The platforms this code was for have been removed, drop this support
code as well.
It is a pain to have to specify the value 10 in each call. Add a new
dectoul() function and update the code to use it.
It is a pain to have to specify the value 16 in each call. Add a new
hextoul() function and update the code to use it.
Add a proper comment to simple_strtoul() while we are here.
Move this uncommon header out of the common header.
We should not use typedefs in U-Boot. They cannot be used as forward
declarations which means that header files must include the full header to
access them.
Drop the typedef and rename the struct to remove the _s suffix which is
now not useful.
This requires quite a few header-file additions.
Drop inclusion of crc.h in common.h and use the correct header directly
instead.
With this we can drop the conflicting definition in fw_env.h and rely on
the crc.h header, which is already included.
Move env_set() over to the new header file.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We are now using an env_ prefix for environment functions. Rename these
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Suggested-by: Wolfgang Denk <wd@denx.de>
We are now using an env_ prefix for environment functions. Rename setenv()
This board runs a P5020 or P5040 chip, and utilizes
an EEPROM with similar formatting to the Freescale P5020DS.
Large amounts of this code were developed by
Adrian Cox <adrian at humboldt dot co dot uk>
Signed-off-by: Andy Fleming <afleming@gmail.com>
Reviewed-by: York Sun <yorksun@freescale.com>
