We need a TLB entry to call get_ram_size(); the common code doesn't create
one until *after* fixed_sdram() has determined the size. So we set up tlbs
for the max possible size and tear them down once we're done with
get_ram_size(); the common 85xx code will then set up a final set of tlb
entries for the *actual* detected size of ddr.
This prevents us from having TLB entries that are larger than DDR sitting
around for very long, which is not a recommended scenario.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
A large number of boards incorrectly used getenv() in their board init
code running before relocation. In some cases this caused U-Boot to
hang when certain environment variables grew too long.
Fix the code to use getenv_r().
Cc: Stefan Roese <sr@denx.de>
Cc: The LEOX team <team@leox.org>
Cc: Michael Schwingen <michael@schwingen.org>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Werner Pfister <Pfister_Werner@intercontrol.de>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Peter De Schrijver <p2@mind.be>
Cc: John Zhan <zhanz@sinovee.com>
Cc: Rishi Bhattacharya <rishi@ti.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
8xx was left behind when fixing up powerpc linking
scripts to support -fpic.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
This patch exposes more registers which can be used by the DDR drivers or
interactive debugging. U-boot doesn't use all the registers in DDRC.
When advanced tuning is required, writing to those registers is needed.
Add writing to cdr1, cdr2, err_disable, err_int_en and debug registers
Add options to override rcw, address parity to RDIMMs.
Use array for debug registers.
Signed-off-by: York Sun <yorksun@freescale.com>
Remove duplicated code in TQM 85xx boards and utilize the common
fsl_pcie_init_board().
CC: wd@denx.de
Correct initdram to use phys_size_t to represent the size of
dram; instead of changing this all over the place, and correcting
all the other random errors I've noticed, create a
common initdram that is used by all non-corenet 85xx parts. Most
of the initdram() functions were identical, with 2 common differences:
1) DDR tlbs for the fixed_sdram case were set up in initdram() on
some boards, and were part of the tlb_table on others. I have
changed them all over to the initdram() method - we shouldn't
be accessing dram before this point so they don't need to be
done sooner, and this seems cleaner.
2) Parts that require the DDR11 erratum workaround had different
implementations - I have adopted the version from the Freescale
errata document. It also looks like some of the versions were
buggy, and, depending on timing, could have resulted in the
DDR controller being disabled. This seems bad.
The xpedite boards had a common/fsl_8xxx_ddr.c; with this
change only the 517 board uses this so I have moved the ddr code
into that board's directory in xpedite517x.c
Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Also, change this code to use phys_size_t instead of long int.
Using common naming for this function will enable us to use the common
initdram() for 85xx going forward. Other than the type change,
this is just a code rearrange.
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can
replace the is_fsl_pci_cfg() code with the is_serdes_configured().
The include/miiphy.h header duplicates a lot of things from linux/mii.h.
So punt all the things that overlap to keep the API simple and to make
merging between U-Boot and Linux simpler.
Commit 98e6956 "mpc52xx: add support for tqm52xx based board charon"
caused build warnings on some systems. Fix these.
- serial console in PSC1
- 128MiB DRAM
- 32MiB Flash
- FEC Ethernet
- 2 I2C busses
- FPGA on CS3
- IDE
- VGA SMI501
Recent cleanup actions resulted in a number of config.mk files that
contained only redundant entries like
PLATFORM_CPPFLAGS += -I$(TOPDIR)
or settings of variables that were not used anywhere in the code, like
TEXT_END = 0xfe080000
Remove these unnecessary files.
Cc: Scott McNutt <smcnutt@psyent.com>
Cc: Wolfgang Wegner <w.wegner@astro-kom.de>
Cc: Josef Wagner <Wagner@Microsys.de>
Cc: Tolunay Orkun <torkun@nextio.com>
Cc: Frank Panno <fpanno@delphintech.com>
Cc: Brad Kemp <Brad.Kemp@seranoa.com>
Acked-by: Heiko Schocher<hs@denx.de>
Fix warnings:
cam5200_flash.c: In function 'write_word_32':
cam5200_flash.c:443: warning: dereferencing type-punned pointer will break strict-aliasing rules
cam5200_flash.c: In function 'write_word_16':
cam5200_flash.c:684: warning: dereferencing type-punned pointer will break strict-aliasing rules
Before this commit, weak symbols were not overridden by non-weak symbols
found in archive libraries when linking with recent versions of
binutils. As stated in the System V ABI, "the link editor does not
extract archive members to resolve undefined weak symbols".
This commit changes all Makefiles to use partial linking (ld -r) instead
of creating library archives, which forces all symbols to participate in
linking, allowing non-weak symbols to override weak symbols as intended.
This approach is also used by Linux, from which the gmake function
cmd_link_o_target (defined in config.mk and used in all Makefiles) is
inspired.
The name of each former library archive is preserved except for
extensions which change from ".a" to ".o". This commit updates
references accordingly where needed, in particular in some linker
scripts.
This commit reveals board configurations that exclude some features but
include source files that depend these disabled features in the build,
resulting in undefined symbols. Known such cases include:
- disabling CMD_NET but not CMD_NFS;
- enabling CONFIG_OF_LIBFDT but not CONFIG_QE.
