: Make all linker scripts compatible with per-symbol sectionsBenoît Thébaudeau
Let all ARM linker scripts handle properly -ffunction-sections and -fdata-sections. This will be useful for future changes in order to create symbol-specific sections in common .S files. Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-04-12arm: relocate_code(): Use __image_copy_end for end of relocationBenoît Thébaudeau
Use __image_copy_end instead of __bss_start for the end of the image to relocate. This is the same as commit 033ca72, but applied to all ARM start.S. This is a more appropriate symbol naming for an image copy & relocate feature, and this also saves a useless copy of data put between __image_copy_end and __bss_start in linker scripts (e.g. relocation information, or MMU initialization tables used only before jumping to the relocated image). Signed-off-by: Benoît Thébaudeau <benoit.thebaudeau@advansee.com>
2013-03-18Merge branch 'master' of git://git.denx.de/u-boot-armTom Rini
Albert's rework of the linker scripts conflicted with Simon's making everyone use __bss_end. We also had a minor conflict over README.scrapyard being added to in mainline and enhanced in u-boot-arm/master with proper formatting. Conflicts: arch/arm/cpu/ixp/u-boot.lds arch/arm/cpu/u-boot.lds arch/arm/lib/Makefile board/actux1/u-boot.lds board/actux2/u-boot.lds board/actux3/u-boot.lds board/dvlhost/u-boot.lds board/freescale/mx31ads/u-boot.lds doc/README.scrapyard include/configs/tegra-common.h Build tested for all of ARM and run-time tested on am335x_evm. Signed-off-by: Tom Rini <trini@ti.com>
2013-03-15Replace __bss_end__ with __bss_endSimon Glass
Note this is a tree-wide change affecting multiple architectures. At present we use __bss_start, but mostly __bss_end__. This seems inconsistent and in a number of places __bss_end is used instead. Change to use __bss_end for the BSS end symbol throughout U-Boot. This makes it possible to use the asm-generic/sections.h file on all archs. Signed-off-by: Simon Glass <sjg@chromium.org>
2013-03-12Remove linker lists (LGAs) from SPL linker scriptsAlbert ARIBAUD
Many SPL linker scripts needlessly include linker lists (aka LGAs). Remove them whenever possible; keep it only in the seven am335x_evm variants (am335x_evm, am335x_evm_uart[1-5], am335x_evm_spiboot), where there is actual content in output section .u_boot_list. This commit keeps all u-boot.bin and u-boot-spl.bin in ARM targets byte-identical. Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
2012-10-22common: Add .u_boot_list into all linker filesMarek Vasut
Add section for the linker-generated lists into all possible linker files, so that everyone can easily use these lists. This is mostly a mechanical adjustment. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Joe Hershberger <joe.hershberger@gmail.com> Cc: Mike Frysinger <vapier@gentoo.org>
2012-10-15serial: pxa: Make use of default_serial_console in serial_pxaMarek Vasut
Make use of the newly implemented weak default_serial_console in the serial_pxa driver. This removes all reimplementations of this function from board files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2012-03-28board/vpac270/onenand.c: Fix build errorsAnatolij Gustschin
Building for vpac270_ond_256 configuration fails: arch/arm/lib/libarm.o: In function `icache_disable': /home/ag/git/u-boot/arch/arm/lib/cache-cp15.c:156: multiple definition of `icache_disable' board/vpac270/libvpac270.o:/home/ag/git/u-boot/board/vpac270/onenand.c:65: first defined here arch/arm/lib/libarm.o: In function `dcache_disable': /home/ag/git/u-boot/arch/arm/lib/cache-cp15.c:188: multiple definition of `dcache_disable' board/vpac270/libvpac270.o:/home/ag/git/u-boot/board/vpac270/onenand.c:66: first defined here make[1]: *** [/home/ag/git/u-boot/spl/u-boot-spl] Error 1 Signed-off-by: Anatolij Gustschin <agust@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2011-12-06PXA: Rename pxa_dram_init to pxa2xx_dram_initMarek Vasut
2011-12-06PXA: Squash extern pxa_dram_init()Marek Vasut
2011-12-06PXA: Adapt Voipac PXA270 to OneNAND SPLMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> V2: Add missing u-boot-spl.lds, convert bitshifts to division, convert to spl_onenand_load_image()
2011-11-15PXA: vpac270: Enable the new generic MMC driverMarek Vasut
2010-10-19Build: PXA: Fix Vpac270 build variantsMarek Vasut
2010-10-19PXA: Fix vpac270 for RelocMarek Vasut
2010-10-19PXA: Add necessary information for RELOCMarek Vasut
2010-10-19PXA: remove unused u-boot.lds from board/vpac270Mikhail Kshevetskiy
This file is not used, automatically generated u-boot.lds is used instead Signed-off-by: Mikhail Kshevetskiy <mikhail.kshevetskiy@gmail.com>
2010-10-19PXA: Voipac270 improvementsMarek Vasut
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-10-19PXA: pxa-regs.h cleanupMarek Vasut
2010-08-09PXA: Fix missing includesMarek Vasut
2010-08-09PXA: Fix off-the-tree build problemsMarek Vasut
2010-07-14PXA: Voipac PXA270 SupportMarek Vasut
This patch adds support for the Voipac PXA270 board. The support includes: - Ethernet - USB - MMC - NOR Booting - OneNAND Booting - LCD - HDD Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com>
