Commit 155fa9af95ac5be857a7327e7a968a296e60d4c8 changed the way
to define a GPIO line, which can be used to force CS high
across multiple transactions. In order to fix sf detection
change board code to make use of board_spi_cs_gpio(..).
Signed-off-by: Markus Niebel <Markus.Niebel@tq-group.com>
This commit introduces a Kconfig symbol for each ARM CPU:
CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136,
CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100.
Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected
for CPU_ARM1176 and CPU_V7.
For each target, the corresponding CPU is selected and the definition of
SYS_CPU in the corresponding Kconfig file is removed.
Also, it removes redundant "string" type in some Kconfig files.
Signed-off-by: Georges Savoundararadj <savoundg@gmail.com>
Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
This board is old and is using CONFIG_I2C_X, which is wrong.
Cc: Tom Rini <trini@ti.com>
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4
(patman: RunPipe() should not pipe stdout/stderr unless asked),
Patman spits lots of "Invalid MAINTAINERS address: '-'"
error messages for patches with global changes.
It takes too long for Patman to process them.
Anyway, "M: -" does not carry any important information.
Rather, it is just like a place holder in case of assigning
a new board maintainer. Let's comment out.
This commit can be reproduced by the following command:
find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/'
Now the types of CONFIG_SYS_{ARCH, CPU, SOC, VENDOR, BOARD, CONFIG_NAME}
are specified in arch/Kconfig.
We can delete the ones in arch and board Kconfig files.
This commit can be easily reproduced by the following command:
find . -name Kconfig -a ! -path ./arch/Kconfig | xargs sed -i -e '
/config[[:space:]]SYS_\(ARCH\|CPU\|SOC\|\VENDOR\|BOARD\|CONFIG_NAME\)/ {
N
s/\n[[:space:]]*string//
The QS Systems TQMa6 board support was added by commit cb07d74e
and lost by commit e82abaeb.
Commit e82abaeb merged the IMX branch based on pre-Kconfig
and the mainline based on post-Kconfig, simply deleting
the boards.cfg file. As a result, some boards added just before
the merge were lost.
This commit adds Kconfig, defconfig, MAINTAINERS for TQMa6 board
to work on the Kconfig infrastructure.
Cc: Markus Niebel <Markus.Niebel@tq-group.com>
resync ubi subsystem with linux:
commit 455c6fdbd219161bd09b1165f11699d6d73de11c
Author: Linus Torvalds <torvalds@linux-foundation.org>
Date: Sun Mar 30 20:40:15 2014 -0700
Linux 3.14
A nice side effect of this, is we introduce UBI Fastmap support
to U-Boot.
Cc: Sergey Lapin <slapin@ossfans.org>
Cc: Scott Wood <scottwood@freescale.com>
Cc: Joerg Krause <jkrause@posteo.de>
boards.cfg
It is redundant to use 'PFUZE100_PMIC' as the PMIC name because we already
know it is a PMIC.
Call it simply 'PFUZE100' instead.
Cc: Tim Harvey <tharvey@gateworks.com>
We have switched to Kconfig and the boards.cfg file is going to
be removed. We have to retrieve the board status and maintainers
information from it.
The MAINTAINERS format as in Linux Kernel would be nice
because we can crib the scripts/get_maintainer.pl script.
After some discussion, we chose to put a MAINTAINERS file under each
board directory, not the top-level one because we want to collect
relevant information for a board into a single place.
TODO:
Modify get_maintainer.pl to scan multiple MAINTAINERS files.
Suggested-by: Tom Rini <trini@ti.com>
This commit adds:
- arch/${ARCH}/Kconfig
provide a menu to select target boards
- board/${VENDOR}/${BOARD}/Kconfig or board/${BOARD}/Kconfig
set CONFIG macros to the appropriate values for each board
- configs/${TARGET_BOARD}_defconfig
default setting of each board
(This commit was automatically generated by a conversion script
based on boards.cfg)
In Linux Kernel, defconfig files are located under
arch/${ARCH}/configs/ directory.
It works in Linux Kernel since ARCH is always given from the
command line for cross compile.
But in U-Boot, ARCH is not given from the command line.
Which means we cannot know ARCH until the board configuration is done.
That is why all the "*_defconfig" files should be gathered into a
single directory ./configs/.
This patch adds the changes to boards.cfg and the board directory
under board/tqc.
TQMa6 is a family of modules based on Freescale i.MX6. It consists of
TQMa6Q (i.MX6 Quad), TQMa6D (i.MX6 Dual) featuring eMMC, and 1 GiB DDR3
TQMa6S (i.MX6 Solo) featuring eMMC and 512 MiB DDR3
The modules need a baseboard. Initially the MBa6x starterkit mainboard is
supported. To easy support for other mainboards the functionality is splitted
in one file for the module (tqma6.c) and one file for the baseboard (tqma6_
mba6).
The modules can be boot from eMMC (on USDHC3) and SPI flash.
The following features are supported:
- MMC: eMMC on module (on USDHC3) and SD-card (on MBa6x mainboard)
- Ethernet: RGMII using micrel KSZ9031 phy on MBa6x mainboard for TQMa6<x> module.
