The 'trab' board configuration is broken, and there is nobody who is
interested and willing to fix it. Drop it.
This includes support for VFD displays which have always been used by
this board only.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Signed-off-by: Bartlomiej Sieka <tur@semihalf.com>
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
This patch introduces the following prefix convention for the
image format handling and bootm related code:
genimg_ - dual format shared code
image_ - legacy uImage format specific code
fit_ - new uImage format specific code
boot_ - booting process related code
Related routines are renamed and a few pieces of code are moved around and
re-grouped.
This patch adds framework for dual format images. Format detection is added
and the bootm controll flow is updated to include cases for new FIT format
uImages.
When the legacy (image_header based) format is detected appropriate
legacy specific handling is invoked. For the new (FIT based) format uImages
dual boot framework has a minial support, that will only print out a
corresponding debug messages. Implementation of the FIT specific handling will
be added in following patches.
- Add inline helper macros for basic header processing
- Move common non inline code common/image.c
- Replace direct header access with the API routines
- Rename IH_CPU_* to IH_ARCH_*
The update procedure was modified to turn off the USB subsystem
before exit for MCC200 and TRAB. This is necessary as otherwise the
USB controller continues to write periodically to system memory!
MCC200-specific notes:
- the patch disables the magic key check for MCC200
- the patch contains the configuration changes made
for the new revision of the board.
Signed-off-by: Sergei Poselenov <sposelenov@emcraft.com>
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Each of the filesystem drivers duplicate the get_dev routine. This change
merges them into a single function in part.c
to choose between the old and the generic OHCI drivers.
During an automatic update via USB stick, U-Boot searches for
images with the name "firmware.img" and "kernel.img". This names
are now changed to "firmw_01.img" and "kernl_01.img". This is done,
to prevent updates of new boards (with the new macronics "c" step
flashes) with old, incompatible firmware or kernel versions.
Patch by Martin Krause, 21 Jun 2006
Patch by Martin Krause, 16 Sep 2005
* Add reset code for Coral-P on INKA4x0 board
* Patch by Martin Krause, 28 Jun 2004:
Update for TRAB board.
* Fix some missing "volatile"s in MPC5xxx FEC driver
* Minor code cleanup (coding style)
* Patch by Reinhard Meyer, 30 Dec 2003:
- cpu/mpc5xxx/fec.c: added CONFIG_PHY_ADDR, added CONFIG_PHY_TYPE,
- added CONFIG_PHY_ADDR to include/configs/IceCube.h,
- turned debug print of PHY registers into a function (called in two places)
- added support for EMK MPC5200 based modules
* Fix MPC8xx PLPRCR_MFD_SHIFT typo
* Add support for TQM866M modules
* Fixes for TQM855M with 4 MB flash (Am29DL163 = _no_ mirror bit flash)
* Fix a few compiler warnings
- add a return value for the fpga command
- add ide_preinit() function called in ide_init if CONFIG_IDE_PREINIT
is defined. If ide_preinit fails, ide_init is aborted.
- fix an endianess problem in fat.h
headers first instead of always reading the whole images.
* TRAB auto-update: image type patch by Martin Krause, 17 Oct 2003
header on image type as encoded in the header
* Make 5200 reset command _really_ reset the board, without running
any other code after it
* Fix flash mapping and display on P3G4 board
* Patch by Kyle Harris, 15 Jul 2003:
- add support for Intel IXP425 CPU
- add support for IXDP425 eval board
Fixes for TRAB board
- /board/trab/rs485.c: correct baudrate
- /board/trab/cmd_trab.c: bug fix for problem with timer overflow in
udelay(); fix some timing problems with adc controller
- /board/trab/trab_fkt.c: add new commands: gain, eeprom and power;
modify commands: touch and buzzer
* Disable CONFIG_SUPPORT_VFAT when used with CONFIG_AUTO_UPDATE
(quick & dirty workaround for rogue pointer problem in get_vfatname());
Use direct function calls for auto_update instead of hush commands
* Make fatload set filesize environment variable
fix potential buffer overlow problem
* enable basic / medium / high-end configurations for PPChameleonEVB
board; fix NAND code
* enable TFTP client code to specify to the server the desired
timeout value (see RFC-2349)
Cleanup for submitted patches.
Minor cleanup of comments
