path: root/board/tqc
2019-05-21mpc83xx: Get rid of CONFIG_SYS_DDR_BASEMario Six
CONFIG_SYS_DDR_BASE is specific to mpc83xx an is always set to the same value as CONFIG_SYS_SDRAM_BASE. Just use CONFIG_SYS_SDRAM_BASE instead. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21tqm834x: Expand CONFIG_SYS_OR_TIMING_FLASH macroMario Six
We want to normalize all BR/OR config lines as much as possible. The TQM834x board uses CONFIG_SYS_OR_TIMING_FLASH in a OR definition, which we want to remove. But CONFIG_SYS_OR_TIMING_FLASH is also used outside of the config file. Replace these usages with the definition of the variable, so we can remove the variable in the next patch. Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-05-21mpc83xx: Get rid of CONFIG_83XX_CLKINMario Six
MPC83xx uses CONFIG_83XX_CLKIN instead of CONFIG_SYS_CLK_FREQ to set the system clock. To migrate the architecture, we can replace CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ. To do this * replace all occurrences of CONFIG_83XX_CLKIN with CONFIG_SYS_CLK_FREQ * set CONFIG_SYS_CLK_FREQ to the old value of CONFIG_83XX_CLKIN in all MPC83xx config files Signed-off-by: Mario Six <mario.six@gdsys.cc>
2019-03-25tqma6s_wru4_mmc: manage board_spi_cs_gpio correctlyPatrick Delaunay
Define the function board_spi_cs_gpio only when needed, only called in drivers/spi/mxc_spi.c. That avoid compilation issue for tqma6s_wru4_mmc_defconfig when CONFIG_SF_DEFAULT_BUS and CONFIG_SF_DEFAULT_CS are not defined (CMD_SF not defined) after migration in KConfig. Signed-off-by: Patrick Delaunay <patrick.delaunay@st.com>
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2018-03-05libfdt: move headers to <linux/libfdt.h> and <linux/libfdt_env.h>Masahiro Yamada
Thomas reported U-Boot failed to build host tools if libfdt-devel package is installed because tools include libfdt headers from /usr/include/ instead of using internal ones. This commit moves the header code: include/libfdt.h -> include/linux/libfdt.h include/libfdt_env.h -> include/linux/libfdt_env.h and replaces include directives: #include <libfdt.h> -> #include <linux/libfdt.h> #include <libfdt_env.h> -> #include <linux/libfdt_env.h> Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com> Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
Change is consistent with other SOCs and it is in preparation for adding SOMs. SOC's related files are moved from cpu/ to mach-imx/<SOC>. This change is also coherent with the structure in kernel. Signed-off-by: Stefano Babic <sbabic@denx.de> CC: Fabio Estevam <fabio.estevam@nxp.com> CC: Akshay Bhat <akshaybhat@timesys.com> CC: Ken Lin <Ken.Lin@advantech.com.tw> CC: Marek Vasut <marek.vasut@gmail.com> CC: Heiko Schocher <hs@denx.de> CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com> CC: Christian Gmeiner <christian.gmeiner@gmail.com> CC: Stefan Roese <sr@denx.de> CC: Patrick Bruenn <p.bruenn@beckhoff.com> CC: Troy Kisky <troy.kisky@boundarydevices.com> CC: Nikita Kiryanov <nikita@compulab.co.il> CC: Otavio Salvador <otavio@ossystems.com.br> CC: "Eric Bénard" <eric@eukrea.com> CC: Jagan Teki <jagan@amarulasolutions.com> CC: Ye Li <ye.li@nxp.com> CC: Peng Fan <peng.fan@nxp.com> CC: Adrian Alonso <adrian.alonso@nxp.com> CC: Alison Wang <b18965@freescale.com> CC: Tim Harvey <tharvey@gateworks.com> CC: Martin Donnelly <martin.donnelly@ge.com> CC: Marcin Niestroj <m.niestroj@grinn-global.com> CC: Lukasz Majewski <lukma@denx.de> CC: Adam Ford <aford173@gmail.com> CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr> CC: Boris Brezillon <boris.brezillon@free-electrons.com> CC: Soeren Moch <smoch@web.de> CC: Richard Hu <richard.hu@technexion.com> CC: Wig Cheng <wig.cheng@technexion.com> CC: Vanessa Maegima <vanessa.maegima@nxp.com> CC: Max Krummenacher <max.krummenacher@toradex.com> CC: Stefan Agner <stefan.agner@toradex.com> CC: Markus Niebel <Markus.Niebel@tq-group.com> CC: Breno Lima <breno.lima@nxp.com> CC: