path: root/board/vpac270/Makefile
2011-12-06PXA: Adapt Voipac PXA270 to OneNAND SPLMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Cc: Albert ARIBAUD <albert.u.boot@aribaud.net> V2: Add missing u-boot-spl.lds, convert bitshifts to division, convert to spl_onenand_load_image()
2010-10-19PXA: Fix vpac270 for RelocMarek Vasut
2010-10-19PXA: Voipac270 improvementsMarek Vasut
128MB NOR module support. Define __io to get harddrive working. Fix saving of environment into OneNAND. Boot from harddrive when possible. Add missing MAINTAINERS entry. Signed-off-by: Marek Vasut <marek.vasut@gmail.com>
2010-08-09PXA: Fix off-the-tree build problemsMarek Vasut
2010-07-14PXA: Voipac PXA270 SupportMarek Vasut
This patch adds support for the Voipac PXA270 board. The support includes: - Ethernet - USB - MMC - NOR Booting - OneNAND Booting - LCD - HDD Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Acked-by: Scott Wood <scottwood@freescale.com>
