path: root/board/trab
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-04-13arm: Move cpu/$CPU to arch/arm/cpu/$CPUPeter Tyser
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-11-27Add a unified s3c24x0 header filekevin.morfitt@fearnside-systems.co.uk
This patch adds a unified s3c24x0 cpu header file that selects the header file for the specific s3c24x0 cpu from the SOC and CPU configs defined in board config file. This removes the current chain of s3c24-type #ifdef's from the s3c24x0 code. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-11-27Move s3c24x0 header files to asm-arm/arch-s3c24x0/kevin.morfitt@fearnside-systems.co.uk
This patch moves the s3c24x0 header files from include/ to include/asm-arm/arch-s3c24x0/. checkpatch.pl showed 2 errors and 3 warnings. The 2 errors were both due to a non-UTF8 character in David M?ller's name: ERROR: Invalid UTF-8, patch and commit message should be encoded in UTF-8 #489: FILE: include/asm-arm/arch-s3c24x0/s3c2410.h:3: + * David M?ller ELSOFT AG Switzerland. d.mueller@elsoft.ch As David's name correctly contains a non-UTF8 character I haven't fixed these errors. The 3 warnings were all because of the use of 'volatile' in s3c24x0.h: WARNING: Use of volatile is usually wrong: see Documentation/volatile-considered-harmful.txt #673: FILE: include/asm-arm/arch-s3c24x0/s3c24x0.h:35: +typedef volatile u8 S3C24X0_REG8; +typedef volatile u16 S3C24X0_REG16; +typedef volatile u32 S3C24X0_REG32; I'll fix these errors in another patch. Tested by running MAKEALL for ARM8 targets and ensuring there were no new errors or warnings. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-10-13Clean-up of s3c24x0 drivers excluding nand driverkevin.morfitt@fearnside-systems.co.uk
This patch re-formats the arm920t s3c24x0 driver files, excluding the nand driver, in preparation for changes to add support for the Embest SBC2440-II Board. The changes are as follows: - re-indent the code using Lindent - make sure register layouts are defined using a C struct - replace the upper-case typedef'ed C struct names with lower case non-typedef'ed ones - make sure registers are accessed using the proper accessor functions - run checkpatch.pl and fix any error reports It assumes the following patch has been applied first: - [U-Boot][PATCH-ARM] CONFIG_SYS_HZ fix for ARM902T S3C24X0 Boards, 05/09/2009 - patches 1/4 and 2/4 of this series Tested on an Embest SBC2440-II Board with local u-boot patches as I don't have any s3c2400 or s3c2410 boards but need this patch applying before I can submit patches for the SBC2440-II Board. Also, temporarily modified sbc2410x, smdk2400, smdk2410 and trab configs to use the mtd nand driver (which isn't used by any board at the moment), ran MAKEALL for all ARM9 targets and no new warnings or errors were found. Signed-off-by: Kevin Morfitt <kevin.morfitt@fearnside-systems.co.uk> Signed-off-by: Minkyu Kang <mk7.kang@samsung.com>
2009-08-25Convert CS8900 Ethernet driver to CONFIG_NET_MULTI APIBen Warren
All in-tree boards that use this controller have CONFIG_NET_MULTI added Also: - changed CONFIG_DRIVER_CS8900 to CONFIG_CS8900 - changed CS8900_BASE to CONFIG_CS8900_BASE - changed CS8900_BUS?? to CONFIG_CS8900_BUS?? - cleaned up line lengths - modified VCMA9 command function that accesses the device - removed MAC address initialization from lib_arm/board.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de>
2009-08-21TRAB: make independent of specific libgcc helper routinesWolfgang Denk
The TRAB board references local libgcc helper routines (lib_arm/div0.o and lib_arm/_umodsi3.o) which cause build problems when we try to use the normal, compiler provided libgcc instead. Removing these references allows to build both with and without the local libgcc helper routines. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-08-13trab: rename spi_init()Mike Frysinger
The local board-specific spi_init() function conflicts with the common SPI layer, so rename it to something board-specific. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2009-07-27Make linking against libgcc configurableWolfgang Denk
