path: root/board/tplink
2018-04-27Remove unnecessary instances of DECLARE_GLOBAL_DATA_PTRTom Rini
We have a large number of places where while we historically referenced gd in the code we no longer do, as well as cases where the code added that line "just in case" during development and never dropped it. Signed-off-by: Tom Rini <trini@konsulko.com>
2017-05-10MIPS: tl-wdr4300: remove debug_uart_init callÁlvaro Fernández Rojas
In order to add a generic MIPS debug_uart_init call right before the call to board_early_init_f, we need to remove all calls to debug_uart_init from every MIPS boards. WDR4300 doesn't provide a board_debug_uart_init and configures pinmux in board_early_init_f instead. Since I have no idead of what's the needed uart pinmux config, I copied the whole pinmux config to a new function that is called from board_early_init_f if CONFIG_DEBUG_UART_BOARD_INIT is not enabled. Signed-off-by: Álvaro Fernández Rojas <noltari@gmail.com>
2016-05-31MIPS: Split I & D cache line size configPaul Burton
Allow L1 Icache & L1 Dcache line size to be specified separately, since there's no architectural mandate that they be the same. The [id]cache_line_size functions are tidied up to take advantage of the fact that the Kconfig entries are always present to simply check them for zero rather than needing to #ifdef on their presence. Signed-off-by: Paul Burton <paul.burton@imgtec.com> [removed CONFIG_SYS_CACHELINE_SIZE in include/configs/pic32mzdask.h] Signed-off-by: Daniel Schwierzeck <daniel.schwierzeck@gmail.com>
2016-05-31MIPS: Move cache sizes to KconfigPaul Burton
Move details of the L1 cache line sizes & total sizes into Kconfig, defaulting to 0. A new CONFIG_SYS_CACHE_SIZE_AUTO Kconfig entry is introduced to allow platforms to select auto-detection of cache sizes, and it defaults to being enabled if none of the cache sizes are set by the configuration (ie. sizes are all the default 0), and code is adjusted to #ifdef on that rather than on the definition of the sizes (which will always be defined even if 0). Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-26MIPS: Move CONFIG_SYS_TEXT_BASE to KconfigPaul Burton
Move CONFIG_SYS_TEXT_BASE to Kconfig, and add default values in board Kconfig files matching what was present in their config headers. This will make it cleaner to conditionalise the value for Malta based on 32 vs 64 bit builds. Signed-off-by: Paul Burton <paul.burton@imgtec.com>
2016-05-21mips: ath79: Add support for TPLink WDR4300Marek Vasut
Add support for the TPLink WDR4300 router, which is based on the AR9344 MIPS 74Kc CPU and has 128 MiB of RAM. The USB is supported on this system as well. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Daniel Schwierzeck <daniel.schwierzeck@gmail.com> Cc: Wills Wang <wills.wang@live.com>
