path: root/board/trizepsiv
2010-10-22PXA: trizepsiv: Fix for relocMarek Vasut
2010-10-19Build: PXA: Fix TrizepsIV build variantsMarek Vasut
2010-10-19PXA: pxa-regs.h cleanupMarek Vasut
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-07-06xscale: add support for the polaris boardStefano Babic
The Polaris board is based on the TrizepsIV module of Keith & Koep (http://www.keith-koep.com). Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-07-06xscale: fix USB initialization for Trizepsiv moduleStefano Babic
Due to change in the usb_board_init() prototype, the USB for the TrizepsIV was not correctly initialized. Removed dummy print from usb_board_stop(). Signed-off-by: Stefano Babic <sbabic@denx.de>
2009-06-15Convert DM9000 driver for CONFIG_NET_MULTIRemy Bohmer
All drivers need to be converted to CONFIG_NET_MULTI. This patch converts the dm9000 driver. Signed-off-by: Thomas Smits <ts.smits@gmail.com> Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-08Add config option for disabling DM9000-SROM support.Remy Bohmer
Some boards do not have SROM support for the DM9000 network adapter. Instead of listing these board names in the driver code, make this option configurable from the board config file. It also removes a build warning for the at91sam9261ek board: 'dm9000x.c:545: warning: 'read_srom_word' defined but not used' And it repaires the trizepsiv board build which was broken around the same routines Signed-off-by: Remy Bohmer <linux@bohmer.net> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-05-03Fix defined but not used build warningMarcel Ziswiler
- warning: 'srom' defined but not used Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com>
2007-09-07Update CHANGELOG, minor coding style cleanup.Wolfgang Denk
2007-09-07PXA270: Added support for TrizepsIV board.stefano babic
This patch add support for the Trizeps IV module (520Mhz). Signed-off-by: Stefano Babic <sbabic@denx.de>
