path: root/board/uc101
2009-09-25mpc5200, mucmc52, uc101: config cleanupHeiko Schocher
- As these boards are similiar, collect common config options in manroland/common.h and manroland/mpc52xx-common.h for mpc5200 specific common options for this manufacturer. - add OF support - update default environment Signed-off-by: Heiko Schocher <hs@denx.de> Minor edit of commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-07-04Remove obsolete mpc5xxx linker scripts (3 of 3)Grant Likely
2007-07-04Consolidate mpc5xxx linker scriptsGrant Likely
2007-04-14[Fix] Set the LED status register on the UC101 for the LXT971 PHY.Heiko Schocher
clear the Display after reset. Signed-off-by: Heiko Schocher <hs@denx.de>
2007-03-07UC101: fix compiler warningsWolfgang Denk
2007-01-15Merge with /home/hs/SC3/u-bootWolfgang Denk
Some code cleanup.
2006-12-21[PATCH] Add support for the UC101 board from MAN.Heiko Schocher