The phy needs special configurations for the pad skew registers to adjust for
the signal routing.
Also support for standard ethernet commands and uppdate via tftp.
- SPI: ECSPI1 with bootable serial flash on module and two additional
chip selects on MBa6x
- I2C: This patch adds support for the I2C busses on the TQMa6<x> modules (I2C3)
and MBa6x baseboards (I2C1). The LM75 temperature sensors on TQMa6<x> and MBa6x
are also configured.
- USB: high speed host 1 on MBa6x and support for USB storage
- PMIC: support for pfuze 100 on TQMa6<x>
Cc: Kim Phillips <kim.phillips@freescale.com>
Cc: York Sun <yorksun@freescale.com>
Cc: Stefan Roese <sr@denx.de>
This commit moves some drivers subdirectory entry
from the toplevel Makefile to drivers/Makefile
using Kbuild descending feature.
The sandburst-specific i2c drivers have been deleted, conflict was just
over the SPDX conversion.
board/sandburst/common/ppc440gx_i2c.c
board/sandburst/common/ppc440gx_i2c.h
[trini: Fixup common/cmd_io.c]
- added to soft_i2c driver new multibus/multiadpater support
- adapted all config files, which uses this driver
Cc: Stephen Warren <swarren@wwwdotorg.org>
Albert's rework of the linker scripts conflicted with Simon's making
everyone use __bss_end. We also had a minor conflict over
README.scrapyard being added to in mainline and enhanced in
u-boot-arm/master with proper formatting.
arch/arm/cpu/ixp/u-boot.lds
arch/arm/cpu/u-boot.lds
arch/arm/lib/Makefile
board/actux1/u-boot.lds
board/actux2/u-boot.lds
board/actux3/u-boot.lds
board/dvlhost/u-boot.lds
board/freescale/mx31ads/u-boot.lds
doc/README.scrapyard
include/configs/tegra-common.h
Build tested for all of ARM and run-time tested on am335x_evm.
Note this is a tree-wide change affecting multiple architectures.
At present we use __bss_start, but mostly __bss_end__. This seems
inconsistent and in a number of places __bss_end is used instead.
Change to use __bss_end for the BSS end symbol throughout U-Boot. This
makes it possible to use the asm-generic/sections.h file on all
archs.
Refactor linker-generated array code so that symbols
which were previously linker-generated are now compiler-
generated. This causes relocation records of type
R_ARM_ABS32 to become R_ARM_RELATIVE, which makes
code which uses LGA able to run before relocation as
well as after.
Note: this affects more than ARM targets, as linker-
lists span possibly all target architectures, notably
PowerPC.
arch/arm/cpu/arm926ejs/mxs/u-boot-spl.lds
arch/arm/cpu/arm926ejs/spear/u-boot-spl.lds
arch/arm/cpu/armv7/omap-common/u-boot-spl.lds
board/ait/cam_enc_4xx/u-boot-spl.lds
board/davinci/da8xxevm/u-boot-spl-da850evm.lds
board/davinci/da8xxevm/u-boot-spl-hawk.lds
board/vpac270/u-boot-spl.lds
Signed-off-by: Albert ARIBAUD <albert.u.boot@aribaud.net>
Once more, some of the previous changes caused the code to grow, which
causes errors like
u-boot.lds:80 cannot move location counter backwards (from 400082a4 to 40008000)
when building with some older tool chains (like ELDK 4.2).
Adjust the linker script to make fit again.
The command declaration now uses the new LG-array method to generate
list of commands. Thus the __u_boot_cmd section is now superseded and
redundant and therefore can be removed. Also, remove externed symbols
associated with this section from include/command.h .
Cc: Joe Hershberger <joe.hershberger@gmail.com>
Cc: Mike Frysinger <vapier@gentoo.org>
Add section for the linker-generated lists into all possible linker
files, so that everyone can easily use these lists. This is mostly
a mechanical adjustment.
Due to grown code sizes the TQM85xx boards don't build any more with
some older tool chains (like ELDK 4.2). As these boards have long
reached EOL it seems a waste of effort trying to fix them. The vendor
has agreed to drop support for them, too. So let's get rid of them.
cc: Kim Phillips <kim.phillips@freescale.com>
Some of the previous changes caused the code to grow, which causes
errors like
u-boot.lds:76 cannot move location counter backwards (from 4000828c to 40008000)
Also drop a few files referring to no longer / not yet supported
boards.
