path: root/board/tqc
2009-02-19TQM8xxL: make some room in low memory for future needsWolfgang Denk
THe TQM8xxL use a ahnd-optimized linker script to efficiently use the small boot sectors in the flash. This patch makes some room in the first sector to prepare for a size increase of lib_generic/vsprintf.o by a future patch. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-02-16TQM85xx: Fix a couple warnings in TQM8548 buildAndy Fleming
The ecm variable in sdram.c was being declared for all 8548, but only used by specific 8548 boards, so we make that variable require those specific boards, too The nand code was using an index "i" into a table, and then re-using "i" to set addresses for each upm. However, then it relied on the old value of i still being there to enable things. Changed the second "i" to "j" Signed-off-by: Andy Fleming <afleming@freescale.com>
2009-02-16MPC85xx: TQM8548: workaround for erratum DDR 19 and 20Wolfgang Grandegger
This patch adds the workaround for erratum DDR20 according to MPC8548 Device Errata document, Rev. 1: "CKE signal may not function correctly after assertion of HRESET". Furthermore, the bug DDR19 is fixed in processor version 2.1 and the work-around must be removed. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: use cache for AG and BE variantsWolfgang Grandegger
This patch makes accesses to the system memory cachable by removing the caching-inhibited and guarded flags from the relevant TLB entries for the TQM8548_BE and TQM8548_AG modules. FYI, the Freescale MPC85* boards are configured similarly. This results in a big averall performace improvement. TFTP downloads, NAND Flash accesses, kernel boots, etc. are much faster. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548_AG: add 1 GiB DDR2-SDRAM configurationWolfgang Grandegger
This patch add support for the 1 GiB DDR2-SDRAM on the TQM8548_AG module. Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: fix SDRAM timing for 533 MHzWolfgang Grandegger
According to new TQM8548 timing specification: Refresh Recovery: 34 -> 53 clocks CKE pulse width: 1 -> 3 cycles Window for four activities: 13 -> 14 cycles Signed-off-by: Jens Gehrlein <sew_s@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM8548: add support for the TQM8548_BE moduleWolfgang Grandegger
The TQM8548_BE is a variant of the TQM8548 module with NAND and CAN interface. With NAND support, the image is significantly larger and TEXT_BASE is adjusted accordingly. U-Boot can be built for this module with "$ make TQM8548_BE_config". Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM85xx: make standard PCI/PCI-X configurableWolfgang Grandegger
The TQM8548_AG module does not have the standard PCI/PCI-X interface connected but just the PCI Express interface . So far it was not possible to disable it without disabling the complete PCI interface (CONFIG_PCI) including PCI Express. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-16MPC85xx: TQM85xx: fix flash protection for boot loaderWolfgang Grandegger
As the reset vector is located at 0xfffffffc, all flash sectors from the beginning of the U-Boot binary to 0xffffffff must be protected. On the TQM8548-AG having small sectors at the end of the flash it happened that the last two sector were not protected and an "erase all" left an un-bootable system behind: Bank # 2: CFI conformant FLASH (32 x 16) Size: 32 MB in 270 Sectors AMD Standard command set, Manufacturer ID: 0xEC, Device ID: 0x257E Erase timeout: 8192 ms, write timeout: 1 ms FFFA0000 E RO FFFC0000 RO FFFE0000 RO FFFE4000 RO FFFE8000 RO FFFEC000 RO FFFF0000 RO FFFF4000 RO FFFF8000 E FFFFC000 The same bug seems to be in drivers/mtd/cfi_flash.c:flash_init() and many board BSPs as well. Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2009-02-07pci: Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY for clarityKumar Gala
The PCI_REGION_MEMORY and PCI_REGION_MEM are a bit to similar and can be confusing when reading the code. Rename PCI_REGION_MEMORY to PCI_REGION_SYS_MEMORY to clarify its used for system memory mapping purposes. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-12-19mpc8xxx: LCRR[CLKDIV] is sometimes five bitsTrent Piepho
