This board has not been converted to CONFIG_DM_PCI by the deadline.
Remove it.
Acked-by: Heiko Schocher <hs@denx.de>
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
These functions relate to memory init so move them into the init
header.
These functions relate to setting up the device tree for booting the OS.
The fdt_support.h header file supports similar functions, so move these
there.
This function can be dropped when all boards use driver model for PCI. For
now, move it into init.h with a comment.
Except for one counter example, CONFIG_SYS_LBC_LBCR always has a value
of either 0x00040000 or 0x00000000.
CONFIG_SYS_LBC_MRTPR always has the value 0x20000000.
CONFIG_SYS_LBC_LSDMR_{1,2,4,5} are not set for any mpc83xx board.
CONFIG_SYS_LBC_LSRT is set by one board (to 0x32000000).
To simplify the configuration files, hardcode the setting of these
values for mpc83xx.
Signed-off-by: Mario Six <mario.six@gdsys.cc>
CONFIG_SYS_DDR_SDRAM_BASE is set to the same value as
CONFIG_SYS_SDRAM_BASE on all existing boards. Just use
CONFIG_SYS_SDRAM_BASE instead.
CONFIG_SYS_DDR_BASE is specific to mpc83xx an is always set to the same
value as CONFIG_SYS_SDRAM_BASE. Just use CONFIG_SYS_SDRAM_BASE instead.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
Thomas reported U-Boot failed to build host tools if libfdt-devel
package is installed because tools include libfdt headers from
/usr/include/ instead of using internal ones.
This commit moves the header code:
include/libfdt.h -> include/linux/libfdt.h
include/libfdt_env.h -> include/linux/libfdt_env.h
and replaces include directives:
#include <libfdt.h> -> #include <linux/libfdt.h>
#include <libfdt_env.h> -> #include <linux/libfdt_env.h>
Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
This allows us to use the same DRAM init function on all archs. Add a
dummy function for arc, which does not use DRAM init here.
[trini: Dummy function on nios2]
At present we cannot use this function as an init sequence call without a
wrapper, since it returns the RAM size. Adjust it to set the RAM size in
global_data instead, and return 0 on success.
It looks like only cm5200 and tqm8xx use this feature, so we don't really
need it in generic code. Drop it and have the users access gd->board_type
directly.
This function can fail if the device tree runs out of space. Rather than
silently booting with an incomplete device tree, allow the failure to be
detected.
Unfortunately this involves changing a lot of places in the code. I have
not changed behvaiour to return an error where one is not currently
returned, to avoid unexpected breakage.
Eventually it would be nice to allow boards to register functions to be
called to update the device tree. This would avoid all the many functions
to do this. However it's not clear yet if this should be done using driver
model or with a linker list. This work is left for later.
Acked-by: Anatolij Gustschin <agust@denx.de>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
[trini: Fixup common/cmd_io.c]
Rename CONFIG_SYS_DDR_CONFIG to include which CS it is configuring
Cleanup the setting of the csnbds to respect the setting of
Use __ilog2 instead of writing the code to compute it
Disable unused CS configs
Ensure ddrlaw.bar is configured
Cc: Joe Hershberger <joe.hershberger@gmail.com>
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
This change lays the groundwork for the BOOTFLAG_* flags being removed.
This change has the small affect of delaying 100ms on PCI initialization
after a warm boot as opposed to the optimal 1ms on some boards.
included the mpc8308_p1m board.
We get two build errors:
fsl_elbc_nand.c: In function 'fsl_elbc_run_command':
fsl_elbc_nand.c:231: error: 'fsl_lbc_t' has no member named 'lsor'
make[1]: *** [/work/wd/tmp-ppc/drivers/mtd/nand/fsl_elbc_nand.o] Error 1
and
ve8313.c: In function 'initdram':
ve8313.c:104: error: expected '=', ',', ';', 'asm' or '__attribute__'
before '*' token
ve8313.c:104: error: 'lbc' undeclared (first use in this function)
ve8313.c:104: error: (Each undeclared identifier is reported only once
ve8313.c:104: error: for each function it appears in.)
ve8313.c:104: error: 'immap_t' has no member named 'lbus'
make[1]: *** [ve8313.o] Error 1
make: *** [board/ve8313/libve8313.a] Error 2
Due to changes to unifiy local bus struct definitions.
Reported-by: Wolfgang Denk <wd@denx.de>
This patch add support for the ve8313 board based on
Freescale MPC8313 CPU.
- serial console on UART 1
- 128 MB DDR RAM
- 32 MB NOR Flash
- 16 MB NAND Flash
- Ethernet MII Mode over on TSEC0
- micrel ksz804 phy
- Hardware WDT MAX824
changes since v1
- Environment size = sector size
- use red. environment
- add comments from Kim Phillips
- add MAKEALL, MAINTAINERS entry
- Codingstyle issues fixed
- inserted original Copyrights
- PCI subsys vendor ID changed from 0x1057 (Motorola)
to 0x1957 (Freescale)
changes since v2
- add comments from Wolfgang Denk
- fix Codingstyle and some comments
- reworked WDT reset (just toggling the WD_TRIG pin)
- Environment size now 16KiB
- fixed RAMBOOT version
- fixed CONFIG_SYS_LOAD_ADDR
- renamed CONFIG_TSEC1_NAME to TSEC1
