Convert to DM_SERIAL and drop the iomux board file
level init as it's handled as part of the DM serial
layer instead.
Signed-off-by: Peter Robinson <pbrobinson@gmail.com>
Reviewed-by: Fabio Estevam <festevam@denx.de>
This moves over the PMIC power init to DM and the associated i2c and
regulator bits.
Calling gpio_request() prior to its usage is now mandatory.
This fixes the following GPIO errors:
U-Boot SPL 2022.01-rc3-00067-g7a5be871c0ec (Dec 18 2021 - 17:45:07 -0300)
Trying to boot from MMC1
U-Boot 2022.01-rc3-00067-g7a5be871c0ec (Dec 18 2021 - 17:45:07 -0300)
CPU: Freescale i.MX6Q rev1.2 at 792 MHz
Reset cause: WDOG
Model: Udoo i.MX6 Quad Board
Board: Udoo Quad
DRAM: 1 GiB
MMC: FSL_SDHC: 2
Loading Environment from MMC... OK
In: serial
Out: serial
Err: serial
gpio@20a0000: set_dir_flags: error: gpio GPIO2_31 not reserved
gpio@20a4000: set_dir_flags: error: gpio GPIO3_23 not reserved
gpio@20b0000: set_dir_flags: error: gpio GPIO6_24 not reserved
gpio@20b0000: set_dir_flags: error: gpio GPIO6_25 not reserved
gpio@20b0000: set_dir_flags: error: gpio GPIO6_27 not reserved
gpio@20b0000: set_dir_flags: error: gpio GPIO6_28 not reserved
gpio@20b0000: set_dir_flags: error: gpio GPIO6_29 not reserved
gpio@20a4000: set_value: error: gpio GPIO3_23 not reserved
Net: Could not get PHY for FEC0: addr -2
No ethernet found.
Signed-off-by: Fabio Estevam <festevam@gmail.com>
Reviewed-by: Peter Robinson <pbrobinson@gmail.com>
Currently, imx6q udoo board fails to boot like this:
U-Boot SPL 2022.01-rc3-00061-g95ca715adad3 (Dec 18 2021 - 18:04:40 -0300)
The reason is that the eSDHC controller is not initialized in SPL.
Initialize the eSDHC controller in SPL via C code as DM is not
used in SPL.
By default the Model information from DT is printed:
CPU: Freescale i.MX6SX rev1.2 996 MHz (running at 792 MHz)
CPU: Extended Commercial temperature grade (-20C to 105C) at 63C
Reset cause: POR
Model: UDOO Neo Basic
Board: UDOO Neo FULL
I2C: ready
As the udoo basic DT is used, such output may be confusing.
Improve it by only printing the Board model instead, which is
read from the board identification GPIOs.
Acked-by: Tommaso Merciai <tomm.merciai@gmail.com>
Tested-by: Tommaso Merciai <tomm.merciai@gmail.com>
Currently, the board model is not printed correctly:
Board: UDOO Neo UNDEFINED
Read the model type in SPL and store it the internal OCRAM, so that
U-Boot proper can retrieve it correctly.
The ethernet has a RMII not RGMII, also needs DM_MDIO and finally
initialise it later in the process as it's not needed that early on
and not everything is ready so it locks up the device.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
This fixes booting from the mSD card from both SPL and when
using it for the OS booting. It also cleans up a few mmc
booting bits that are no longer needed.
gpio@20a8000: set_dir_flags: error: gpio GPIO4_16 not reserved
gpio@20a8000: set_dir_flags: error: gpio GPIO4_13 not reserved
gpio@20a8000: set_dir_flags: error: gpio GPIO4_0 not reserved
gpio@20a8000: get_value: error: gpio GPIO4_13 not reserved
gpio@20a8000: get_value: error: gpio GPIO4_0 not reserved
gpio@20a0000: set_dir_flags: error: gpio GPIO2_1 not reserved
gpio@20a0000: set_value: error: gpio GPIO2_1 not reserved
Fixes: 191840ae99 ("ARM: imx: udoo_neo: Enable OF_CONTROL and DM gpio/pin control")
CONFIG_POWER_I2C
CONFIG_POWER_LEGACY
They are handled at the same time due to a dependency between them.
