path: root/board/tqc/tqm8xx/Makefile
2008-09-16TQM8xx: Fix CFI flash driver support for all TQM8xx based boardsWolfgang Denk
After switching to using the CFI flash driver, the correct remapping of the flash banks was forgotten. Also, some boards were not adapted, and the old legacy flash driver was not removed yet. Signed-off-by: Wolfgang Denk <wd@denx.de>
2008-06-10TQM: move TQM boards to board/tqcWolfgang Grandegger
Move all TQM board directories to the vendor specific directory "tqc" for modules from TQ-Components GmbH (http://www.tqc.de). Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