Many (especially ARM) tool chains seem to come with broken or otherwise unusable (for the purposes of builing U-Boot) run-time support libraries `libgcc.a'. By using the "USE_PRIVATE_LIBGCC" setting we allow to use alternative libraries instead. "USE_PRIVATE_LIBGCC" can either be set as an environment variable in the shell, or as a command line argument when running "make", i. e. $ make USE_PRIVATE_LIBGCC=yes or $ USE_PRIVATE_LIBGCC=yes $ export USE_PRIVATE_LIBGCC $ make The value of "USE_PRIVATE_LIBGCC" is the name of the directory which contains the alternative run-time support library `libgcc.a'. The special value "yes" selects the directory $(OBJTREE)/lib_$(ARCH) . Note that not all architectures provide an alternative `libgcc.a' in their lib_$(ARCH) directories - so far, only ARM does. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Cc: Prafulla Wadaskar <prafulla@marvell.com> cc: Stefan Roese <sr@denx.de>
2009-07-22Fix "ld: cannot find -lstubs" build errorWolfgang Denk
Commit 1bc15386 moved the examples/ to examples/standalone but failed to adapt the Makefiles that need to link against libstubs.a Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-07-18stdio/device: rework function naming conventionJean-Christophe PLAGNIOL-VILLARD
So far the console API uses the following naming convention: ======Extract====== typedef struct device_t; int device_register (device_t * dev); int devices_init (void); int device_deregister(char *devname); struct list_head* device_get_list(void); device_t* device_get_by_name(char* name); device_t* device_clone(device_t *dev); ======= which is too generic and confusing. Instead of using device_XX and device_t we change this into stdio_XX and stdio_dev This will also allow to add later a generic device mechanism in order to have support for multiple devices and driver instances. Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com> Edited commit message. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-06-12arm: unify linker scriptJean-Christophe PLAGNIOL-VILLARD
all arm boards except a few use the same cpu linker script so move it to cpu/$(CPU) that could be overwrite in following order SOC BOARD via the corresponding config.mk Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2009-06-04Redundant Environment: protect full sector sizeWolfgang Denk
Several boards used different ways to specify the size of the protected area when enabling flash write protection for the sectors holding the environment variables: some used CONFIG_ENV_SIZE and CONFIG_ENV_SIZE_REDUND, some used CONFIG_ENV_SECT_SIZE, and some even a mix of both for the "normal" and the "redundant" areas. Normally, this makes no difference at all. However, things are different when you have to deal with boards that can come with different types of flash chips, which may have different sector sizes. Here we may have to chose CONFIG_ENV_SECT_SIZE such that it fits the biggest sector size, which may include several sectors on boards using the smaller sector flash types. In such a case, using CONFIG_ENV_SIZE or CONFIG_ENV_SIZE_REDUND to enable the protection may lead to the case that only the first of these sectors get protected, while the following ones aren't. This is no real problem, but it can be confusing for the user - especially on boards that use CONFIG_ENV_SECT_SIZE to protect the "normal" areas, while using CONFIG_ENV_SIZE_REDUND for the "redundant" area. To avoid such inconsistencies, I changed all sucn boards that I found to consistently use CONFIG_ENV_SECT_SIZE for protection. This should not cause any functional changes to the code. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Paul Ruhland Cc: Pantelis Antoniou <panto@intracom.gr> Cc: Stefan Roese <sr@denx.de> Cc: Gary Jennejohn <garyj@denx.de> Cc: Dave Ellis <DGE@sixnetio.com> Acked-by: Stefan Roese <sr@denx.de>
2009-05-15Fix e-mail address of Gary Jennejohn.Detlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-04-28Replace __asm references with __asm__Peter Tyser
__asm__ follows gcc's documented syntax and is generally more common than __asm. This change is only asthetic and should not affect functionality. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-12-16board/trab/memory.c: Fix compile problems.Wolfgang Denk
Apply changes from commit 44b4dbed to board/trab/memory.c, too. Actually we'd need a major cleanup here - as it turns out, board/trab/memory.c is more or less a verbatim copy of post/drivers/memory.c ... but then, trab is EOL anyway,r so this is not worth the effort. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-16trab: make trab_fkt standalone code independent of libgccWolfgang Denk