Francesco Montefoschi <francesco.montefoschi@udoo.org> CC: Jaehoon Chung <jh80.chung@samsung.com> CC: Scott Wood <oss@buserror.net> CC: Joe Hershberger <joe.hershberger@ni.com> CC: Anatolij Gustschin <agust@denx.de> CC: Simon Glass <sjg@chromium.org> CC: "Andrew F. Davis" <afd@ti.com> CC: "Łukasz Majewski" <l.majewski@samsung.com> CC: Patrice Chotard <patrice.chotard@st.com> CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org> CC: Hans de Goede <hdegoede@redhat.com> CC: Masahiro Yamada <yamada.masahiro@socionext.com> CC: Stephen Warren <swarren@nvidia.com> CC: Andre Przywara <andre.przywara@arm.com> CC: "Álvaro Fernández Rojas" <noltari@gmail.com> CC: York Sun <york.sun@nxp.com> CC: Xiaoliang Yang <xiaoliang.yang@nxp.com> CC: Chen-Yu Tsai <wens@csie.org> CC: George McCollister <george.mccollister@gmail.com> CC: Sven Ebenfeld <sven.ebenfeld@gmail.com> CC: Filip Brozovic <fbrozovic@gmail.com> CC: Petr Kulhavy <brain@jikos.cz> CC: Eric Nelson <eric@nelint.com> CC: Bai Ping <ping.bai@nxp.com> CC: Anson Huang <Anson.Huang@nxp.com> CC: Sanchayan Maity <maitysanchayan@gmail.com> CC: Lokesh Vutla <lokeshvutla@ti.com> CC: Patrick Delaunay <patrick.delaunay@st.com> CC: Gary Bisson <gary.bisson@boundarydevices.com> CC: Alexander Graf <agraf@suse.de> CC: u-boot@lists.denx.de Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com> Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
2017-06-16powerpc, 5xxx, 512x: remove support for mpc5xxx and mpc512xHeiko Schocher
There was for long time no activity in the mpx5xxx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in mpc5xxx, so remove it. Signed-off-by: Heiko Schocher <hs@denx.de>
2017-06-16treewide: remove unneeded semicolonsMasahiro Yamada
2017-06-12powerpc, 8xx: remove support for 8xxHeiko Schocher
There was for long time no activity in the 8xx area. We need to go further and convert to Kconfig, but it turned out, nobody is interested anymore in 8xx, so remove it (with a heavy heart, knowing that I remove here the root of U-Boot). Signed-off-by: Heiko Schocher <hs@denx.de>
2017-05-22Kconfig: Add a CONFIG_IDE optionSimon Glass
At present IDE support is controlled by CONFIG_CMD_IDE. Add a separate CONFIG_IDE option so that IDE support can be enabled without requiring the 'ide' command. Update existing users and move the ide driver into drivers/block since it should not be in common/. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-05-15i2c: Drop use of CONFIG_I2C_HARDSimon Glass
This option is pretty old. It predates CONFIG_SYS_I2C which is itself deprecated in favour of driver model. Disable it for all boards. Also drop I2C options which depend on this. Signed-off-by: Simon Glass <sjg@chromium.org>
2017-04-13board_f: Rename initdram() to dram_init()Simon Glass
This allows us to use the same DRAM init function on all archs. Add a dummy function for arc, which does not use DRAM init here. Signed-off-by: Simon Glass <sjg@chromium.org> [trini: Dummy function on nios2] Signed-off-by: Tom Rini <trini@konsulko.com>
2017-04-05board_f: Drop return value from initdram()Simon Glass
At present we cannot use this function as an init sequence call without a wrapper, since it returns the RAM size. Adjust it to set the RAM size in global_data instead, and return 0 on success. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-04-05board_f: Drop board_type parameter from initdram()Simon Glass
It looks like only cm5200 and tqm8xx use this feature, so we don't really need it in generic code. Drop it and have the users access gd->board_type directly. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Stefan Roese <sr@denx.de>
2017-03-17arm: imx6: tqma6: add support for TQMa6DL variantMarkus Niebel
This adds support for TQMa6DL using i.MX6DL and 1GiB DRAM Since The module will use the same devicetree, we patch the ram size in ft_board_setup. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-03-17arm: imx6: tqma6: use CONFIG_TQM6x for SOM specific settingsMarkus Niebel
