Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
Fix Flash support for Versatile.
* Patch by Roger Blofeld, 16 Sep 2004:
Fix timeout for DHCP command retry
- update ARM boards to use constants from mach-types.h
Add initialization for Integrator and versatile board files.
* Patch by Hinko Kocevar, 01 Jun 2004:
Fix VFD FB allocation, add LCD FB allocation on ARM
Added ARM Integrator AP, CP and Versatile PB926EJ-S Reference
Platform support.
* Patch by Masami Komiya, 08 Mar 2004:
Don't overwrite server IP address or boot file name
when the boot server does not return values
* Patch by listmember@orkun.us, 5 Mar 2004:
Removed compile time restriction on CFG_I2C_SPEED for DS1338 RTC
