path: root/board/tqc
2011-05-12Fix incorrect use of getenv() before relocationWolfgang Denk
A large number of boards incorrectly used getenv() in their board init code running before relocation. In some cases this caused U-Boot to hang when certain environment variables grew too long. Fix the code to use getenv_r(). Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Stefan Roese <sr@denx.de> Cc: The LEOX team <team@leox.org> Cc: Michael Schwingen <michael@schwingen.org> Cc: Georg Schardt <schardt@team-ctech.de> Cc: Werner Pfister <Pfister_Werner@intercontrol.de> Cc: Dirk Eibach <eibach@gdsys.de> Cc: Peter De Schrijver <p2@mind.be> Cc: John Zhan <zhanz@sinovee.com> Cc: Rishi Bhattacharya <rishi@ti.com> Cc: Peter Tyser <ptyser@xes-inc.com>
2011-04-20powerpc, 8xx: Fixup all 8xx u-boot.lds scriptsJoakim Tjernlund
8xx was left behind when fixing up powerpc linking scripts to support -fpic. Signed-off-by: Joakim Tjernlund <Joakim.Tjernlund@transmode.se>
2011-03-27rename _end to __bss_end__Po-Yu Chuang
Currently, _end is used for end of BSS section. We want _end to mean end of u-boot image, so we rename _end to __bss_end__ first. Signed-off-by: Po-Yu Chuang <ratbert@faraday-tech.com>
2011-01-19mpc85xx: Adding more registers and optionsYork Sun
This patch exposes more registers which can be used by the DDR drivers or interactive debugging. U-boot doesn't use all the registers in DDRC. When advanced tuning is required, writing to those registers is needed. Add writing to cdr1, cdr2, err_disable, err_int_en and debug registers Add options to override rcw, address parity to RDIMMs. Use array for debug registers. Signed-off-by: York Sun <yorksun@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/85xx: Rework TQM boards pci_init_board to use common FSL PCIe codeKumar Gala
Remove duplicated code in TQM 85xx boards and utilize the common fsl_pcie_init_board(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org> CC: wd@denx.de
2011-01-14mpc85xx boards: initdram() cleanup/bugfixBecky Bruce
Correct initdram to use phys_size_t to represent the size of dram; instead of changing this all over the place, and correcting all the other random errors I've noticed, create a common initdram that is used by all non-corenet 85xx parts. Most of the initdram() functions were identical, with 2 common differences: 1) DDR tlbs for the fixed_sdram case were set up in initdram() on some boards, and were part of the tlb_table on others. I have changed them all over to the initdram() method - we shouldn't be accessing dram before this point so they don't need to be done sooner, and this seems cleaner. 2) Parts that require the DDR11 erratum workaround had different implementations - I have adopted the version from the Freescale errata document. It also looks like some of the versions were buggy, and, depending on timing, could have resulted in the DDR controller being disabled. This seems bad. The xpedite boards had a common/fsl_8xxx_ddr.c; with this change only the 517 board uses this so I have moved the ddr code into that board's directory in xpedite517x.c Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Paul Gortmaker <paul.gortmaker@windriver.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14tqm85xx: create fixed_sdram() to do sdram setupBecky Bruce
Also, change this code to use phys_size_t instead of long int. Using common naming for this function will enable us to use the common initdram() for 85xx going forward. Other than the type change, this is just a code rearrange. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Stefan Roese <sr@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-14powerpc/8xxx: Replace is_fsl_pci_cfg with is_serdes_configuredKumar Gala
Now that we have serdes support for all 85xx/86xx/Pxxx chips we can replace the is_fsl_pci_cfg() code with the is_serdes_configured(). Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2011-01-09miiphy: convert to linux/mii.hMike Frysinger
The include/miiphy.h header duplicates a lot of things from linux/mii.h. So punt all the things that overlap to keep the API simple and to make merging between U-Boot and Linux simpler. Signed-off-by: Mike Frysinger <vapier@gentoo.org>
2011-01-09tqm5200.c: fix warning: 'edid_buf' defined but not usedWolfgang Denk
Commit 98e6956 "mpc52xx: add support for tqm52xx based board charon" caused build warnings on some systems. Fix these. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
