path: root/board/ttcontrol/vision2
2011-12-24vision2: Fix checkpatch warningFabio Estevam
Fix the following checkpatch warning: WARNING: braces {} are not necessary for single statement blocks Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-04vision2: Remove unused get_board_rev functionFabio Estevam
No board information is passed for VISION2, so remove get_board_rev function. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-11-03vision2: Remove unused header fileFabio Estevam
errno.h is not used on this file, so remove it. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-10-27MX5: vision2: use new pmic driverStefano Babic
Switch to new pmic generic driver. Signed-off-by: Stefano Babic <sbabic@denx.de>
2011-10-17Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
* 'master' of git://git.denx.de/u-boot-video: video: Moving mx3fb.c to CONFIG_VIDEO mx31: make HSP clock for mx3fb driver available MX5: Make IPU display output and pixel format configurable VIDEO: MX5: export pix format VIDEO: MX5: Switch MX5 to CONFIG_VIDEO video: update the Freescale DIU driver to use linux/fb.h
2011-10-13MX5: Make IPU display output and pixel format configurableMarek Vasut
Signed-off-by: Marek Vasut <marek.vasut@gmail.com> Signed-off-by: Stefano Babic <sbabic@denx.de> Tested-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-10-13VIDEO: MX5: Switch MX5 to CONFIG_VIDEOStefano Babic
The framebuffer driver for MX5 is based on CONFIG_LCD. In the current implementation, there is a serious bug because the required memory is allocated before relocation, but the driver knows only later which is the resolution of the display. The patch switches the driver to CONFIG_VIDEO and the memory is allocated by the driver itself. We also need to switch the vision2 board code and config file in the same commit so that this commit will be bisectable. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Anatolij Gustschin <agust@denx.de> Tested-by: Stefano Babic <sbabic@denx.de> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2011-09-30vision2: Place machine ID into board configFabio Estevam
Let common code set the machine ID. Cc: Stefano Babic <sbabic@denx.de> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com> Acked-by: Stefano Babic <sbabic@denx.de>
2011-09-04MX5: vision2: make use of GPIO frameworkStefano Babic
2011-07-04vision2: Fix build due to WEIM registers name changeFabio Estevam
commit 0015de1a (MX5: Make the weim structure complete) fixed the name for the WEIM registers in order to match with the MX51/MX53 manuals. Fix the WEIM register for vision2 board so that it can build again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-05-23mx5: board: code clean up for checkboard codeJason Liu
The boot cause code has been factor out to soc common code,we need drop the part from the board support code This patch also remove the redundant cpu version print Signed-off-by: Jason Liu <jason.hui@linaro.org>
2011-05-23MX51: vision2: Fix build for vision2 board.Fabio Estevam
config.mk should not be used in board directory and should be removed. Use the same approach for building the image as other MX51/MX53 boards. After this change vision2 board can be built again. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2011-05-23MX51: vision: Let video mode struct be independant of watchdog.Fabio Estevam
Currently the fb_videomode struct is only declared if CONFIG_HW_WATCHDOG is defined. Remove this dependancy and let the video struct always be declared. Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2010-10-29Merge branch 'master' of git://git.denx.de/u-boot-imxWolfgang Denk
2010-10-29Drop support for CONFIG_SYS_ARM_WITHOUT_RELOCWolfgang Denk
When this define was introduced, the idea was to provide a soft migration path for ARM boards to get adapted to the new relocation support. However, other recent changes led to a different implementation (ELF relocation), where this no longer works. By now CONFIG_SYS_ARM_WITHOUT_RELOC does not only not help any more, but it actually hurts because it obfuscates the actual code by sprinkling it with lots of dead and non-working debris. So let's make a clean cut and drop CONFIG_SYS_ARM_WITHOUT_RELOC. Signed-off-by: Wolfgang Denk <wd@denx.de> Tested-by: Heiko Schocher <hs@denx.de> Tested-by: Reinhard Meyer <u-boot@emk-elektronik.de>
2010-10-28MX51: add CONFIG_SYS_TEXT_BASE to vision2 board, use general ld scriptStefano Babic
Recent patch changed TEXT_BASE to CONFIG_SYS_TEXT_BASE and vision2 board was not updated. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-22MX51: Add video support to vision2 boardStefano Babic
The patch adds support for LCD to the vision2 board. Signed-off-by: Stefano Babic <sbabic@denx.de>
2010-10-18MX5: rename mx51 to mx5Jason Liu
Rename mx51 to mx5 in order to support more mx51 like-style SOCs such as MX53 and the followings. Signed-off-by: Jason Liu <r64343@freescale.com>
2010-10-07MX51: Support for TTECH vision2 boardStefano Babic
The patch adds support for TTECH vision2 board. The board has 512MB RAM, SDHC slot and 4MB SPI device from StMicron. Signed-off-by: Stefano Babic <sbabic@denx.de>
