path: root/board/tqm85xx
2006-10-11Merge with http://opensource.freescale.com/pub/scm/u-boot-85xx.git#for_wdWolfgang Denk
2006-10-11* Fix a bunch of compiler warnings for gcc 4.0Matthew McClintock
Signed-off-by: Matthew McClintock <msm@freescale.com>
2006-07-21More code cleanupWolfgang Denk
2006-07-19Fix support for PS/2 keyboard on TQM85xx boardsWolfgang Denk
The PS/2 keyobard driver for the TQM85xx modules only supports the internal DUART of the MPC85xx CPU. Since the MPC8560 doesn't include a DUART, the TQM8560 modules can't be used with the PS/2 keyboard controller on the STK85xx board. The PS/2 keyboard driver should work with the modules TQM8540, TQM8541 and TQM8555, but it only has been tested on a TQM8540, yet. Make sure the PS/2 controller on the STK85xx is programmed. Jumper settings: X66 1-2, 9-10; X61 2-3 Patch by Martin Krause, 21 Jun 2006
2006-07-19Add support for TB5200 boardWolfgang Denk
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module integrated in a little aluminium case. Patch by Martin Krause, 8 Jun 2006 Some code cleanup
2006-06-16Add support for PS/2 keyboard on TQM85xx boardWolfgang Denk
Patch by Martin Krause, 07 Nov 2005 Tested on a STK85XX baseboard. Make sure the PS/2 controller has been programmed. Jumper Settings: X66 1-2, 9-10; X61 2-3
2006-03-01Fix problem with flash_get_size() from CFI driver updateStefan Roese
Patch by Stefan Roese, 1 Mar 2006
2006-02-28Major CFI-FLASH driver update:Stefan Roese
* Add env-variable "unlock" to handle initial state of sectors (locked/unlocked). Only the U-Boot image and it's environment is protected, all other sectors are unprotected (unlocked) if flash hardware protection is used (CFG_FLASH_PROTECTION) and the environment variable "unlock" is set to "yes". Patch by Stefan Roese, 28 Feb 2006 * Update drivers/cfi_flash.c: - find_sector() called in both versions of flash_write_cfiword() Patch by Peter Pearse, 27th Feb 2006 * CFI support for a x8/x16 AMD/Spansion flash configured in x8 mode Patch by Jose Maria Lopez, 16 Jan 2006 * Add support for AMD/Spansion Flashes in flash_write_cfibuffer Patch by Alex Bastos and Thomas Schaefer, 2005-08-29 * Changes/fixes for drivers/cfi_flash.c: We *should* check if there are any error bits if the previous call returned ERR_OK (Otherwise we will have output an error message in flash_status_check() already.) The original code would only check for error bits if flash_status_check() returns ERR_TIMEOUT. Patch by Marcus Hall, 23 Aug 2005 * Changes/fixes for drivers/cfi_flash.c: - Add CFG_FLASH_PROTECT_CLEAR on drivers/cfi_flash.c - Prohibit buffer write when buffer_size is 1 on drivers/cfi_flash.c Patch by Sangmoon Kim, 19 Aug 2005 * Fixes for drivers/cfi_flash.c: - Fix wrong timeout value usage in flash_status_check() - Round write_tout up when converting to msec in flash_get_size() - Remove clearing flash status at the end of flash_write_cfibuffer() which sets Intel 28F640J3 flash back to command mode on CSB472 Patch by Tolunay Orkun, 02 July 2005
2005-11-30Add support for TQM8541/8555 boards, TQM85xx support reworked:Stefan Roese
- Support for TQM8541/8555 boards added. - Complete rework of TQM8540/8560 support. - Common TQM85xx code now supports all current TQM85xx platforms (TQM8540/8541/8555/8560). - DDR SDRAM size detection added. - CAS latency default values can be overwritten by setting "serial#" to e.g. "ABC0001 casl=25" -> CAS latency 2.5 will be used. If problems are detected with this non default CAS latency, the defualt values will be used instead. - FLASH size detection added. - Moved FCC ethernet driver initialization behind TSEC driver init -> TSEC is first device. Patch by Stefan Roese, 30 Nov 2005
