Move all TQM board directories to the vendor specific directory "tqc"
for modules from TQ-Components GmbH (http://www.tqc.de).
Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
This commit gets rid of a huge amount of silly white-space issues.
Especially, all sequences of SPACEs followed by TAB characters get
removed (unless they appear in print statements).
Also remove all embedded "vim:" and "vi:" statements which hide
indentation problems.
Before the first call of ide_reset(), the level of the IDE reset
signal on the TQM5200 is low (reset asserted). This patch sets the
default value to high (reset not asserted).
Currently this patch fixes no real problem, but it is cleaner to
assert the reset signal only on demand, and not permanently.
Signed-off-by: Martin Krause <martin.krause@tqs.de>
This board never used a MGT5100 processor.
Call fdt_fixup_memory() on the boards TQM5200, TQM5200_B, TQM5200S,
TB5200 and TB5200_B to fixup the /memory node with the memory values
detected by U-Boot.
detected by U-Boot.
This patch fixes a bug in the SDRAM initialization code for the
TQM5200. The hi_addr bit is now set correctly. Without this patch
the hi_addr bit is always set to 1, if the second SDRAM bank is
not populated.
For other MPC5200 boards a correspondig patch has already been applied
some time ago, see commit a63109281ad41b0fb489fdcb901171f76bcdbc2c.
Forget the first patch please. I confused flash with SDRAM in
the comment ...
board/tqm5200/tqm5200.c
usb_cpu_init() configures GPS USB pins, clocks, etc. and
is required for proper operation of kernel USB subsystem.
This setup was previously done in the kernel by the fixup
code which is being removed, thus low level init must be
done by U-boot now.
Signed-off-by: Marian Balakowicz <m8@semihalf.com>
done by U-boot now.
Signed-off-by: Markus Klotzbuecher <mk@denx.de>
grafic controller
Some commands for the STK52xx base board try to access the SM501 grafic
controller. But the TQM5200S has no grafic controller (only the TQM5200
and the TQM5200B have). This patch deactivates the commands accessing
the SM501 for the TQM5200S.
Affects boards: icecube (lite5200), jupiter, motionpro, tqm5200
Tested on: lite5200b
Note: the fixup functions have not been moved to a common place. This
patch is targeted for immediate merging as in solves a build issue, but
the final name/location of the fixups is still subject to debate. I
propose to merge this now, and move the fixups in the next merge window
to be usable by all targets.
Fixed some broken instances of "#ifdef CMD_CFG_IDE" too.
Those always evaluated TRUE, and thus were always compiled
even when IDE really wasn't defined/wanted.
This is a compatibility step that allows both the older form
and the new form to co-exist for a while until the older can
be removed entirely.
All transformations are of the form:
Before:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT)
After:
#if (CONFIG_COMMANDS & CFG_CMD_AUTOSCRIPT) || defined(CONFIG_CMD_AUTOSCRIPT)
Signed-off-by: Jan Wrobel <wrr@semihalf.com>
Acked-by: Bartlomiej Sieka <tur@semihalf.com>
- use CFI driver (replaces custom flash driver) for main 'cam5200' target
- add second build target 'cam5200_niosflash' which still uses custom driver
- fix off-by-one error in board/tqm5200/cam5200_flash.c error message
- simplify "udate" definitions
MPC5XXX_WU_GPIO_DATA macro to MPC5XXX_WU_GPIO_DATA_O (per MPC5200 User's
Manual). Replace the uses of MPC5XXX_WU_GPIO_DATA with
MPC5XXX_WU_GPIO_DATA_O for affected boards.
- Add defintions for some MPC5XXX GPIO pins.
(and then only if PSC6_3 is read as "1" when booting).
Patch by Martin Krause, 21 Jun 2006
- Map in a additional chip selects CS4 and CS5.
- Modify the port configration, configure six UARTs and no PCI,
ATA and USB.
- Add custom flash driver to handle specific byte swapping
(according to S1 switch setting).
Patch by Marian Balakowicz, 12 Sep 2006
Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
- make highboot configurations use environment at high end, too,
to avoid flash fragmentation
- always use redundand environment
- don't enable video code for modules without graphics controller
- provide useful (though different) mtdparts settings
- get rid of CONFIG_CS_AUTOCONF which was always set anyway
* Extend mkconfig tool to print more useful target name
Hint: the CPLD on the TQM5200 must be programmed with a software
version supporting the high boot option! The new TQM5200S is
already supporting this option. On the TQM5200 this option will be
supported in configurations with MPC5200 rev B processors.
To actually "high boot", set jumper X30 on the STK52xx.
Patch by Martin Krause, 12 Jul 2006
- Support for TQM5200S (short version without graphic controller)
- Support for modules with 'N' type S29GL128N Spansion flashes
(requires changes to flash layout)
- Support for MPC5200B cpu (mostly support for second SDRAM bank)
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module
integrated in a little aluminium case.
Patch by Martin Krause, 8 Jun 2006
Some code cleanup
Patch by Martin Krause, 11 Jan 2006
Make the automatic CS configuration the default.
The dedicated configurations CONFIG_TQM5200_AA, CONFIG_TQM5200_AB
and CONFIG_TQM5200_AC are removed.
"TQM5200_config" is now the default for STK52XX.200 base boards.
On a STK52XX.100 base board "TQM5200_STK100_config" must be used.
Patch by Martin Krause, 07 Nov 2005
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
- Sound commands (beep, wav, sound)
- Test commands (led, can, backlight, rs232)
Patch by Martin Krause, 02 May 2005
Patch by Martin Krause, 8 Apr. 2005
Minor coding style cleanup.
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
- add support for "STK52xx" board (including PS/2 multiplexer)
- add hardware detection for TQM5200
* Patch by Mark Jonas, 05 Jul 2004:
add support for the Total5100's and Total5200's LCD screen
* Patches by Dan Eisenhut, 01 Jul 2004:
- README fixes.
- Move doc2000.h include to prevent compiler warning on some boards
Add support for TQM5200 board
* Patch by Martin Krause, 29 Jun 2004:
Add loopw command: infinite write loop on address range