2010-12-16mpc52xx: add support for tqm52xx based board charonHeiko Schocher
- serial console in PSC1 - 128MiB DRAM - 32MiB Flash - FEC Ethernet - 2 I2C busses - FPGA on CS3 - IDE - VGA SMI501 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-12-09Remove redundant config.mk filesWolfgang Denk
Recent cleanup actions resulted in a number of config.mk files that contained only redundant entries like PLATFORM_CPPFLAGS += -I$(TOPDIR) or settings of variables that were not used anywhere in the code, like TEXT_END = 0xfe080000 Remove these unnecessary files. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Scott McNutt <smcnutt@psyent.com> Cc: Wolfgang Wegner <w.wegner@astro-kom.de> Cc: Josef Wagner <Wagner@Microsys.de> Cc: Tolunay Orkun <torkun@nextio.com> Cc: Frank Panno <fpanno@delphintech.com> Cc: Heiko Schocher <hs@denx.de> Cc: Brad Kemp <Brad.Kemp@seranoa.com> Acked-by: Heiko Schocher<hs@denx.de>
2010-11-278xx: Cleanup for partial linking and --gc-sectionsWolfgang Denk
Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-11-26cam5200_niosflash: fix build warningsWolfgang Denk
Fix warnings: cam5200_flash.c: In function 'write_word_32': cam5200_flash.c:443: warning: dereferencing type-punned pointer will break strict-aliasing rules cam5200_flash.c: In function 'write_word_16': cam5200_flash.c:684: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-11-14fsl: Clean up printing of PCI boot infoPeter Tyser
Previously boards used a variety of indentations, newline styles, and colon styles for the PCI information that is printed on bootup. This patch unifies the style to look like: ... NAND: 1024 MiB PCIE1: connected as Root Complex Scanning PCI bus 01 04 01 8086 1010 0200 00 04 01 8086 1010 0200 00 03 00 10b5 8112 0604 00 02 01 10b5 8518 0604 00 02 02 10b5 8518 0604 00 08 00 1957 0040 0b20 00 07 00 10b5 8518 0604 00 09 00 10b5 8112 0604 00 07 01 10b5 8518 0604 00 07 02 10b5 8518 0604 00 06 00 10b5 8518 0604 00 02 03 10b5 8518 0604 00 01 00 10b5 8518 0604 00 PCIE1: Bus 00 - 0b PCIE2: connected as Root Complex Scanning PCI bus 0d 0d 00 1957 0040 0b20 00 PCIE2: Bus 0c - 0d In: serial ... Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: wd@denx.de CC: sr@denx.de CC: galak@kernel.crashing.org
2010-11-12TQM85xx: Fix bug introduced by 83xx/85xx/86xx: LBC register cleanupBecky Bruce
The size of the other bank needed to be added to the br0 setting; this got dropped in the LBC cleanup. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Tested-by: Wolfgang Denk <wd@denx.de> Acked-by: Wolfgang Denk <wd@denx.de> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-20tqm85xx: Update PCI codePeter Tyser
Update to use the recent, common FSL PCI initialization code. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> CC: sr@denx.de Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-28Merge branch 'next' of /home/wd/git/u-boot/nextWolfgang Denk
Conflicts: include/ppc4xx.h Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-2383xx: Remove warmboot parameter from PCI init functionsPeter Tyser
This change lays the groundwork for the BOOTFLAG_* flags being removed. This change has the small affect of delaying 100ms on PCI initialization after a warm boot as opposed to the optimal 1ms on some boards. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> included the mpc8308_p1m board. Signed-off-by: Kim Phillips <kim.phillips@freescale.com>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-09-21Merge branch 'next' of ../custodians into nextWolfgang Denk
2010-09-20cfi_flash: Simplify dynamic flash bank number detectionStefan Roese
This patch simplifies the use of CONFIG_SYS_MAX_FLASH_BANKS_DETECT. By moving these optional variables and defines into the common code, board specific code is minimized. Currently only the following board use this feature: APC405, IDS8247, TQM834x And IDS8247 doesn't seem to really need this feature, since its not updating the bank number variable at all. So this patch removes the definition of CONFIG_SYS_MAX_FLASH_BANKS_DETECT from this board port. This new framework will be used by the upcoming lwmon5 update as well. Signed-off-by: Stefan Roese <sr@denx.de> Acked-by: Heiko Schocher <hs@denx.de> Cc: Matthias Fuchs <matthias.fuchs@esd.eu>
2010-09-19Remove HMI10 board supportWolfgang Denk
