path: root/board/voiceblue
2011-09-04ARM: remove broken "voiceblue" boardWolfgang Denk
2010-03-07VoiceBlue: fix linker errorsLadislav Michl
linking eeprom with libgeneric.a is not really needed and causes following error: ../../lib_generic/libgeneric.a(string.o): In function `strcmp': /home/ladis/src/u-boot-ti/lib_generic/string.c:152: multiple definition of `strcmp' ../../examples/standalone/libstubs.a(stubs.o):include/_exports.h:24: first defined here make[1]: *** [eeprom.srec] Error 1 Fix undefined reference to memset generated by some versions of gcc to zero out initialized structure on the stack: eeprom.o: In function `eeprom': board/voiceblue/eeprom.c:152: undefined reference to `memset' make[1]: *** [eeprom] Error 1 Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Sandeep Paulraj <s-paulraj@ti.com>
2009-10-04Convert SMC91111 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_SMC91111 to CONFIG_SMC91111 - cleaned up line lengths - modified all boards that override weak function in this driver - modified all eeprom standalone apps to work with new driver - updated blackfin standalone EEPROM app after testing Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-08-21Fix all linker scripts for older binutils versions (pre-2.16)Wolfgang Denk
Commit f62fb99941c6 fixed handling of all rodata sections by using a wildcard combined with calls to ld's builtin functions SORT_BY_ALIGNMENT() and SORT_BY_NAME(). Unfortunately these functions were only introduced with biunutils version 2.16, so the modification broke building with all tool chains using older binutils. This patch makes it work again. This is done by omitting the use of these functions for such old tool chains. This will result in slightly larger target binaries, as the rodata sections are no longer in optimal order alignment-wise which reauls in unused gaps, but the effect was found to be insignificant - especially compared to the fact that you cannot build U-Boot at all in the current state. As ld seems to have no support for conditionals we run the linker script through the C preprocessor which can be easily used to remove the unwanted function calls. Note that the C preprocessor must be run with the "-ansi" (or a "-std=") option to make sure all the system-specific predefined macros outside the reserved namespace are suppressed. Otherise, cpp might for example substitute "powerpc" to "1", thus corrupting for example "OUTPUT_ARCH(powerpc)" etc. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Mike Frysinger <vapier@gentoo.org>
2009-07-22Fix "ld: cannot find -lstubs" build errorWolfgang Denk
Commit 1bc15386 moved the examples/ to examples/standalone but failed to adapt the Makefiles that need to link against libstubs.a Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-12arm: timer and interrupt init reworkJean-Christophe PLAGNIOL-VILLARD
actually the timer init use the interrupt_init as init callback which make the interrupt and timer implementation difficult to follow so now rename it as int timer_init(void) and use interrupt_init for interrupt btw also remane the corresponding file to the functionnality implemented as ixp arch implement two timer - one based on interrupt - so all the timer related code is moved to timer.c Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-02-04ARM: Board voiceblue updateLadislav Michl
2007-11-25drivers/net : move net drivers to drivers/netJean-Christophe PLAGNIOL-VILLARD
2006-10-28[PATCH] Add some missing machtypes for netstar & voiceblue boardsStefan Roese
Use MACH_TYPE_NETSTAR and MACH_TYPE_VOICEBLUE defines instead of numbers in code. Signed-off-by: Ladislav Michl <ladis@linux-mips.org> Signed-off-by: Stefan Roese <sr@denx.de>
2006-05-03VoiceBlue update: use new MTD flash partitioning methods, use moreHeiko Schocher
reasonable TEXT_BASE, update default environment and enable keyed autoboot. Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
2005-10-06Update make target for ARM supported boards.Wolfgang Denk
Use lowlevel_init() instead of platformsetup() [rename]. Patch by Peter Pearse, 06 Oct 2005
2005-08-12Minor code cleanupWolfgang Denk
2005-08-12Add forgotten new fils from latest VoiceBlue updateWolfgang Denk
2005-08-12VoiceBlue update: eeprom tool can also store firmware version now.Wolfgang Denk
eeprom.bin is runable by jumping at load address. Patch by Ladislav Michl, 23 May 2005
2005-08-08Add common (with Linux) MTD partition scheme and "mtdparts" commandWolfgang Denk
Old, obsolete and duplicated code was cleaned up and replace by the new partitioning method. There are two possible approaches now: * define a single, static partition * use mtdparts command line option and dynamic partitioning Default is static partitioning.
2005-04-07Cleanupwdenk
2005-04-05* Patch by Ladislav Michl, 05 Apr 2005:wdenk
Add support for VoiceBlue board. * Patch by Ladislav Michl, 05 Apr 2005: Fix netboot_common() prototypes. * Cleanup.
