path: root/board/trab
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-12-16board/trab/memory.c: Fix compile problems.Wolfgang Denk
Apply changes from commit 44b4dbed to board/trab/memory.c, too. Actually we'd need a major cleanup here - as it turns out, board/trab/memory.c is more or less a verbatim copy of post/drivers/memory.c ... but then, trab is EOL anyway,r so this is not worth the effort. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-16trab: make trab_fkt standalone code independent of libgccWolfgang Denk
Use our own local functions in lib_arm/ instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-09trab: fix build problem after change to use do_div()Wolfgang Denk
We must link with libgeneric now. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09ARM: Use do_div() instead of division for "long long".Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-19[new uImage] Fix style issue spotted by Wolfgang Denk <wd@denx.org>Bartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-12[new uImage] Fix build problems on trab boardMarian Balakowicz
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-08-12Adapt board configuration and fix kernel crash on MCC200 board.Wolfgang Denk
The update procedure was modified to turn off the USB subsystem before exit for MCC200 and TRAB. This is necessary as otherwise the USB controller continues to write periodically to system memory! MCC200-specific notes: - the patch disables the magic key check for MCC200 - the patch contains the configuration changes made for the new revision of the board. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-08-06Add functions to list of exported functionsMartin Krause
Additionally export the following fuctions (to make trab_config build again): - simple_strtol() - strcmp() Also bump the ABI version to reflect this change Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-07-10board/[j-z]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[q-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-03-23Merge with git://www.denx.de/git/u-boot.git#testing-USBMarkus Klotzbuecher
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-11-27Merge with /home/mk/git/u-boot-generic_ohci#generic_ohciWolfgang Denk
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
2006-08-10Fix compiler warning for TRAB board.Wolfgang Denk
Patch by Martin Krause, 07 Aug 2006
2006-07-19Adjust filenames for USB update images on TRAB board.Wolfgang Denk
During an automatic update via USB stick, U-Boot searches for images with the name "firmware.img" and "kernel.img". This names are now changed to "firmw_01.img" and "kernl_01.img". This is done, to prevent updates of new boards (with the new macronics "c" step flashes) with old, incompatible firmware or kernel versions. Patch by Martin Krause, 21 Jun 2006
2006-07-19Bugfix in VFD routine on TRAB board.Wolfgang Denk
Make sure upper lext pixel can be set to blue, too (so far only red was possible). Patch by Martin Krause, 15 Feb 2006
2006-07-19Fix some bugs in TRAB board flash driver.Wolfgang Denk
- increase CFG_FLASH_ERASE_TOUT from 2 to 15 seconds - use CFG_FLASH_WRITE_TOUT for programming instead of CFG_FLASH_ERASE_TOUT - remove "Unlock Bypass" mode, because macronix flashes do not support this mode officially - fix flash reset command from 0x00FF to 0x00F0. 0x00FF is only specified for Intel compatible flashes, not for AMD compatible. Patch by Martin Krause, 15 Feb 2006
2006-07-19Add additional error messages to flash driver on TRAB boardWolfgang Denk
(for erase errors and timeout errors) Patch by Martin Krause, 14 Feb 2006
2006-06-26Cleanup trab board for GCC-4.xWolfgang Denk
2006-06-16Fix TRAB channel switching delay for trab_fkt.bin standalone applikationWolfgang Denk
Patch by Martin Krause, 08 Nov 2005 In tsc2000_read_channel() the delay after setting the multiplexer to a temperature channel is increased from 1,5 ms to 10 ms. This is to allow the multiplexer inputs to stabilize after huge steps of the input signal level.
2006-06-16Fix setting of environment variable "ver" on trab boardWolfgang Denk
The environment variable "ver" is now set before do_auto_update() is called, so that "ver" can be used in USB update scripts. Patch by Martin Krause, 27 Oct 2005
2006-06-16Fix wrong usage of udelay() in led_blink() on trab boardWolfgang Denk
2006-06-16Fix udelay bug in vfd.c for trab boardWolfgang Denk
2006-03-11More GCC 4.x woesWolfgang Denk
2006-03-11More GCC 4.x code cleanupWolfgang Denk
2005-10-28Fix conflicting types (flash_write()) in trab auto_update.cMarian Balakowicz
2005-09-21Fix bug in auto_update (trab board)Wolfgang Denk
Patch by Martin Krause, 16 Sep 2005
2005-04-02Prepare for SoC rework of ARM code:wdenk
- rename CONFIG_BOOTBINFUNC into CONFIG_INIT_CRITICAL - rename memsetup into lowlevel_init (function name and source files)
