2008-06-10 | TQM: move TQM boards to board/tqc | Wolfgang Grandegger | |
Move all TQM board directories to the vendor specific directory "tqc" for modules from TQ-Components GmbH (http://www.tqc.de). Signed-off-by: Wolfgang Grandegger <wg@grandegger.com> | |||
2003-05-30 | * Get (mostly) rid of CFG_MONITOR_LEN definition; compute real lengthLABEL_2003_05_30_1450 | wdenk | |
instead CFG_MONITOR_LEN is now only used to determine _at_compile_ _time_ (!) if the environment is embedded within the U-Boot image, or in a separate flash sector. * Cleanup CFG_DER #defines in config files (wd maintained only) | |||
2002-08-17 | Initial revision | wdenk | |
