2005-08-31 | Add I2C support to TQM8540 and TQM8560 boards (EEPROM, RTC, LM75-DTT). | Stefan Roese | |
Removed CFG_CMD_DISPLAY from default commands. Fixed compiler warning in net.c. Patch by Stefan Roese, 31 Aug 2005 | |||
2005-08-31 | Fix problems with ld version 2.16 (dot outside sections problem) | Wolfgang Denk | |
Pointed out by Gerhard Jaeger, 31 Aug 2005; cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html | |||
2005-07-25 | * Patch by Jon Loeliger, 2005-07-25 | Jon Loeliger | |
Move the TSEC driver out of cpu/mpc85xx as it will be shared by the upcoming mpc83xx family as well. | |||
2005-04-05 | Add support for TQM8560 boardLABEL_2005_04_05_1830 | wdenk | |
