path: root/board/vamrs
2020-06-02rockchip: Remove ARCH= references from documentationTom Rini
When building U-Boot we select the architecture via Kconfig and not ARCH being passed in via the environment or make cmdline. Acked-by: Kever Yang <kever.yang@rock-chips.com> Cc: Simon Glass <sjg@chromium.org> Cc: Philipp Tomsich <philipp.tomsich@theobroma-systems.com> Acked-by: Klaus Goger <klaus.goger@theobroma-systems.com> Cc: Jagan Teki <jagan@amarulasolutions.com> Signed-off-by: Tom Rini <trini@konsulko.com> Reviewed-by: Simon Glass <sjg@chromium.org>
2020-05-22rockchip: Enable PCIe/M.2 on rock960 boardJagan Teki
Due to board limitation some SSD's would work on rock960 PCIe M.2 only with 1.8V IO domain. So, this patch enables grf io_sel explicitly to make PCIe/M.2 to work. Cc: Tom Cubie <tom@radxa.com> Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Acked-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-29rockchip: rk3399: Migrate to use common board fileKever Yang
Use common board file for board_init() and board_late_init(), for Rockchip SoCs have very similar process. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-07-19rockchip: rock960-rk3399: fix mail format in MAINTAINER fileKever Yang
The mail format should have '<>', or else the patman won't recognize it correctley. Signed-off-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26rockchip: rk3399: Support common spl_board_initJagan Teki
Support common spl_board_init by moving code from puma board file into, common rk3399-board-spl.c. Part of the code has sysreset-gpio, regulators_enable_boot_on but right now only puma board is using this with relevant config options rest remains common for all targets. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26board: rk3399: Drop explicit uart enablement in spl_board_initJagan Teki
preloader_console_init is used for printing SPL boot banner that usually called from spl_board_init. The current spl_board_init in evb and rock960 is enabling explicit pinctrl, debug uart prior to calling preloader_console_init which eventually not required since board_init_f is already enabled debug uart. So, drop those explicit enablement calls from spl_board_init of evb, rock960. Tested this by enabling CONFIG_SPL_BOARD_INIT and adding u-boot,dm-pre-reloc property for uart node. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-06-26Kconfig: Add u-boot.itb BUILD_TARGET for RockchipJagan Teki
Add u-boot.itb BUILD_TARGET for Rockchip platform when SPL_LOAD_FIT is being used. This can get rid of building itb explicitly with 'make u-boot.itb' so, from now all required images will build just by make. Signed-off-by: Jagan Teki <jagan@amarulasolutions.com> Reviewed-by: Kever Yang <kever.yang@rock-chips.com>
2019-05-01rockchip: use 'arch-rockchip' as header file pathKever Yang
Rockchip use 'arch-rockchip' instead of arch-$(SOC) as common header file path, so that we can get the correct path directly. Signed-off-by: Kever Yang <kever.yang@rock-chips.com> Reviewed-by: Philipp Tomsich <philipp.tomsich@theobroma-systems.com>
2018-12-06rockchip: rk3399: Add MAINTAINERS entryTom Rini
Add an entry for the Ficus EE board to the existing rock960 MAINTAINERS file. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-12-06rockchip: rk3399: Add common Rock960 family from VamrsManivannan Sadhasivam
Rock960 is a family of boards based on Rockchip RK3399 SoC from Vamrs. It consists of Rock960 (Consumer Edition) and Ficus (Enterprise Edition) 96Boards. Below are some of the key differences between both Rock960 and Ficus boards: 1. Different host enable GPIO for USB 2. Different power and reset GPIO for PCI-E 3. No Ethernet port on Rock960 The common board support will be utilized by both boards. The device tree has been organized in such a way that only the properties which differ between both boards are placed in the board specific dts and the reset of the nodes are placed in common dtsi file. Signed-off-by: Manivannan Sadhasivam <manivannan.sadhasivam@linaro.org> [Added instructions for SD card boot] Signed-off-by: Ezequiel Garcia <ezequiel@collabora.com> Reviewed-by: Simon Glass <sjg@chromium.org> Tested-by: Peter Robinson <pbrobinson@gmail.com>
