Update for R360MPI board
* Add new meaning to "autostart" environment variable:
If set to "no", a standalone image passed to the
"bootm" command will be copied to the load address
(and eventually uncompressed), but NOT be started.
This can be used to load and uncompress arbitrary
data.
* Set max brightness for MN11236 displays on TRAB board
the HSYNC/VSYNC. Requires new CPLD code (Version 101 for Rev. 100
boards, version 153 for Rev. 200 boards).
* Patch by Vladimir Gurevich, 12 Mar 2003:
Fix relocation problem of statically initialized string pointers
in common/cmd_pci.c
* Patch by Kai-Uwe Blöm, 12 Mar 2003:
Cleanup & bug fixes for JFFS2 code:
- the memory mangement was broken. It caused havoc on malloc by
writing beyond the block boundaries.
- the length calculation for files was wrong, sometimes resulting
in short file reads.
- data copying now optionally takes fragment version numbers into
account, to avoid copying from older data.
See doc/README.JFFS2 for details.
- 16/32 MB and 50/80 MHz support with auto-detection for IP860
- ETH05 and BEDBUG support for CU824
- added support for MicroSys CPC45
- new BOOTROM/FLASH0 and DOC base for PM826
* Patch by Robert Schwebel, 12 Mar 2003:
Fix the chpart command on innokom board
* Name cleanup:
mv include/asm-i386/ppcboot-i386.h include/asm-i386/u-boot-i386.h
s/PPCBoot/U-Boot/ in some files
s/pImage/uImage/ in some files
* Patch by Detlev Zundel, 15 Jan 2003:
Fix '' command line quoting
* Patch by The LEOX team, 19 Jan 2003:
- add support for the ELPT860 board
- add support for Dallas ds164x RTC
- minimal setup for CardBus bridges
- add EEPROM read/write support in the CS8900 driver
- add support for the builtin I2C controller in the Samsung s3c24x0 chips
- add support for MPL's VCMA9 (Samsung s3c2410 based) board
* Patch by Steven Scholz, 04 Feb 2003:
add support for RTC DS1307
* Patch by Reinhard Meyer, 5 Feb 2003:
fix PLPRCR/SCCR init sequence on 8xx to allow for
changes of EBDF by software
* Patch by Vladimir Gurevich, 07 Feb 2003:
"API-compatibility patch" for 4xx I2C driver
- fix bug in BOOTP code (must use NetCopyIP)
- update of CSB226 port
- clear BSS segment on XScale
- added support for i2c_init_board() function
- update to the Innokom plattform
* Extend support for redundand environments for configurations where
environment size < sector size
* Patch by Erwin Rol, 27 Feb 2003:
Add support for RTEMS
* Add image information to README
* Fix dual PCMCIA slot support (when running with just one
slot populated)
* Add VFD type detection to trab board
* extend drivers/cs8900.c driver to synchronize ethaddr environment
variable with value in the EEPROM
* Start adding MIPS support files
Fix misc problems with AmigaOne support
* Patch by Chris Hallinan, 3 Dec 2002:
minor cleanup to the MPC8245 EPIC driver
* Patch by Pierre Aubert , 28 Nov 2002
Add support for external (SIU) interrupts on MPC8xx
Fix nested syscalls bug in standalone applications
* Patch by David Müller, 27 Nov 2002:
fix output of "pciinfo" command for CardBus bridge devices.
* Fix bug in TQM8260 board detection - boards got stuck when board ID
was not readable
* Patch by Pierre Aubert, 20 Nov 2002
Add driver for Epson SED13806 graphic controller.
Add support for BMP logos in cfb_console driver.
Fixes for x86 port (mostly strings issues)
* Patch by Ken Chou, 18 Nov 2002:
Fix for natsemi NIC cards (DP83815)
* Patch by Pierre Aubert, 19 Nov 2002:
fix a bug for the MII configuration, and some warnings
Improve PCI access on 32-bits Compact PCI bus
Adjust VFD initialization on TRAB
Cleanup RRvision video code
seconds instead of ms.
* Patch by Robert Schwebel, 1 Nov 2002:
XScale related cleanup (affects all ARM boards)
* Cleanup of names, warnings, and README.
