path: root/board/tqc/tqm5200
2015-03-17powerpc: mpc5xxx: remove aev, TB5200 board supportMasahiro Yamada
They have not been converted to Generic Board, so should be removed. (See doc/README.generic-board for details.) Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com>
2014-11-21fdt: Allow ft_board_setup() to report failureSimon Glass
This function can fail if the device tree runs out of space. Rather than silently booting with an incomplete device tree, allow the failure to be detected. Unfortunately this involves changing a lot of places in the code. I have not changed behvaiour to return an error where one is not currently returned, to avoid unexpected breakage. Eventually it would be nice to allow boards to register functions to be called to update the device tree. This would avoid all the many functions to do this. However it's not clear yet if this should be done using driver model or with a linker list. This work is left for later. Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Anatolij Gustschin <agust@denx.de>
2014-09-24MAINTAINERS: comment out blank M: fieldMasahiro Yamada
Since commit ddaf5c8f3030050fcd356a1e49e3ee8f8f52c6d4 (patman: RunPipe() should not pipe stdout/stderr unless asked), Patman spits lots of "Invalid MAINTAINERS address: '-'" error messages for patches with global changes. It takes too long for Patman to process them. Anyway, "M: -" does not carry any important information. Rather, it is just like a place holder in case of assigning a new board maintainer. Let's comment out. This commit can be reproduced by the following command: find . -name MAINTAINERS | xargs sed -i -e '/^M:[[:blank:]]*-$/s/^/#/' Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-25board: tqm5200: delete its own object make ruleMasahiro Yamada
2011-11-07board/tqc/tqm5200/cam5200_flash.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: cam5200_flash.c: In function 'flash_erase_32': cam5200_flash.c:282:24: warning: variable 'l_sect' set but not used [-Wunused-but-set-variable] cam5200_flash.c: In function 'flash_erase_16': cam5200_flash.c:612:24: warning: variable 'l_sect' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-11-07board/tqc/tqm5200/cmd_stk52xx.c: fix GC 4.6 build warningsWolfgang Denk
Fix: cmd_stk52xx.c: In function 'spi_transmit': cmd_stk52xx.c:85:6: warning: variable 'dummy' set but not used [-Wunused-but-set-variable] cmd_stk52xx.c: In function 'i2s_play_wave': cmd_stk52xx.c:199:3: warning: dereferencing type-punned pointer will break strict-aliasing rules [-Wstrict-aliasing] Signed-off-by: Wolfgang Denk <wd@denx.de>
2011-01-09tqm5200.c: fix warning: 'edid_buf' defined but not usedWolfgang Denk
Commit 98e6956 "mpc52xx: add support for tqm52xx based board charon" caused build warnings on some systems. Fix these. Signed-off-by: Wolfgang Denk <wd@denx.de> Cc: Heiko Schocher <hs@denx.de>
2010-12-16mpc52xx: add support for tqm52xx based board charonHeiko Schocher
- serial console in PSC1 - 128MiB DRAM - 32MiB Flash - FEC Ethernet - 2 I2C busses - FPGA on CS3 - IDE - VGA SMI501 Signed-off-by: Heiko Schocher <hs@denx.de> Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-26cam5200_niosflash: fix build warningsWolfgang Denk
Fix warnings: cam5200_flash.c: In function 'write_word_32': cam5200_flash.c:443: warning: dereferencing type-punned pointer will break strict-aliasing rules cam5200_flash.c: In function 'write_word_16': cam5200_flash.c:684: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2010-10-18config.mk cleanup: drop "-I$(TOPDIR)/board" entriesWolfgang Denk
After the recent cleanups, a number of config.mk files consist only of a "PLATFORM_CPPFLAGS += -I$(TOPDIR)/board" entry whih is not needed. Remove such entries. In most cases, that means that the whole config.mk file can be removed. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-09-21POST cleanup.Michael Zaidman