We have a Kconfig name for the module types. Let's Use it. Some feature selections and configurations are based on the module. Module selection selects the CPU type. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-03-17mx6: tqma6: clear enet clk sel for mba6Markus Niebel
we have external ref clock from phy. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-03-17imx6: tqma6: adjust ethernet phy reset delayMarkus Niebel
fix the reset delay which was to short Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-03-17imx6: tqma6: disable spi CS unused in U-BootMarkus Niebel
Since the CS are not in use, do not map them. User of starterkit mainboard is free to use them otherwise. When using these pins later in the OS for instance as GPIO IRQ pin, they need to be input. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-03-17imx6: tqma6: use lower driver stength for I2C pinsMarkus Niebel
The current driver stength is too high, leading to spec violations on the falling edge. Fix it with values from HW Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2017-03-17imx6: tqma6: implement power_init_boardMarkus Niebel
PMIC implements proper I2C bus switching, implement power_init_board instead handling in board_late_init. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2016-10-23video: Move video_get_info_str() prototype to a header fileSimon Glass
This should be defined in a header file so that arguments are checked. Move it to video.h. Signed-off-by: Simon Glass <sjg@chromium.org> Reviewed-by: Tom Rini <trini@konsulko.com>
2016-05-02Fix spelling of "occurred".Vagrant Cascadian
Signed-off-by: Vagrant Cascadian <vagrant@debian.org> Reviewed-by: Simon Glass <sjg@chromium.org>
2016-02-06Use correct spelling of "U-Boot"Bin Meng
Correct spelling of "U-Boot" shall be used in all written text (documentation, comments in source files etc.). Signed-off-by: Bin Meng <bmeng.cn@gmail.com> Reviewed-by: Heiko Schocher <hs@denx.de> Reviewed-by: Simon Glass <sjg@chromium.org> Reviewed-by: Minkyu Kang <mk7.kang@samsung.com>
2016-02-02tqma6_wru4: Fix the reset delay for the the LAN8720 PHYFabio Estevam
According to the LAN8720 datasheet tpurstd (time that reset line should stay asserted) is 25ms. So do as suggested by the LAN8720 datasheet. Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
2016-01-25powerpc: tqm834x: Fix build warnings in initdram()Bin Meng
With gcc 4.9, it produces the following warnings: CC board/tqc/tqm834x/tqm834x.o board/tqc/tqm834x/tqm834x.c: In function 'initdram': board/tqc/tqm834x/tqm834x.c:325:12: warning: iteration 3u invokes undefined behavior [-Waggressive-loop-optimizations] (((base + size - 1) >> CSBNDS_EA_SHIFT) & ^ board/tqc/tqm834x/tqm834x.c:80:2: note: containing loop for(cs = 0; cs < 4; ++cs) { ^ There is an integer overflow when cs = 3. To fix it, change parameters of set_cs_bounds() to ulong. Signed-off-by: Bin Meng <bmeng.cn@gmail.com>
2015-11-19Move console definitions into a new console.h fileSimon Glass
The console includes a global variable and several functions that are only used by a small subset of U-Boot files. Before adding more functions, move the definitions into their own header file. Signed-off-by: Simon Glass <sjg@chromium.org>
2015-11-10powerpc: Finish updating u-boot*lds scripts for newer binutilsTom Rini
In 522b021 we dropped 'PROVIDE(_GLOBAL_OFFSET_TABLE_ = . + 4)' lines in the mpc85xx linker scripts as this is not required and breaks newer binutils. This commit cleans up the rest of the powerpc linker scripts. Signed-off-by: Tom Rini <trini@konsulko.com>
2015-09-13tqma6_mba6: Fix the error handling in board_eth_init()Fabio Estevam
We should not return 0 on failure, so return a negative error code instead. Also centralize the error path so that is easier to follow. Cc: Markus Niebel <Markus.Niebel@tq-group.com> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-09-13mx6: remove SYS_SOC from board KconfigPeng Fan
