Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
Current u-boot top of tree builds with warnings/errors for
the following boards:
ads5121 cpci5200 mecp5200 v38b IAD210 MBX MBX860T NX823
RPXClassic debris PN62
following patch solves this.
The environment is the canonical storage location of the mac address, so
we're killing off the global data location and moving everything to
querying the env directly.
Rather than have the common ppc code have board-specific hooks, move the
board_get_enetaddr() function into the board-specific init functions.
CC: Ben Warren <biggerbadderben@gmail.com>
This patch changes the return type of initdram() from long int to phys_size_t.
This is required for a couple of reasons: long int limits the amount of dram
to 2GB, and u-boot in general is moving over to phys_size_t to represent the
size of physical memory. phys_size_t is defined as an unsigned long on almost
all current platforms.
This patch *only* changes the return type of the initdram function (in
include/common.h, as well as in each board's implementation of initdram). It
does not actually modify the code inside the function on any of the platforms;
platforms which wish to support more than 2GB of DRAM will need to modify
their initdram() function code.
Build tested with MAKEALL for ppc, arm, mips, mips-el. Booted on powerpc
MPC8641HPCN.
Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
Several board/<...>/config.mk files include dynamically built (by
the Makefile) config files but used the wrong file name of
$(TOPDIR)/board/$(BOARDDIR)/config.tmp
instead if the correct
$(OBJTREE)/board/$(BOARDDIR)/config.tmp
The bug is nasty because the build result is correct for the (normal)
in-tree builds, and because 'sinclude' is used no errors get raised
even for out-of-tree build tests. But out-of-tree builds use an
incomplete and thus usually incorrect configuration...
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
- fix a typo in V38B config file
- move watchdog initialisation earlier in the boot process
- add "wdt=off" to default kernel command line (disables kernel watchdog)
- add watchdog support
- enable GPIO_WKUP_7 pin for input
- code cleanup
* remove warnings when compiling ethaddr.c
* adjust linker script (fixes a crash resulting from incorrect
definition of __u_boot_cmd_start)
- Some MarelV38B code cleanup.
