Modifications are based on the linux kernel approach and
support two use cases:
1) Add O= to the make command line
'make O=/tmp/build all'
2) Set environement variable BUILD_DIR to point to the desired location
'export BUILD_DIR=/tmp/build'
'make'
The second approach can also be used with a MAKEALL script
'./MAKEALL'
Command line 'O=' setting overrides BUILD_DIR environent variable.
When none of the above methods is used the local build is performed and
the object files are placed in the source directory.
- make highboot configurations use environment at high end, too,
to avoid flash fragmentation
- always use redundand environment
- don't enable video code for modules without graphics controller
- provide useful (though different) mtdparts settings
- get rid of CONFIG_CS_AUTOCONF which was always set anyway
* Extend mkconfig tool to print more useful target name
Hint: the CPLD on the TQM5200 must be programmed with a software
version supporting the high boot option! The new TQM5200S is
already supporting this option. On the TQM5200 this option will be
supported in configurations with MPC5200 rev B processors.
To actually "high boot", set jumper X30 on the STK52xx.
Patch by Martin Krause, 12 Jul 2006
- Support for TQM5200S (short version without graphic controller)
- Support for modules with 'N' type S29GL128N Spansion flashes
(requires changes to flash layout)
- Support for MPC5200B cpu (mostly support for second SDRAM bank)
The TB5200 ("Tinybox") is a small baseboard for the TQM5200 module
integrated in a little aluminium case.
Patch by Martin Krause, 8 Jun 2006
Some code cleanup
Patch by Martin Krause, 11 Jan 2006
Make the automatic CS configuration the default.
The dedicated configurations CONFIG_TQM5200_AA, CONFIG_TQM5200_AB
and CONFIG_TQM5200_AC are removed.
"TQM5200_config" is now the default for STK52XX.200 base boards.
On a STK52XX.100 base board "TQM5200_STK100_config" must be used.
Patch by Martin Krause, 07 Nov 2005
Pointed out by Gerhard Jaeger, 31 Aug 2005;
cf. http://sourceware.org/ml/binutils/2005-08/msg00412.html
- Sound commands (beep, wav, sound)
- Test commands (led, can, backlight, rs232)
Patch by Martin Krause, 02 May 2005
Patch by Martin Krause, 8 Apr. 2005
Minor coding style cleanup.
- use TQM5200_auto as MAKEALL target for TQM5200 systems
- add support for SM501 graphics controller
- add support for graphic console on TQM5200
- add support for TQM5200 Rev 200
- cleanup, fix typo in include/configs/TQM5200.h
- add support for "STK52xx" board (including PS/2 multiplexer)
- add hardware detection for TQM5200
* Patch by Mark Jonas, 05 Jul 2004:
add support for the Total5100's and Total5200's LCD screen
* Patches by Dan Eisenhut, 01 Jul 2004:
- README fixes.
- Move doc2000.h include to prevent compiler warning on some boards
Add support for TQM5200 board
* Patch by Martin Krause, 29 Jun 2004:
Add loopw command: infinite write loop on address range
