2003-04-27 | * LWMON extensions: | wdenk | |
- Splashscreen support - modem support - sysmon support - temperature dependend enabling of LCD * Allow booting from old "PPCBoot" disk partitions * Add support for TQM8255 Board / MPC8255 CPU | |||
2002-12-07 | * Patch by Hans-Joerg Frieden, 06 Dec 2002LABEL_2002_12_07_0120 | wdenk | |
Fix misc problems with AmigaOne support * Patch by Chris Hallinan, 3 Dec 2002: minor cleanup to the MPC8245 EPIC driver * Patch by Pierre Aubert , 28 Nov 2002 Add support for external (SIU) interrupts on MPC8xx * Patch by Pierre Aubert , 28 Nov 2002 Fix nested syscalls bug in standalone applications * Patch by David Müller, 27 Nov 2002: fix output of "pciinfo" command for CardBus bridge devices. * Fix bug in TQM8260 board detection - boards got stuck when board ID was not readable | |||
2002-11-02 | Initial revision | wdenk | |
2002-08-26 | Initial revision | wdenk | |
2002-08-17 | Initial revision | wdenk | |
2002-07-11 | Initial revision | wdenk | |
2001-06-01 | Initial revision | wdenk | |
