path: root/board/ve8313
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-08-19powerpc/83xx: Fix build issue with ve8313 board due to lbus changesKumar Gala
We get two build errors: fsl_elbc_nand.c: In function 'fsl_elbc_run_command': fsl_elbc_nand.c:231: error: 'fsl_lbc_t' has no member named 'lsor' make[1]: *** [/work/wd/tmp-ppc/drivers/mtd/nand/fsl_elbc_nand.o] Error 1 and ve8313.c: In function 'initdram': ve8313.c:104: error: expected '=', ',', ';', 'asm' or '__attribute__' before '*' token ve8313.c:104: error: 'lbc' undeclared (first use in this function) ve8313.c:104: error: (Each undeclared identifier is reported only once ve8313.c:104: error: for each function it appears in.) ve8313.c:104: error: 'immap_t' has no member named 'lbus' make[1]: *** [ve8313.o] Error 1 make: *** [board/ve8313/libve8313.a] Error 2 Due to changes to unifiy local bus struct definitions. Reported-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-0983xx: add support for ve8313 boardHeiko Schocher
This patch add support for the ve8313 board based on Freescale MPC8313 CPU. - serial console on UART 1 - 128 MB DDR RAM - 32 MB NOR Flash - 16 MB NAND Flash - Ethernet MII Mode over on TSEC0 - micrel ksz804 phy - Hardware WDT MAX824 changes since v1 - Environment size = sector size - use red. environment - add comments from Kim Phillips - add MAKEALL, MAINTAINERS entry - Codingstyle issues fixed - inserted original Copyrights - PCI subsys vendor ID changed from 0x1057 (Motorola) to 0x1957 (Freescale) changes since v2 - add comments from Wolfgang Denk - fix Codingstyle and some comments - reworked WDT reset (just toggling the WD_TRIG pin) - Environment size now 16KiB - fixed RAMBOOT version - fixed CONFIG_SYS_LOAD_ADDR - renamed CONFIG_TSEC1_NAME to TSEC1 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