- Revives POST for blackfin arch; - Removes redundant code: arch/blackfin/lib/post.c arch/powerpc/cpu/ppc4xx/commproc.c arch/powerpc/cpu/mpc512x/common.c - fixes up the post_word_{load|store} usage. Signed-off-by: Michael Zaidman <michael.zaidman@gmail.com> Acked-by: Detlev Zundel <dzu@denx.de> Tested-by: Anatolij Gustschin <agust@denx.de> List of the maintainers of the affected by patch boards: Cc: Stephan Linz <linz@li-pro.net> Cc: Denis Peter <d.peter@mpl.ch> Cc: Matthias Fuchs <matthias.fuchs@esd-electronics.com> Cc: Peter Tyser <ptyser@xes-inc.com> Cc: Stefan Roese <sr@denx.de> Cc: Mike Frysinger <vapier@gentoo.org> Cc: Niklaus Giger <niklaus.giger@netstal.com> Cc: Larry Johnson <lrj@acm.org> Cc: Feng Kan <fkan@amcc.com>
2010-07-24cmd_usage(): simplify return code handlingWolfgang Denk
Lots of code use this construct: cmd_usage(cmdtp); return 1; Change cmd_usage() let it return 1 - then we can replace all these ocurrances by return cmd_usage(cmdtp); This fixes a few places with incorrect return code handling, too. Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-03-21mpc5xxx: Remove all references to MGT5100Detlev Zundel
We do not support a processor that never reached a real customer. Signed-off-by: Detlev Zundel <dzu@denx.de>
2009-12-085xxx, fdt: move fdt_fixup_memory() to cpu.c fileHeiko Schocher
u-boot updates, before starting Linux, the memory node in the DTS. As this is a "standard" feature, move this functionality to the cpu.c file for mpc5xxx and mpc512x processors. Signed-off-by: Heiko Schocher <hs@denx.de>
2009-10-08tqm5200: Correct comment and code in post_hotkeys_pressed.Detlev Zundel
This fixes the code and the comment according to the original intent of doing an intensive memory test when PSC6_3 is pulled low on the STK52xx. Notably PORT_CONFIG will be overridden with this correct code now, so beware. The original code only worked by coincidence depending on the PORT_CONFIG setting from the header file. The new code was tested to ensure that the (undocumented) memory test still works on the STK52x. Signed-off-by: Detlev Zundel <dzu@denx.de> CC: Martin Krause <Martin.Krause@tqs.de> Minor white-space cleanup. Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-09-04ppc: Remove -fno-strict-aliasingKumar Gala
-fno-strict-aliasing is hidding warnings. Signed-off-by: Kumar Gala <galak@kernel.crashing.org>
2009-06-12General help message cleanupWolfgang Denk
Many of the help messages were not really helpful; for example, many commands that take no arguments would not print a correct synopsis line, but "No additional help available." which is not exactly wrong, but not helpful either. Commit ``Make "usage" messages more helpful.'' changed this partially. But it also became clear that lots of "Usage" and "Help" messages (fields "usage" and "help" in struct cmd_tbl_s respective) were actually redundant. This patch cleans this up - for example: Before: => help dtt dtt - Digital Thermometer and Thermostat Usage: dtt - Read temperature from digital thermometer and thermostat. After: => help dtt dtt - Read temperature from Digital Thermometer and Thermostat Usage: dtt Signed-off-by: Wolfgang Denk <wd@denx.de>
2009-01-28Command usage cleanupPeter Tyser
Remove command name from all command "usage" fields and update common/command.c to display "name - usage" instead of just "usage". Also remove newlines from command usage fields. Signed-off-by: Peter Tyser <ptyser@xes-inc.com>
2009-01-28Standardize command usage messages with cmd_usage()Peter Tyser
2008-09-02Moved initialization of MPC5xxx_FEC Ethernet driver to CPU directoryBen Warren
Modified board_eth_init() functions of boards that have this FEC in addition to other Ethernet controllers. Affected boards: bc3450 icecube mvbc_p o2dnt pm520 total5200 tq5200 Removed initialization of controller from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-09-02Moved initialization of NS8382X Ethernet controller to board_eth_init()Ben Warren
Affected boards: bc3450 cpci5200 mecp5200 pf2000 icecube o2dnt pm520 sandpoint8245 total5200 tqm5200 Removed initialization of the driver from net/eth.c Signed-off-by: Ben Warren <biggerbadderben@gmail.com>
2008-07-14Code cleanup: fix old style assignment ambiguities like "=-" etc.Wolfgang Denk
2008-07-11Fix some more print() format errors.Wolfgang Denk
2008-06-10TQM: move TQM boards to board/tqcWolfgang Grandegger
Move all TQM board directories to the vendor specific directory "tqc" for modules from TQ-Components GmbH (http://www.tqc.de). Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