Recent changes caused that the HMI10 board now is included in the boards built by MAKEALL, which revealed that compilation for this board has been broken for a long time: ps2ser.c: In function 'ps2ser_init': ps2ser.c:155: error: 'UART_LCR' undeclared (first use in this function) ps2ser.c:155: error: (Each undeclared identifier is reported only once ps2ser.c:155: error: for each function it appears in.) ps2ser.c:156: error: 'UART_DLL' undeclared (first use in this function) ps2ser.c:157: error: 'UART_DLM' undeclared (first use in this function) ps2ser.c:159: error: 'UART_IER' undeclared (first use in this function) ps2ser.c:160: error: 'UART_MCR' undeclared (first use in this function) ps2ser.c:161: error: 'UART_FCR' undeclared (first use in this function) ps2ser.c:162: error: 'UART_FCR_ENABLE_FIFO' undeclared (first use in this function) ps2ser.c:166: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_putc': ps2ser.c:198: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:200: error: 'UART_TX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_getc_hw': ps2ser.c:224: error: 'UART_LSR' undeclared (first use in this function) ps2ser.c:225: error: 'UART_RX' undeclared (first use in this function) ps2ser.c: In function 'ps2ser_interrupt': ps2ser.c:293: error: 'UART_IIR' undeclared (first use in this function) The board is orphaned, and AFAICT has reached EOL. Drop support for it. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-08-09net ppc: fix ethernet device names with spacesHeiko Schocher
since commit 1384f3bb8a4f9066805b70c1418eda78ecb73fdd ethernet names with spaces drop a Warning: eth device name has a space! message. This patch fix it for: - "FEC ETHERNET" devices found on mpc512x, mpc5xxx, mpc8xx and mpc8220 boards. renamed to "FEC". - "SCC ETHERNET" devices found on mpc8xx, mpc82xx based boards. Renamed to "SCC". - "HDLC ETHERNET" devices found on mpc8xx boards Renamed to "HDLC" - "FCC ETHERNET" devices found on mpc8260 and mpc85xx based boards. Renamed to "FCC" Tested on the kup4k board. Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2010-08-04Rename getenv_r() into getenv_f()Wolfgang Denk
While running from flash, i. e. before relocation, we have only a limited C runtime environment without writable data segment. In this phase, some configurations (for example with environment in EEPROM) must not use the normal getenv(), but a special function. This function had been called getenv_r(), with the idea that the "_r" suffix would mean the same as in the _r_eentrant versions of some of the C library functions (for example getdate vs. getdate_r, getgrent vs. getgrent_r, etc.). Unfortunately this was a misleading name, as in U-Boot the "_r" generally means "running from RAM", i. e. _after_ relocation. To avoid confusion, rename into getenv_f() [as "running from flash"] Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Detlev Zundel <dzu@denx.de>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-07-20powerpc/85xx & 86xx: Rework ft_fsl_pci_setup to not require aliasesKumar Gala
Previously we used an alias the pci node to determine which node to fixup or delete. Now we use the new fdt_node_offset_by_compat_reg to find the node to update. Additionally, we replace the code in each board with a single macro call that makes assumes uniform naming and reduces duplication in this area. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-07-1683xx/85xx/86xx: LBC register cleanupBecky Bruce
Currently, 83xx, 86xx, and 85xx have a lot of duplicated code dedicated to defining and manipulating the LBC registers. Merge this into a single spot. To do this, we have to decide on a common name for the data structure that holds the lbc registers - it will now be known as fsl_lbc_t, and we adopt a common name for the immap layouts that include the lbc - this was previously known as either im_lbc or lbus; use the former. In addition, create accessors for the BR/OR regs that use in/out_be32 and use those instead of the mismash of access methods currently in play. I have done a successful ppc build all and tested a board or two from each processor family. Signed-off-by: Becky Bruce <beckyb@kernel.crashing.org> Acked-by: Kim Phillips <kim.phillips@freescale.com> Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2010-04-13ppc: Move cpu/$CPU to arch/ppc/cpu/$CPUPeter Tyser
2010-04-13Replace "#include <asm-$ARCH/$FILE>" with "#include <asm/$FILE>"Peter Tyser