Signed-off-by: Sebastien Carlier <sebastien.carlier@gmail.com>
Previously boards used a variety of indentations, newline styles, and
colon styles for the PCI information that is printed on bootup. This
patch unifies the style to look like:
NAND: 1024 MiB
PCIE1: connected as Root Complex
Scanning PCI bus 01
04 01 8086 1010 0200 00
03 00 10b5 8112 0604 00
02 01 10b5 8518 0604 00
02 02 10b5 8518 0604 00
08 00 1957 0040 0b20 00
07 00 10b5 8518 0604 00
09 00 10b5 8112 0604 00
07 01 10b5 8518 0604 00
07 02 10b5 8518 0604 00
06 00 10b5 8518 0604 00
02 03 10b5 8518 0604 00
01 00 10b5 8518 0604 00
PCIE1: Bus 00 - 0b
PCIE2: connected as Root Complex
Scanning PCI bus 0d
0d 00 1957 0040 0b20 00
PCIE2: Bus 0c - 0d
In: serial
CC: wd@denx.de
CC: sr@denx.de
CC: galak@kernel.crashing.org
The size of the other bank needed to be added to the br0 setting;
this got dropped in the LBC cleanup.
Tested-by: Wolfgang Denk <wd@denx.de>
Acked-by: Wolfgang Denk <wd@denx.de>
Update to use the recent, common FSL PCI initialization code.
CC: sr@denx.de
After the recent cleanups, a number of config.mk files consist only of
a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed.
Remove such entries. In most cases, that means that the whole
config.mk file can be removed.
Clean up Makefile, and drop a lot of the config.mk files on the way.
We now also automatically pick all boards that are listed in
boards.cfg (and with all configurations), so we can drop the redundant
entries from MAKEALL to avoid building these twice.
The change is currently needed to be able to remove the board
configuration scripting from the top level Makefile and replace it by
a simple, table driven script.
Moving this configuration setting into the "CONFIG_*" name space is
also desirable because it is needed if we ever should move forward to
a Kconfig driven configuration system.
include/ppc4xx.h
This change lays the groundwork for the BOOTFLAG_* flags being removed.
This change has the small affect of delaying 100ms on PCI initialization
after a warm boot as opposed to the optimal 1ms on some boards.
included the mpc8308_p1m board.
- Revives POST for blackfin arch;
- Removes redundant code:
arch/blackfin/lib/post.c
arch/powerpc/cpu/ppc4xx/commproc.c
arch/powerpc/cpu/mpc512x/common.c
- fixes up the post_word_{load|store} usage.
Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com>
Acked-by: Detlev Zundel <dzu@denx.de>
Tested-by: Anatolij Gustschin <agust@denx.de>
List of the maintainers of the affected by patch boards:
Cc: Stephan Linz <linz@li-pro.net>
Cc: Denis Peter <d.peter@mpl.ch>
Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Cc: Niklaus Giger <niklaus.giger@netstal.com>
Cc: Larry Johnson <lrj@acm.org>
Cc: Feng Kan <fkan@amcc.com>
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By
moving these optional variables and defines into the common code, board
specific code is minimized. Currently only the following board use
this feature:
APC405, IDS8247, TQM834x
And IDS8247 doesn't seem to really need this feature, since its not
updating the bank number variable at all. So this patch removes the
definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port.
This new framework will be used by the upcoming lwmon5 update as well.
Acked-by: Heiko Schocher <hs@denx.de>
Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
Recent changes caused that the HMI10 board now is included in the
boards built by MAKEALL, which revealed that compilation for this
board has been broken for a long time:
ps2ser.c: In function 'ps2ser_init':
ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function)
ps2ser.c:155: error: (Each undeclared identifier is reported only once
ps2ser.c:155: error: for each function it appears in.)
ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function)
ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function)
ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function)
ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function)
ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function)
ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function)
ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_putc':
ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_getc_hw':
ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function)
ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function)
ps2ser.c: In function 'ps2ser_interrupt':
ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function)
The board is orphaned, and AFAICT has reached EOL.
Drop support for it.
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names
with spaces drop a
Warning: eth device name has a space!
message. This patch fix it for:
- "FEC ETHERNET" devices found on
mpc512x, mpc5xxx, mpc8xx and mpc8220 boards.
renamed to "FEC".
- "SCC ETHERNET" devices found on
mpc8xx, mpc82xx based boards. Renamed to "SCC".
- "HDLC ETHERNET" devices found on mpc8xx boards
Renamed to "HDLC"
- "FCC ETHERNET" devices found on mpc8260 and mpc85xx based
boards. Renamed to "FCC"
Tested on the kup4k board.
While running from flash, i. e. before relocation, we have only a
limited C runtime environment without writable data segment. In this
phase, some configurations (for example with environment in EEPROM)
must not use the normal getenv(), but a special function. This
function had been called getenv_r(), with the idea that the "_r"
suffix would mean the same as in the _r_eentrant versions of some of
the C library functions (for example getdate vs. getdate_r, getgrent
vs. getgrent_r, etc.).