Remove duplicated SYS_SOC Kconfig entry from board Kconfig, because we have this entry in arch/arm/cpu/armv7/mx6/Kconfig. Signed-off-by: Peng Fan <Peng.Fan@freescale.com> Cc: Stefano Babic <sbabic@denx.de> Cc: Heiko Schocher <hs@denx.de> Cc: Christian Gmeiner <christian.gmeiner@gmail.com> Cc: Stefan Roese <sr@denx.de> Cc: Troy Kisky <troy.kisky@boundarydevices.com> Cc: Nikita Kiryanov <nikita@compulab.co.il> Cc: "Eric Bénard" <eric@eukrea.com> Cc: Fabio Estevam <fabio.estevam@freescale.com> Cc: Tim Harvey <tharvey@gateworks.com> Cc: Marek Vasut <marex@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Otavio Salvador <otavio@ossystems.com.br> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Marek Vasut <marex@denx.de> Acked-by: Christian Gmeiner <christian.gmeiner@gmail.com> Acked-by: Markus Niebel <Markus.Niebel@tq-group.com> Acked-by: Troy Kisky <troy.kisky@boundarydevices.com> Acked-by: Igor Grinberg <grinberg@compulab.co.il>
2015-09-02arm: mx6: Remove SPI support from WRU-IV baseboardStefan Roese
This patch removes the SPI support from the WRU-IV baseboard as its not used at all. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Clemens Gruber <clemens.gruber@pqgruber.com> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de> Tested-by: Clemens Gruber <clemens.gruber@pqgruber.com> Reviewed-by: Jagan Teki <jteki@openedev.com>
2015-07-26arm: mx6: tqma6: Add WRU-IV baseboard for the TQMa6 SoMStefan Roese
This patch adds support for the "OHB System AG" baseboard with is equipped with the TQMa6S SoM. Signed-off-by: Stefan Roese <sr@denx.de> Cc: Markus Niebel <Markus.Niebel@tq-group.com> Cc: Stefano Babic <sbabic@denx.de>
2015-06-27arm: imx6: tqma6: implement KConfig baseboard selectionMarkus Niebel
this finally removes the need for extra settings in defconfig Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2015-06-27arm: imx6: tqma6: boot device selection via KconfigMarkus Niebel
2015-06-27arm: imx6: tqma6: implement IMX_CONFIG with KconfigMarkus Niebel
Now that we have the Kconfig based CPU type selection, use this to fill the IMX_CONFIG automatically Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2015-06-27arm: mx6: tqma6: CPU type selection via KconfigMarkus Niebel
This is the first patch to remove the CONFIG_SYS_EXTRA_OPTIONS. This patch implements CPU type selection from Kconfig. Further Kconfig stuff is added later. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2015-05-15arm: mx6: tqma6: Update to optionally configure an alternative SPI setupStefan Roese
By making the tqma6_iomuxc_spi() weak, this patch adds the possibility to add a different function for this SPI configuration. This can be used by other baseboards, that might have a different SPI setup. This patch will be used by the upcoming WRU-IV board support which also uses the TQMa6 SoM. Signed-off-by: Stefan Roese <sr@denx.de>
2015-03-17powerpc: mpc5xxx: remove aev, TB5200 board supportMasahiro Yamada
They have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2015-01-05mpc8xx: remove FPS{850, 860}L, NSCU, SM850, TK885D, virtlab2 supportMasahiro Yamada
These boards are still non-generic boards. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Cc: Wolfgang Denk <wd@denx.de>
2014-11-26Merge git://git.denx.de/u-boot-fdtTom Rini
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-11-20tqma6: use imx_ddr_sizeMarkus Niebel
2014-11-20tqma6: add warning on failed setup_i2cMarkus Niebel
setup_i2c has a return value. Use it to give feedback on error. Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2014-11-20tqma6: add missing includeMarkus Niebel
Add include needed to have prototype for board_spi_cs_gpio Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
2014-11-05Merge branch 'master' of git://www.denx.de/git/u-boot-imxTom Rini
2014-10-30tqma6: fix typo in header guard defineMarkus Niebel