The appropriate include/asm-$ARCH directory should already by symlinked to include/asm so using the whole "asm-$ARCH" path is unnecessary. This change should also allow us to move the include/asm-$ARCH directories into their appropriate lib/$ARCH/ directories. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Rename lib_generic/ to lib/Peter Tyser
Now that the other architecture-specific lib directories have been moved out of the top-level directory there's not much reason to have the '_generic' suffix on the common lib directory. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-04-13Move lib_$ARCH directories to arch/$ARCH/libPeter Tyser
Also move lib_$ARCH/config.mk to arch/$ARCH/config.mk This change is intended to clean up the top-level directory structure and more closely mimic Linux's directory organization. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2010-03-12TQM8xx: add device tree support for TQM8xx based boards.Heiko Schocher
Also use hwconfig to configure whether the board has a FEC or not. We then can adjust the DTS to tell Linux if there is a FEC present. syntax: hwconfig=fec:on if hardware has a FEC hwconfig=fec:off if hardware has no FEC Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-01-17PCIe, USB: Replace 'end point' references with 'endpoint'Peter Tyser
When referring to PCIe and USB 'endpoint' is the standard naming convention. Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Acked-by: Stefan Roese <sr@denx.de> Acked-by: Remy Bohmer <linux@bohmer.net>
2010-01-05ppc/85xx: Move to using fsl_setup_hose on TQM 85xxKumar Gala
We can use fsl_setup_hose to determine if we are a agent/end-point or a host. Rather than using some SoC specific register we can just look at the PCI cfg space of the host controller to determine this. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-12-085xxx, fdt: move fdt_fixup_memory() to cpu.c fileHeiko Schocher
u-boot updates, before starting Linux, the memory node in the DTS. As this is a "standard" feature, move this functionality to the cpu.c file for mpc5xxx and mpc512x processors. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-09Merge branch 'reloc'Wolfgang Denk
2009-10-08tqm5200: Correct comment and code in post_hotkeys_pressed.Detlev Zundel
This fixes the code and the comment according to the original intent of doing an intensive memory test when PSC6_3 is pulled low on the STK52xx. Notably PORT_CONFIG will be overridden with this correct code now, so beware. The original code only worked by coincidence depending on the PORT_CONFIG setting from the header file. The new code was tested to ensure that the (undocumented) memory test still works on the STK52x. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Martin Krause <Martin.Krause@tqs.de> Minor white-space cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-10-03ppc: Enable full relocation to RAMPeter Tyser
The following changes allow U-Boot to fully relocate from flash to RAM: - Remove linker scripts' .fixup sections from the .text section - Add -mrelocatable to PLATFORM_RELFLAGS for all boards - Define CONFIG_RELOC_FIXUP_WORKS for all boards Previously, U-Boot would partially relocate, but statically initialized pointers needed to be manually relocated. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-09-08ppc/8xxx: Refactor code to determine if PCI is enabled & agent/hostKumar Gala
Refactor the code into a simple bitmask lookup table that determines if a given PCI controller is enabled and if its in host/root-complex or agent/end-point mode. Each processor in the PQ3/MPC86xx family specified different encodings for the cfg_host_agt[] and cfg_IO_ports[] boot strapping signals. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-09-04ppc: Remove -fno-strict-aliasingKumar Gala
-fno-strict-aliasing is hidding warnings. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-2885xx: Move to a common linker scriptKumar Gala
There are really no differences between all the 85xx linker scripts so we can just move to a single common one. Board code is still able to override the common one if need be. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-08-28pci/fsl_pci_init: Fold fsl_pci_setup_inbound_windows into fsl_pci_initKumar Gala
Every platform that calls fsl_pci_init calls fsl_pci_setup_inbound_windows before it calls fsl_pci_init. There isn't any reason to just call it from fsl_pci_init and simplify things a bit. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
