path: root/board/udoo
2016-10-06udoo: Add a README fileFabio Estevam
Add a README file to explain how to build and flash the SD card for Udoo boards. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-09-06mx6: ddr: Allow changing REFSEL and REFR fieldsFabio Estevam
Currently MX6 SPL DDR initialization hardcodes the REF_SEL and REFR fields of the MDREF register as 1 and 7, respectively for DDR3 and 0 and 3 for LPDDR2. Looking at the MDREF initialization done via DCD we see that boards do need to initialize these fields differently: $ git grep 0x021b0020 board/ board/bachmann/ot1200/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/ccv/xpress/imximage.cfg:DATA 4 0x021b0020 0x00000800 /* MMDC0_MDREF */ board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x7800 board/freescale/mx6qarm2/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qarm2/imximage_mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6dl.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6qsabreauto/mx6qp.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6dlsabresd.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6sabresd/mx6q_4x_mt41j128.cfg:DATA 4 0x021b0020 0x00005800 board/freescale/mx6slevk/imximage.cfg:DATA 4 0x021b0020 0x00001800 board/freescale/mx6sxsabreauto/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/freescale/mx6sxsabresd/imximage.cfg:DATA 4 0x021b0020 0x00000800 board/warp/imximage.cfg:DATA 4 0x021b0020 0x00001800 So introduce a mechanism for users to be able to configure REFSEL and REFR fields as needed. Keep all the mx6 SPL users in their current REF_SEL and REFR values, so no functional changes for the existing users. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Eric Nelson <eric@nelint.com>
2016-01-11MAINTAINERS/mailmap: Update my email addressFabio Estevam
Update my email address to the NXP account. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2015-09-13udoo: Fix the error handling in board_eth_init()Fabio Estevam
We should not return 0 on failure, so return a negative error code instead. Also centralize the error path so that is easier to follow. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric BĂ©nard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-09-02udoo: Switch to SPL supportvpeter4
Currently we need to build one U-boot image for each of the udoo variants: quad and dual-lite. By switching to SPL we can support all two variants with a single binary. Based on the SPL for wandboard. Tested with OpenELEC (Open Embedded Linux Entertainment Center) on both boards. Signed-off-by: Peter Vicman <peter.vicman@gmail.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Acked-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Peter Vicman <peter.vicman@gmail.com> Acked-by: Fabio Estevam <fabio.estevam@freescale.com>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-12-17udoo: Add SATA support on uDoo Board.Giuseppe Pagano
Add SATA support on uDoo Board. Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-28udoo: Fix watchdog during kernel boot.Giuseppe Pagano
uDoo uses APX823-31W5 watchdog chip. Timeout is about 1.2 seconds. To disabled watchdog during kernel boot, WDI pin of that chip needs to be in "high impedance" state. I.mx6 gpio configuration does not contemplate tristate, so pin is set as input in high impedance. Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com> Reviewed-by: Fabio Estevam <fabio.estevam@freescale.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-28udoo: Add ethernet support (FEC + Micrel KSZ9031).Giuseppe Pagano
Add Ethernet and networking support on uDoo board (FEC +phy Micrel KSZ9031). Ethernet speed is currently limited to 10/100Mbps. Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-28udoo: Move and optimize platform register setting.Giuseppe Pagano
Previous uDoo configuration adopts register settings for DDR3, clock, muxing, etc. taken from Nitrogen6x. uDoo schematics is rather different from that board, and it needs customized setting for most of the registers. All this changes can be considered atomical since it is part of initial support of the board. Patch changes uDoo configuration files path to a specific one, and adopt optimized value for every configured register. Signed-off-by: Giuseppe Pagano <giuseppe.pagano@seco.com> Tested-by: Fabio Estevam <fabio.estevam@freescale.com> CC: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@freescale.com>
2013-11-13i.MX6DQ/DLS: replace pad names with their Linux kernel equivalentsEric Nelson
Signed-off-by: Eric Nelson <eric.nelson@boundarydevices.com>
2013-11-09Merge branch 'iu-boot/master' into 'u-boot-arm/master'Albert ARIBAUD
Conflicts: arch/arm/cpu/arm926ejs/mxs/Makefile board/compulab/cm_t35/Makefile board/corscience/tricorder/Makefile board/ppcag/bg0900/Makefile drivers/bootcount/Makefile include/configs/omap4_common.h include/configs/pdnb3.h Makefile conflicts are due to additions/removals of object files on the ARM branch vs KBuild introduction on the main branch. Resolution consists in adjusting the list of object files in the main branch version. This also applies to two files which are not listed as conflicting but had to be modified: board/compulab/common/Makefile board/udoo/Makefile include/configs/omap4_common.h conflicts are due to the OMAP4 conversion to ti_armv7_common.h on the ARM side, and CONFIG_SYS_HZ removal on the main side. Resolution is to convert as this icludes removal of CONFIG_SYS_HZ. include/configs/pdnb3.h is due to a removal on ARM side. Trivial resolution is to remove the file. Note: 'git show' will also list two files just because they are new: include/configs/am335x_igep0033.h include/configs/omap3_igep00x0.h
2013-10-17udoo: Add initial support for mx6q udoo boardFabio Estevam
Add basic support for mx6q udoo board. For further information about Udoo board: http://www.udoo.org/ Tested booting a mainline device tree kernel and a Yocto rootfs from mmc. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