Update the Makefile rule to use legacy power only in U-Boot proper.
Unfortunately a separate rule is needed in SPL to be able to build
legacy power. Add SPL related symbols for both, to allow for SPL-only
usage.
Reviewed-by: Jaehoon Chung <jh80.chung@samsung.com>
[trini: More SPL related cleanups, reword commit message]
This option is used in pre-driver model code and much of it has never
been converted to driver model.
We want to add a new option to enable power support, so we can use a
simple rule in the Makefile. Rename this one, which is really about
a particular implementation of power.
Also update the pmic.h header file so it either includes the legacy
API or the driver model one.
Convert the UDOO Neo to ethernet DM support.
Cc: Francesco Montefoschi <francesco.montefoschi@udoo.org>
Cc: Breno Lima <breno.lima@nxp.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Convert UDOO Neo to use DM MMC.
Convert the UDOO board to use DM_ETH.
Enable DM block, DM MMC and DM SATA support on iMX6 Udoo
convert board code to match the DM support.
Use my personal e-mail address for U-Boot related work.
Move this out of the common header and include it only where needed. In
a number of cases this requires adding "struct udevice;" to avoid adding
another large header or in other cases replacing / adding missing header
files that had been pulled in, very indirectly. Finally, we have a few
cases where we did not need to include <asm/global_data.h> at all, so
remove that include.
The Linux coding style guide (Documentation/process/coding-style.rst)
clearly says:
It's a **mistake** to use typedef for structures and pointers.
Besides, using typedef for structures is annoying when you try to make
headers self-contained.
Let's say you have the following function declaration in a header:
void foo(bd_t *bd);
This is not self-contained since bd_t is not defined.
To tell the compiler what 'bd_t' is, you need to include <asm/u-boot.h>
#include <asm/u-boot.h>
void foo(bd_t *bd);
Then, the include direcective pulls in more bloat needlessly.
If you use 'struct bd_info' instead, it is enough to put a forward
declaration as follows:
struct bd_info;
void foo(struct bd_info *bd);
Right, typedef'ing bd_t is a mistake.
I used coccinelle to generate this commit.
The semantic patch that makes this change is as follows:
<smpl>
typedef bd_t;
-bd_t
+struct bd_info
</smpl>
Signed-off-by: Masahiro Yamada <masahiroy@kernel.org>
Move this uncommon header out of the common header.
Move this header out of the common header. Network support is used in
quite a few places but it still does not warrant blanket inclusion.
Note that this net.h header itself has quite a lot in it. It could be
split into the driver-mode support, functions, structures, checksumming,
etc.
It is bad practice to include common.h in other header files since it can
bring in any number of superfluous definitions. It implies that some C
files don't include it and thus may be missing CONFIG options that are set
up by that file. The C files should include these themselves.
Update some header files in arch/arm to drop this.
A number of board function belong in init.h with the others. Move them.
Move env_set() over to the new header file.
Converted to use fsl_esdhc_imx for i.MX platforms.
Signed-off-by: Yangbo Lu <yangbo.lu@nxp.com>
Tested-by: Steffen Dirkwinkel <s.dirkwinkel@beckhoff.com>
Reviewed-by: Peng Fan <peng.fan@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Martyn Welch <martyn.welch@collabora.com>
Acked-by: Jason Liu <Jason.hui.liu@nxp.com>
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
We have a large number of places where while we historically referenced
gd in the code we no longer do, as well as cases where the code added
that line "just in case" during development and never dropped it.
Thomas reported U-Boot failed to build host tools if libfdt-devel
package is installed because tools include libfdt headers from
/usr/include/ instead of using internal ones.
This commit moves the header code:
include/libfdt.h -> include/linux/libfdt.h
include/libfdt_env.h -> include/linux/libfdt_env.h
and replaces include directives:
#include <libfdt.h> -> #include <linux/libfdt.h>
#include <libfdt_env.h> -> #include <linux/libfdt_env.h>
Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
Inside setup_sata() there is a cpu type check, so there is no need to
do this check in the board file.
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Heinrich Schuchardt <xypron.glpk@gmx.de>
bss section is cleared in crt0.S. board_init_r() is also
entered from crt0 code.
