Commit 1bc15386 moved the examples/ to examples/standalone but failed
to adapt the Makefiles that need to link against libstubs.a
Cc: Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
Signed-off-by: Ladislav Michl <ladis@linux-mips.org>
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
eeprom.bin is runable by jumping at load address.
Patch by Ladislav Michl, 23 May 2005
Add support for VoiceBlue board.
* Patch by Ladislav Michl, 05 Apr 2005:
Fix netboot_common() prototypes.
* Cleanup.