On newer CPUs, 8536, 8572, and 8610, the CLKDIV field of LCRR is five bits instead of four. In order to avoid an ifdef, LCRR_CLKDIV is set to 0x1f on all systems. It should be safe as the fifth bit was defined as reserved and set to 0. Code that was using a hard coded 0x0f is changed to use LCRR_CLKDIV. Signed-off-by: Trent Piepho <tpiepho@freescale.com> Acked-by: Kumar Gala <galak@kernel.crashing.org> Acked-by: Jon Loeliger <jdl@freescale.com>
2008-12-06Update U-Boot's build timestamp on every compilePeter Tyser
Use the GNU 'date' command to auto-generate a new U-Boot timestamp on every compile. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2008-12-06lwmon, tqm8xx: Fix build errorsAnatolij Gustschin
Commit 6b59e03e0237a40a2305ea385defdfd92000978b lcd: Let the board code show board-specific info introduced some bugs which prevent U-Boot building for lwmon board if CONFIG_LCD_INFO_BELOW_LOGO will be defined in the board configuration. Also "LCD enabled" building for TQM823L doesn't work since this commit. This patch fixes above-mentioned issues. Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-12-0485xx: Add PORDEVSR_PCI1 definePeter Tyser
Add define used to determine if PCI1 interface is in PCI or PCIX mode. Convert users of the old PORDEVSR_PCI constant to use MPC85xx_PORDEVSR_PCI1 Signed-off-by: Peter Tyser <ptyser@xes-inc.com> Signed-off-by: Andy Fleming <afleming@freescale.com>
2008-11-02TQM8260: use CFI flash driver instead of custom driver.Wolfgang Denk
2008-11-02Coding Style cleanup, update CHANGELOGWolfgang Denk
2008-10-28Merge branch 'master' of git://git.denx.de/u-boot-videoWolfgang Denk
2008-10-27lcd: Let the board code show board-specific infoHaavard Skinnemoen
The information displayed when CONFIG_LCD_INFO is set is inherently board-specific, so it should be done by the board code. The current code dealing with this only handles two cases, and is already a horrible mess of #ifdeffery. Yes, this duplicates some code, but it also allows boards to print more board-specific information; this used to be very difficult. Signed-off-by: Haavard Skinnemoen <haavard.skinnemoen@atmel.com> Signed-off-by: Anatolij Gustschin <agust@denx.de>
2008-10-2485xx: Convert all fsl_pci_init users to new APIsKumar Gala
Converted ATUM8548, MPC8536DS, MPC8544DS, MPC8548CDS, MPC8568MDS, MPC8572DS, TQM85xx, and SBC8548 to use fsl_pci_setup_inbound_windows() and ft_fsl_pci_setup(). With these changes the board code is a bit smaller and we get dma-ranges set in the device tree for these boards. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andrew Fleming-AFLEMING <afleming@freescale.com>
2008-10-21TQM8260: environment in flash instead EEPROM, baudrate 115kWolfgang Denk
Several customers have reported problems with the environment in EEPROM, including corrupted content after board reset. Probably the code to prevent I2C Enge Conditions is not working sufficiently. We move the environment to flash now, which allows to have a backup copy plus gives much faster boot times. Also, change the default console initialization to 115200 bps as used on most other boards. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-10-21Cleanup: fix "MHz" spellingWolfgang Denk
2008-09-17Coding style cleanup; update CHANEGLOGWolfgang Denk
2008-09-16TQM8xx: Fix CFI flash driver support for all TQM8xx based boardsWolfgang Denk
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten. Also, some boards were not adapted, and the old legacy flash driver was not removed yet. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-09-10cleanup use of CFG_ENV_IS_IN_FLASHJean-Christophe PLAGNIOL-VILLARD
- #if CFG_ENV_IS_IN_FLASH - #if (CFG_ENV_IS_IN_FLASH == 1) - #define CFG_ENV_IS_IN_FLASH 0 Signed-off-by: Jean-Christophe PLAGNIOL-VILLARD <plagnioj@jcrosoft.com>
2008-09-06TQM8272: move NAND part in seperate FileHeiko Schocher
I didn't try to use drivers/mtd/nand/fsl_upm.c for the NAND driver, because I have no longer access to the hardware. Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-06TQM8272: Fix compiling error for the TQM8272 board.Heiko Schocher
Fix compile problems caused by commit cfa460adfdefcc30d104e1a9ee44994ee349bb7b Signed-off-by: Heiko Schocher <hs@denx.de>
2008-09-02Moved initialization of EEPRO100 Ethernet controller to board_eth_init()Ben Warren
