path: root/board/tqc
2008-11-02TQM8260: use CFI flash driver instead of custom driver.Wolfgang Denk
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-10-28Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2008-10-27lcd: Let the board code show board-specific infoHaavard Skinnemoen
The information displayed when CONFIG_LCD_INFO is set is inherently board-specific, so it should be done by the board code. The current code dealing with this only handles two cases, and is already a horrible mess of #ifdeffery. Yes, this duplicates some code, but it also allows boards to print more board-specific information; this used to be very difficult. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-10-2485xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS, MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-21TQM8260: environment in flash instead EEPROM, baudrate 115kWolfgang Denk
Several customers have reported problems with the environment in EEPROM, including corrupted content after board reset. Probably the code to prevent I2C Enge Conditions is not working sufficiently. We move the environment to flash now, which allows to have a backup copy plus gives much faster boot times. Also, change the default console initialization to 115200 bps as used on most other boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-17Coding style cleanup; update CHANEGLOGWolfgang Denk
2008-09-16TQM8xx: Fix CFI flash driver support for all TQM8xx based boardsWolfgang Denk
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten. Also, some boards were not adapted, and the old legacy flash driver was not removed yet. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-06TQM8272: move NAND part in seperate FileHeiko Schocher
I didn't try to use drivers/mtd/nand/fsl_upm.c for the NAND driver, because I have no longer access to the hardware. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-06TQM8272: Fix compiling error for the TQM8272 board.Heiko Schocher
Fix compile problems caused by commit cfa460adfdefcc30d104e1a9ee44994ee349bb7b Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NS8382X Ethernet controller to board_eth_init()Ben Warren
Affected boards: bc3450 cpci5200 mecp5200 pf2000 icecube o2dnt pm520 sandpoint8245 total5200 tqm5200 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-31TQM85xx: fix typo introduce by commit ffbb5cb9Wolfgang Denk
2008-07-20tqm85xx: Demystify 'DK: !!!' commentDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-06-28Coding Style CleanupWolfgang Denk
2008-06-11Merge branch 'master' of git://www.denx.de/git/u-boot-fdtWolfgang Denk
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-11TQM85xx: Change memory map to support Flash memory > 128 MiBWolfgang Grandegger
Some TQM85xx boards could be equipped with up to 1 GiB (NOR) Flash memory. The current memory map only supports up to 128 MiB Flash. This patch adds the configuration option CONFIG_TQM_BIGFLASH. If set, up to 1 GiB flash is supported. To achieve this, the memory map has to be adjusted in great parts (for example the CCSRBAR is moved from 0xE0000000 to 0xA0000000). If you want to boot Linux with CONFIG_TQM_BIGFLASH set, the new memory map also has to be considered in the kernel (changed CCSRBAR address, changed PCI IO base address, ...). Please use an appropriate Flat Device Tree blob (tqm8548.dtb). Signed-off-by: Martin Krause <martin.krause@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-11TQM85xx: NAND support via local bus UPMBWolfgang Grandegger
This patch adds support for NAND FLASH on the TQM8548. It is disabled by default and can be enabled for the TQM8548 modules. It is now based on the re-written FSL NAND UPM driver. A patch has been posted earlier today with the subject: "NAND FSL UPM: driver re-write using the hwcontrol callback" Note that the R/B pin is not supported by that module requiring to use the specified maximum delay time. Note: With NAND support enabled the size of the U-Boot image exceeds 256 KB and TEXT_BASE must therefore be set to 0xfff80000 in config.mk, doubling the image size :-(. Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-11TQM8548: PCI express supportWolfgang Grandegger
This patch adds support for PCI express cards. The board support now uses common FSL PCI init code, for both, PCI and PCIe on all TQM85xx modules. Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-11TQM8548: Basic support for the TQM8548 modulesWolfgang Grandegger
This patch adds basic support for the TQM8548 module from TQ-Components (http://www.tqc.de/) including DDR2 SDRAM initialisation and support for eTSEC 3 and 4 Furthermore Flash buffer write has been enabled to speed up output to the Flash by approx. a factor of 10. Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-11TQM85xx: Support for Flat Device TreeWolfgang Grandegger
This patch adds support for Linux kernels using the Flat Device Tree. It also re-defines the default environment settings for booting Linux with the FDT blob. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-10TQM85xx: Support for Intel 82527 compatible CAN controllerWolfgang Grandegger
This patch adds initialization of the UPMC RAM to support up to two Intel 82527 compatible CAN controller on the TQM85xx modules. Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-10TQM85xx: Bugfix in the SDRAM initialisationWolfgang Grandegger
The CS0_BNDS register is now set according to the detected memory size. Signed-off-by Martin Krause <martin.krause@tqs.de>
2008-06-10TQM85xx: Fix chip select configuration for second FLASH bankWolfgang Grandegger
This patch fixes the re-calculation of the automatic chip select configuration for boards with two populated FLASH banks. Signed-off-by: Martin Krause <martin.krause@tqs.de>
2008-06-10TQM85xx: Fix CPM port pin configurationWolfgang Grandegger
Do not configure port pins PD30/PD31 as SCC1 TxD/RxD except for the TQM8560 board. On the other TQM85xx boards (TQM8541 and TQM8555) SCC1 is not used as serial interface anyway. Worse, on some board variants configuring the pins for SCC1 leads to short circuits (for example on the TQM8541-BG). Signed-off-by: Martin Krause <martin.krause@tqs.de>
2008-06-10TQM85xx: Various coding style fixesWolfgang Grandegger
2008-06-10TQM: move TQM boards to board/tqcWolfgang Grandegger
Move all TQM board directories to the vendor specific directory "tqc" for modules from TQ-Components GmbH (http://www.tqc.de). Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
