path: root/board/tqm834x
2007-03-02mpc83xx: streamline the 83xx immr head fileDave Liu
For better format and style, I streamlined the 83xx head files, including immap_83xx.h and mpc83xx.h. In the old head files, 1) duplicated macro definition appear in the both files; 2) the structure of QE immr is duplicated in the immap_83xx.h and immap_qe.h; 3) The macro definition put inside the each structure. So, I cleaned up the structure of QE immr from immap_83xx.h, deleted the duplicated stuff and moved the macro definition to mpc83xx.h, Just like MPC8260. CHANGELOG *streamline the 83xx immr head file Signed-off-by: Dave Liu <daveliu@freescale.com>
2006-11-03mpc83xx: Replace CFG_IMMRBAR with CFG_IMMRTimur Tabi
Replace all instances of CFG_IMMRBAR with CFG_IMMR, so that the 83xx tree matches the other 8xxx trees. Signed-off-by: Timur Tabi <timur@freescale.com>
2006-11-03mpc83xx: Unified TQM834x variable names with 83xx and consolidated macrosTanya Jiang
Unified TQM834x variable names with 83xx and consolidated macro in preparation for the 8360 and other upcoming 83xx devices. Signed-off-by: Tanya Jiang <tanya.jiang@freescale.com>
2006-10-09Coding style cleanupWolfgang Denk
2006-07-21More code cleanupWolfgang Denk
2006-06-16Fix DDR6 errata on TQM834x boardsWolfgang Denk
Patch by Thomas Waehner, 07 Mar 2006
2005-12-04Code cleanup, especially MIPS for GCC 4.xWolfgang Denk
2005-11-17Minor changes to init flags in TQM834x PCI.Rafal Jaworowski
2005-10-17Add PCI support for the TQM834x board.Rafal Jaworowski
2005-10-11Added support for TQM834x boards.Marian Balakowicz