Use our own local functions in lib_arm/ instead. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-09-09trab: fix build problem after change to use do_div()Wolfgang Denk
We must link with libgeneric now. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-09ARM: Use do_div() instead of division for "long long".Sergei Poselenov
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-12Change bd/gd memsize/ram_size to be phys_size_t.Becky Bruce
Currently, both are defined as an unsigned long, but should be phys_size_t. This should result in no real change, since phys_size_t is currently an unsigned long for all the default configs. Also add print_lnum to cmd_bdinfo to deal with the potentially wider memsize. Signed-off-by: Becky Bruce <becky.bruce@freescale.com>
2008-03-19[new uImage] Fix style issue spotted by Wolfgang Denk <wd@denx.org>Bartlomiej Sieka
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
2008-03-12[new uImage] Fix build problems on trab boardMarian Balakowicz
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-29[new uImage] Update naming convention for bootm/uImage related codeMarian Balakowicz
This patch introduces the following prefix convention for the image format handling and bootm related code: genimg_ - dual format shared code image_ - legacy uImage format specific code fit_ - new uImage format specific code boot_ - booting process related code Related routines are renamed and a few pieces of code are moved around and re-grouped. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-25[new uImage] Add dual format uImage support frameworkMarian Balakowicz
This patch adds framework for dual format images. Format detection is added and the bootm controll flow is updated to include cases for new FIT format uImages. When the legacy (image_header based) format is detected appropriate legacy specific handling is invoked. For the new (FIT based) format uImages dual boot framework has a minial support, that will only print out a corresponding debug messages. Implementation of the FIT specific handling will be added in following patches. Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2008-02-07[new uImage] Define a API for image handling operationsMarian Balakowicz
- Add inline helper macros for basic header processing - Move common non inline code common/image.c - Replace direct header access with the API routines - Rename IH_CPU_* to IH_ARCH_* Signed-off-by: Marian Balakowicz <m8@semihalf.com>
2007-08-12Adapt board configuration and fix kernel crash on MCC200 board.Wolfgang Denk
The update procedure was modified to turn off the USB subsystem before exit for MCC200 and TRAB. This is necessary as otherwise the USB controller continues to write periodically to system memory! MCC200-specific notes: - the patch disables the magic key check for MCC200 - the patch contains the configuration changes made for the new revision of the board. Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com> Signed-off-by: Wolfgang Denk <wd@denx.de>
2007-08-07Merge with git://www.denx.de/git/u-boot.gitMarkus Klotzbuecher
2007-08-06Add functions to list of exported functionsMartin Krause
Additionally export the following fuctions (to make trab_config build again): - simple_strtol() - strcmp() Also bump the ABI version to reflect this change Signed-off-by: Martin Krause <martin.krause@tqs.de>
2007-07-10board/[j-z]*: Remove lingering references to CFG_CMD_* symbols.Jon Loeliger
2007-07-09board/[q-z]*: Remove obsolete references to CONFIG_COMMANDSJon Loeliger
2007-07-04board/[k-z]*: Augment CONFIG_COMMANDS tests with defined(CONFIG_CMD_*).Jon Loeliger
2007-03-23Merge with git://www.denx.de/git/u-boot.git#testing-USBMarkus Klotzbuecher
2007-02-20[PATCH 1_4] Merge common get_dev() routines for block devicesGrant Likely
Each of the filesystem drivers duplicate the get_dev routine. This change merges them into a single function in part.c Signed-off-by: Grant Likely <grant.likely@secretlab.ca>
2006-11-27Merge with /home/mk/git/u-boot-generic_ohci#generic_ohciWolfgang Denk
2006-11-27Introduced the configuration option CONFIG_USB_OHCI_NEW in order to be ableMarkus Klotzbuecher
to choose between the old and the generic OHCI drivers.