Cc: Christian Gmeiner <christian.gmeiner@gmail.com>
Cc: Nikita Kiryanov <nikita@compulab.co.il>
Cc: Jagan Teki <jagan@amarulasolutions.com>
Cc: Tim Harvey <tharvey@gateworks.com>
Cc: Lukasz Majewski <lukma@denx.de>
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D,
MX6Q and MX6QP processors move it to the soc.c file.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
We are now using an env_ prefix for environment functions. Rename setenv()
for consistency. Also add function comments in common.h.
Suggested-by: Wolfgang Denk <wd@denx.de>
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
At present CONFIG_CMD_SATA enables the 'sata' command which also brings
in SATA support. Some boards may wish to enable SATA without the command.
Add a separate CONFIG to permit this.
The standard way is to put ifdef/endif in the very first column.
Commit c94981efa20cc58 ("udoo_neo: Remove USDHC3 support") removed
the SDHC3 support, but missed to remove the entry from the usdhc_cfg
structure, so just remove it.
UDOO Neo boards has one FEC port connected to KSZ8091, add support for it.
Tested on a UDOO Neo Full with "dhcp zImage" command.
UDOO Neo boards has a PFUZE300 connected to I2C1 bus.
Tested on a UDOO Neo Full with "pmic PFUZE3000 dump" command.
Change board_string() function to static because it's being used locally.
It's not necessary to support USDHC3 in U-Boot as it's being used for
the WLAN.
UDOO Neo Board is a development board from Seco that has three models:
- UDOO Neo Basic
- UDOO Neo Basic Kick Starter
- UDOO Neo Extended
- UDOO Neo Full
All versions are based on the i.MX6 SoloX processor.
For more details about the UDOO Neo board, please refer to:
http://www.udoo.org/udoo-neo/
This work is based on a previous commit of Francesco Montefoschi
<francesco.monte@gmail.com>:
https://github.com/fmntf/u-boot/commit/877b71184a5105e708024f232d36aed574961844
Only tested on the UDOO Neo Full board.
Add a README file to explain how to build and flash the SD card
for Udoo boards.
Now, arch/${ARCH}/include/asm/errno.h and include/linux/errno.h have
the same content. (both just wrap <asm-generic/errno.h>)
Replace all include directives for <asm/errno.h> with <linux/errno.h>.
[trini: Fixup include/clk.]
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and
REFR fields of the MDREF register as 1 and 7, respectively for
DDR3 and 0 and 3 for LPDDR2.
Looking at the MDREF initialization done via DCD we see that
boards do need to initialize these fields differently:
$ git grep 0x021b0020 board/
board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800
board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */
board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800
board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800
board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800
board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800
board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800
board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800
So introduce a mechanism for users to be able to configure
REFSEL and REFR fields as needed.
Keep all the mx6 SPL users in their current REF_SEL and REFR values,
so no functional changes for the existing users.
Reviewed-by: Eric Nelson <eric@nelint.com>
Update my email address to the NXP account.
We should not return 0 on failure, so return a negative error code
instead.
Also centralize the error path so that is easier to follow.
Remove duplicated SYS_SOC Kconfig entry from board Kconfig,
because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig.
Signed-off-by: Peng Fan <Peng.Fan@freescale.com>
Cc: Stefan Roese <sr@denx.de>
Cc: Troy Kisky <troy.kisky@boundarydevices.com>
Cc: "Eric Bénard" <eric@eukrea.com>
Cc: Fabio Estevam <fabio.estevam@freescale.com>
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
Cc: Otavio Salvador <otavio@ossystems.com.br>
Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com>
Acked-by: Markus Niebel <Markus.Niebel@tq-group.com>
Acked-by: Troy Kisky <troy.kisky@boundarydevices.com>
Currently we need to build one U-boot image for each of the udoo
variants: quad and dual-lite.
By switching to SPL we can support all two variants with a single binary.
Based on the SPL for wandboard.
Tested with OpenELEC (Open Embedded Linux Entertainment Center)
on both boards.
Signed-off-by: Peter Vicman <peter.vicman@gmail.com>
Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