Affected boards: db64360 db64460 katmai taihu taishan yucca cpc45 cpu87 eXalion elppc debris kvme080 mpc8315erdb integratorap ixdp425 oxc pm826 pm828 pm854 pm856 ppmc7xx sc3 sc520_spunk sorcery tqm8272 tqm85xx utx8245 Removed initialization of the driver from net/eth.c Also, wrapped contents of pci_eth_init() by CONFIG_PCI. Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NS8382X Ethernet controller to board_eth_init()Ben Warren
Affected boards: bc3450 cpci5200 mecp5200 pf2000 icecube o2dnt pm520 sandpoint8245 total5200 tqm5200 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-08-12Fixing coding style issuesWilliam Juul
- Fixing leading white spaces - Fixing indentation where 4 spaces are used instead of tab - Removing C++ comments (//), wherever I introduced them Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-08-12Update MTD to that of Linux 2.6.22.1William Juul
A lot changed in the Linux MTD code, since it was last ported from Linux to U-Boot. This patch takes U-Boot NAND support to the level of Linux 2.6.22.1 and will enable support for very large NAND devices (4KB pages) and ease the compatibility between U-Boot and Linux filesystems. This patch is tested on two custom boards with PPC and ARM processors running YAFFS in U-Boot and Linux using gcc-4.1.2 cross compilers. MAKEALL ppc/arm has some issues: * DOC/OneNand/nand_spl is not building (I have not tried porting these parts, and since I do not have any HW and I am not familiar with this code/HW I think its best left to someone else.) Except for the issues mentioned above, I have ported all drivers necessary to run MAKEALL ppc/arm without errors and warnings. Many drivers were trivial to port, but some were not so trivial. The following drivers must be examined carefully and maybe rewritten to some degree: cpu/ppc4xx/ndfc.c cpu/arm926ejs/davinci/nand.c board/delta/nand.c board/zylonite/nand.c Signed-off-by: William Juul <william.juul@tandberg.com> Signed-off-by: Stig Olsen <stig.olsen@tandberg.com> Signed-off-by: Scott Wood <scottwood@freescale.com>
2008-07-31TQM85xx: fix typo introduce by commit ffbb5cb9Wolfgang Denk
2008-07-20tqm85xx: Demystify 'DK: !!!' commentDetlev Zundel
Signed-off-by: Detlev Zundel <dzu@denx.de>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-06-28Coding Style CleanupWolfgang Denk
2008-06-11Merge branch 'master' of git://www.denx.de/git/u-boot-fdtWolfgang Denk
2008-06-1185xx/86xx: Move to dynamic mgmt of LAWsKumar Gala
With the new LAW interface (set_next_law) we can move to letting the system allocate which LAWs are used for what purpose. This makes life a bit easier going forward with the new DDR code. Signed-off-by: Kumar Gala <galak@kernel.crashing.org> Signed-off-by: Andy Fleming <afleming@freescale.com> Acked-by: Jon Loeliger <jdl@freescale.com> Acked-by: Becky Bruce <becky.bruce@freescale.com>
2008-06-11TQM85xx: Change memory map to support Flash memory > 128 MiBWolfgang Grandegger
Some TQM85xx boards could be equipped with up to 1 GiB (NOR) Flash memory. The current memory map only supports up to 128 MiB Flash. This patch adds the configuration option CONFIG_TQM_BIGFLASH. If set, up to 1 GiB flash is supported. To achieve this, the memory map has to be adjusted in great parts (for example the CCSRBAR is moved from 0xE0000000 to 0xA0000000). If you want to boot Linux with CONFIG_TQM_BIGFLASH set, the new memory map also has to be considered in the kernel (changed CCSRBAR address, changed PCI IO base address, ...). Please use an appropriate Flat Device Tree blob (tqm8548.dtb). Signed-off-by: Martin Krause <martin.krause@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
2008-06-11TQM85xx: NAND support via local bus UPMBWolfgang Grandegger
This patch adds support for NAND FLASH on the TQM8548. It is disabled by default and can be enabled for the TQM8548 modules. It is now based on the re-written FSL NAND UPM driver. A patch has been posted earlier today with the subject: "NAND FSL UPM: driver re-write using the hwcontrol callback" Note that the R/B pin is not supported by that module requiring to use the specified maximum delay time. Note: With NAND support enabled the size of the U-Boot image exceeds 256 KB and TEXT_BASE must therefore be set to 0xfff80000 in config.mk, doubling the image size :-(. Signed-off-by: Thomas Waehner <thomas.waehner@tqs.de> Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
