2006-10-09 | Coding style cleanup | Wolfgang Denk | |
2006-09-01 | Add support for a saving build objects in a separate directory. | Marian Balakowicz | |
Modifications are based on the linux kernel approach and support two use cases: 1) Add O= to the make command line 'make O=/tmp/build all' 2) Set environement variable BUILD_DIR to point to the desired location 'export BUILD_DIR=/tmp/build' 'make' The second approach can also be used with a MAKEALL script 'export BUILD_DIR=/tmp/build' './MAKEALL' Command line 'O=' setting overrides BUILD_DIR environent variable. When none of the above methods is used the local build is performed and the object files are placed in the source directory. | |||
2006-07-21 | More code cleanup | Wolfgang Denk | |
2006-06-16 | Fix DDR6 errata on TQM834x boards | Wolfgang Denk | |
Patch by Thomas Waehner, 07 Mar 2006 | |||
2006-03-31 | GCC-4.x fixes: clean up global data pointer initialization for all boards. | Wolfgang Denk | |
2005-12-12 | (no commit message) | Wolfgang Denk | |
2005-12-04 | Code cleanup, especially MIPS for GCC 4.x | Wolfgang Denk | |
2005-11-17 | Minor changes to init flags in TQM834x PCI. | Rafal Jaworowski | |
2005-10-17 | Add PCI support for the TQM834x board. | Rafal Jaworowski | |
2005-10-11 | Added support for TQM834x boards. | Marian Balakowicz | |
