path: root/board/tqm5200
2005-08-19Add new board specific commands for TQM5200/STK52XXWolfgang Denk
- Sound commands (beep, wav, sound) - Test commands (led, can, backlight, rs232) Patch by Martin Krause, 02 May 2005
2005-08-18Fix initialization problem on TQM5200 without SM501Wolfgang Denk
Patch by Martin Krause, 8 Apr. 2005
2005-08-10Add configuration for IFM AEV FIFO board.Wolfgang Denk
Minor coding style cleanup.
2005-03-27Patches by Martin Krause, 22 Mar 2005:wdenk
- use TQM5200_auto as MAKEALL target for TQM5200 systems - add support for SM501 graphics controller - add support for graphic console on TQM5200 - add support for TQM5200 Rev 200 - cleanup, fix typo in include/configs/TQM5200.h
2004-12-16Code cleanup.wdenk
2004-12-12Patch by Martin Krause, 27 Oct 2004:wdenk
- add support for "STK52xx" board (including PS/2 multiplexer) - add hardware detection for TQM5200
2004-07-11* Cleanupwdenk
* Patch by Mark Jonas, 05 Jul 2004: add support for the Total5100's and Total5200's LCD screen * Patches by Dan Eisenhut, 01 Jul 2004: - README fixes. - Move doc2000.h include to prevent compiler warning on some boards
2004-07-11* Patch by Martin Krause, 30 Jun 2004:wdenk
Add support for TQM5200 board * Patch by Martin Krause, 29 Jun 2004: Add loopw command: infinite write loop on address range
