path: root/board/ttcontrol/vision2/Kconfig
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