Unfortunately this was a misleading name, as in U-Boot the "_r"
generally means "running from RAM", i. e. _after_ relocation.
To avoid confusion, rename into getenv_f() [as "running from flash"]
Lots of code use this construct:
cmd_usage(cmdtp);
return 1;
Change cmd_usage() let it return 1 - then we can replace all these
ocurrances by
return cmd_usage(cmdtp);
This fixes a few places with incorrect return code handling, too.
Previously we used an alias the pci node to determine which node to
fixup or delete. Now we use the new fdt_node_offset_by_compat_reg to
find the node to update.
Additionally, we replace the code in each board with a single macro call
that makes assumes uniform naming and reduces duplication in this area.
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code
dedicated to defining and manipulating the LBC registers. Merge
this into a single spot.
To do this, we have to decide on a common name for the data structure
that holds the lbc registers - it will now be known as fsl_lbc_t, and we
adopt a common name for the immap layouts that include the lbc - this was
previously known as either im_lbc or lbus; use the former.
In addition, create accessors for the BR/OR regs that use in/out_be32
and use those instead of the mismash of access methods currently in play.
I have done a successful ppc build all and tested a board or two from
each processor family.
Acked-by: Kim Phillips <kim.phillips@freescale.com>
The hush shell dynamically allocates (and re-allocates) memory for the
argument strings in the "char *argv[]" argument vector passed to
commands. Any code that modifies these pointers will cause serious
corruption of the malloc data structures and crash U-Boot, so make
sure the compiler can check that no such modifications are being done
by changing the code into "char * const argv[]".
This modification is the result of debugging a strange crash caused
after adding a new command, which used the following argument
processing code which has been working perfectly fine in all Unix
systems since version 6 - but not so in U-Boot:
int main (int argc, char **argv)
while (--argc > 0 && **++argv == '-') {
/* ====> */ while (*++*argv) {
switch (**argv) {
case 'd':
debug++;
break;
default:
usage ();
The line marked "====>" will corrupt the malloc data structures and
usually cause U-Boot to crash when the next command gets executed by
the shell. With the modification, the compiler will prevent this with
an
error: increment of read-only location '*argv'
N.B.: The code above can be trivially rewritten like this:
char *arg = *argv;
while (*++arg) {
switch (*arg) {
As discussed on the list, move "arch/ppc" to "arch/powerpc" to
better match the Linux directory structure.
Please note that this patch also changes the "ppc" target in
MAKEALL to "powerpc" to match this new infrastructure. But "ppc"
is kept as an alias for now, to not break compatibility with
scripts using this name.
The appropriate include/asm-$ARCH directory should already by symlinked
to include/asm so using the whole "asm-$ARCH" path is unnecessary.
This change should also allow us to move the include/asm-$ARCH
directories into their appropriate lib/$ARCH/ directories.
Now that the other architecture-specific lib directories have been
moved out of the top-level directory there's not much reason to have the
'_generic' suffix on the common lib directory.
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk
This change is intended to clean up the top-level directory structure
and more closely mimic Linux's directory organization.
We do not support a processor that never reached a real customer.
Signed-off-by: Detlev Zundel <dzu@denx.de>
Also use hwconfig to configure whether the board has a FEC or not.
We then can adjust the DTS to tell Linux if there is a FEC present.
syntax:
hwconfig=fec:on if hardware has a FEC
hwconfig=fec:off if hardware has no FEC
When referring to PCIe and USB 'endpoint' is the standard naming
convention.
Acked-by: Remy Bohmer <linux@bohmer.net>
We can use fsl_setup_hose to determine if we are a agent/end-point or
a host. Rather than using some SoC specific register we can just look
at the PCI cfg space of the host controller to determine this.
u-boot updates, before starting Linux, the memory node in the
DTS. As this is a "standard" feature, move this functionality
to the cpu.c file for mpc5xxx and mpc512x processors.
This fixes the code and the comment according to the original intent of
doing an intensive memory test when PSC6_3 is pulled low on the STK52xx.
Notably PORT_CONFIG will be overridden with this correct code now,
so beware.
The original code only worked by coincidence depending on the PORT_CONFIG
setting from the header file. The new code was tested to ensure that the
(undocumented) memory test still works on the STK52x.
CC: Martin Krause <Martin.Krause@tqs.de>
Minor white-space cleanup.
The following changes allow U-Boot to fully relocate from flash to
RAM:
- Remove linker scripts' .fixup sections from the .text section
- Add -mrelocatable to PLATFORM_RELFLAGS for all boards
- Define CONFIG_RELOC_FIXUP_WORKS for all boards
Previously, U-Boot would partially relocate, but statically initialized
pointers needed to be manually relocated.
Refactor the code into a simple bitmask lookup table that determines if
a given PCI controller is enabled and if its in host/root-complex or
agent/end-point mode.
Each processor in the PQ3/MPC86xx family specified different encodings
for the cfg_host_agt[] and cfg_IO_ports[] boot strapping signals.
-fno-strict-aliasing is hidding warnings.
There are really no differences between all the 85xx linker scripts so
we can just move to a single common one. Board code is still able to
override the common one if need be.