Cc: Prafulla Wadaskar <prafulla@marvell.com>
Cc: Andy Fleming <afleming@gmail.com>
Cc: Jason Jin <jason.jin@freescale.com>
Cc: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Acked-by: Daniel Schwierzeck <daniel.schwierzeck@googlemail.com>
Fix:
tqm8272.c: In function 'initdram':
tqm8272.c:462:14: warning: variable 'lsize' set but not used
[-Wunused-but-set-variable]
Fix:
cam5200_flash.c: In function 'flash_erase_32':
cam5200_flash.c:282:24: warning: variable 'l_sect' set but not used
cam5200_flash.c: In function 'flash_erase_16':
cam5200_flash.c:612:24: warning: variable 'l_sect' set but not used
Fix:
cmd_stk52xx.c: In function 'spi_transmit':
cmd_stk52xx.c:85:6: warning: variable 'dummy' set but not used
cmd_stk52xx.c: In function 'i2s_play_wave':
cmd_stk52xx.c:199:3: warning: dereferencing type-punned pointer will
break strict-aliasing rules [-Wstrict-aliasing]
tqm834x.c: In function 'initdram':
tqm834x.c:126: warning: format '%d' expects type 'int', but argument 3 has type
'long int'
tqm834x.c: In function 'set_cs_bounds':
tqm834x.c:336: warning: format '%08x' expects type 'unsigned int', but argument
2 has type 'long int'
3 has type 'long int'
tqm834x.c: In function 'set_cs_config':
tqm834x.c:354: warning: format '%08x' expects type 'unsigned int', but argument
The top level Makefile does not do any recursion into subdirs when
cleaning, so these clean/distclean targets in random arch/board dirs
never get used. Punt them all.
MAKEALL didn't report any errors related to this that I could see.
Commit "PPC: Cleanup tqm8xx_pcmcia.c" will clean up the PCMCIA code
to use I/O accessors instead of plain volatile pointer accesses.
This will result in about 300 byte bigger code. Fix custom linker
script to make room for this.
While we are at it, drop unmaintained u-boot.lds.debug linker script.
Cc: Marek Vasut <marek.vasut@gmail.com>
Tested-by: Wolfgang Denk <wd@denx.de>
Fix:
tqm834x.c:299: warning: passing argument 1 of 'get_ram_size' discards
qualifiers from pointer target type
Acked-by: Kumar Gala <galak@kernel.crashing.org>
We need a TLB entry to call get_ram_size(); the common code doesn't create
one until *after* fixed_sdram() has determined the size. So we set up tlbs
for the max possible size and tear them down once we're done with
get_ram_size(); the common 85xx code will then set up a final set of tlb
entries for the *actual* detected size of ddr.
This prevents us from having TLB entries that are larger than DDR sitting
around for very long, which is not a recommended scenario.
Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org>
A large number of boards incorrectly used getenv() in their board init
code running before relocation. In some cases this caused U-Boot to
hang when certain environment variables grew too long.
Fix the code to use getenv_r().
Cc: The LEOX team <team@leox.org>
Cc: Michael Schwingen <michael@schwingen.org>
Cc: Georg Schardt <schardt@team-ctech.de>
Cc: Werner Pfister <Pfister_Werner@intercontrol.de>
Cc: Dirk Eibach <eibach@gdsys.de>
Cc: Peter De Schrijver <p2@mind.be>
Cc: John Zhan <zhanz@sinovee.com>
Cc: Rishi Bhattacharya <rishi@ti.com>
Cc: Peter Tyser <ptyser@xes-inc.com>
8xx was left behind when fixing up powerpc linking
scripts to support -fpic.
Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
Currently, _end is used for end of BSS section. We want _end to mean
end of u-boot image, so we rename _end to __bss_end__ first.
Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
This patch exposes more registers which can be used by the DDR drivers or
interactive debugging. U-boot doesn't use all the registers in DDRC.
When advanced tuning is required, writing to those registers is needed.
Add writing to cdr1, cdr2, err_disable, err_int_en and debug registers
Add options to override rcw, address parity to RDIMMs.
Use array for debug registers.
Signed-off-by: York Sun <yorksun@freescale.com>
Remove duplicated code in TQM 85xx boards and utilize the common
fsl_pcie_init_board().
CC: wd@denx.de
Correct initdram to use phys_size_t to represent the size of
dram; instead of changing this all over the place, and correcting
all the other random errors I've noticed, create a
common initdram that is used by all non-corenet 85xx parts. Most
of the initdram() functions were identical, with 2 common differences:
1) DDR tlbs for the fixed_sdram case were set up in initdram() on
some boards, and were part of the tlb_table on others. I have
changed them all over to the initdram() method - we shouldn't
be accessing dram before this point so they don't need to be
done sooner, and this seems cleaner.
2) Parts that require the DDR11 erratum workaround had different
implementations - I have adopted the version from the Freescale
errata document. It also looks like some of the versions were
buggy, and, depending on timing, could have resulted in the
DDR controller being disabled. This seems bad.
The xpedite boards had a common/fsl_8xxx_ddr.c; with this
change only the 517 board uses this so I have moved the ddr code
into that board's directory in xpedite517x.c
Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com>
Also, change this code to use phys_size_t instead of long int.
Using common naming for this function will enable us to use the common
initdram() for 85xx going forward. Other than the type change,
this is just a code rearrange.
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can
replace the is_fsl_pci_cfg() code with the is_serdes_configured().
The include/miiphy.h header duplicates a lot of things from linux/mii.h.
So punt all the things that overlap to keep the API simple and to make
merging between U-Boot and Linux simpler.
Commit 98e6956 "mpc52xx: add support for tqm52xx based board charon"
caused build warnings on some systems. Fix these.
