path: root/board/tqc/tqm5200/cam5200_flash.c
2011-11-07board/tqc/tqm5200/cam5200_flash.c: Fix GCC 4.6 build warningWolfgang Denk
Fix: cam5200_flash.c: In function 'flash_erase_32': cam5200_flash.c:282:24: warning: variable 'l_sect' set but not used [-Wunused-but-set-variable] cam5200_flash.c: In function 'flash_erase_16': cam5200_flash.c:612:24: warning: variable 'l_sect' set but not used [-Wunused-but-set-variable] Signed-off-by: Wolfgang Denk <wd@denx.de>
2010-11-26cam5200_niosflash: fix build warningsWolfgang Denk
Fix warnings: cam5200_flash.c: In function 'write_word_32': cam5200_flash.c:443: warning: dereferencing type-punned pointer will break strict-aliasing rules cam5200_flash.c: In function 'write_word_16': cam5200_flash.c:684: warning: dereferencing type-punned pointer will break strict-aliasing rules Signed-off-by: Wolfgang Denk <wd@denx.de> Acked-by: Stefan Roese <sr@denx.de>
2008-06-10TQM: move TQM boards to board/tqcWolfgang Grandegger
Move all TQM board directories to the vendor specific directory "tqc" for modules from TQ-Components GmbH (http://www.tqc.de). Signed-off-by: Wolfgang Grandegger <wg@grandegger.com>
