2003-10-09 | * Patch by Martin Krause, 09 Oct 2003:LABEL_2003_10_09_1515 | wdenk | |
Fixes for TRAB board - /board/trab/rs485.c: correct baudrate - /board/trab/cmd_trab.c: bug fix for problem with timer overflow in udelay(); fix some timing problems with adc controller - /board/trab/trab_fkt.c: add new commands: gain, eeprom and power; modify commands: touch and buzzer * Disable CONFIG_SUPPORT_VFAT when used with CONFIG_AUTO_UPDATE (quick & dirty workaround for rogue pointer problem in get_vfatname()); Use direct function calls for auto_update instead of hush commands | |||
2003-09-12 | Move TRAB burn-in tests to TRAB board directoryLABEL_2003_09_12_1745 | wdenk | |
