This changes the define from VERDIN_IMX8MNSL to VERDIN_IMX8MNQ_WIFI_BT
in order to have a related naming to VERDIN_IMX8MMQ_WIFI_BT_IT and also
have the information in for wifi bluetooth.
This as well changes to the final decided naming.
Related-to: ELB-2642
1. Add support for these two modules:
Verdin iMX8M Nano SoloLite 1GB
Verdin iMX8M Mini DualLite 1GB
2. Rename VERDIN_IMX8MM define to VERDIN_IMX8MMQ_WIFI_BT_IT
Relates-to: ELB-2602
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
1. Enable CONFIG_SNVS_SEC_SC_AUTO by default
2. Move BOOTAUX_* defines to defconfig
Related-to: ELB-2605
1. MMC_UHS/HS_ enable in defconfig by default
2. VDD_DRAM/VDD_SOC changes in SPL
3. FEC anatop clock fixes
1. Adding power-up of base board via SCFW
2. Moved BOOTAUX defines to defconfig
Related-to: ELB-2316
Make sure recent version detection implementation is also used during
recovery mode.
And select the correct devicetree to load.
Related-to: ELB-1254
NXP common code now calls a board function mmc_map_to_kernel_blk().
Provide a weak function in common code for boards not requiring
special handling.
Taken from boards/freescale/common/mmc.c
Related-to: ELB-2351
This patch basically just enables both RXC and TXC delay lines in the
PHY. This will compensate the missing delay from the MAC. Other skew
settings are not needed as the traces on board are routed exactly the
same length
Related-to: ELB-1299
(cherry picked from commit 50e975e6ce4e4e88f8c5c943ef2ddc38b0a31997)
Set the Ethernet PHY's RGMII skew registers according to the needed
skew.
Related-to: ELB-1970
DDR calibration created with mscale_ddr_tool_v210_setup.exe using
MX8M_Mini_LPDDR4_RPA_v14 Verdin iMX8MM V1.0.xlsx as of 1. Nov. 2019.
This commit adds initial support for the Toradex Verdin iMX8MM 2GB WB IT
V1.0A module. They are now strapped to boot from eFuses which are
factory fused to properly boot from their on-module eMMC. U-Boot
supports either booting from the on-module eMMC or may be used for
recovery purpose using the universal update utility (uuu) aka mfgtools
3.0.
Functionality wise the following is known to be working:
- eMMC, 8-bit and 4-bit MMC/SD card slots
- Gigabit Ethernet
- GPIOs
- I2C
- USB_1 peripheral: fastboot or ums
- USB_2 host: USB mass storage
To prepare the program image for eMMC fastboot using imx-mkimage and
subsequently flash it using U-Boot proceed as follows:
cd imx-mkimage/
make SOC=iMX8MM flash_evk_emmc_fastboot
load mmc 1:1 $loadaddr flash.bin
setexpr blkcnt ${filesize} + 0x1ff && setexpr blkcnt ${blkcnt} / 0x200
mmc dev 0 1
mmc write ${loadaddr} 0x2 ${blkcnt}
To prepare the program image for use with USB recovery aka serial
downloader using imx-mkimage and subsequently download using uuu
with an uuu.auto script proceed as follows:
cd imx-mkimage/
uuu_version 1.3.34
SDP: boot -f flash.bin
CFG: SDPU: -vid 0x0525 -pid 0xb4a4
SDPU: delay 1000
SDPU: write -f flash.bin -offset 0x57c00
SDPU: jump
Fusing i.MX 8MM SoC and configuring eMMC for fastboot (already done
during manufacturing):
fuse prog 1 3 0x100020d6 (BT_FUSE_SEL, eMMC boot, SD1, fast boot, 4-bit DDR, high speed, 1.8V)
fuse prog 2 2 0x00000001 (enable boot ack)
mmc bootbus 0 1 0 2 (4-bit, reset bus width, DDR)
mmc partconf 0 1 1 0 (booting from boot area partition 1, send acknowledge)
SD manufaccture boot:
SD manufacture boot only works as long as the module is un-fused and
SD_1_PWR_EN is bypassed on the carrier board.
cd imx-mkimage/
sudo dd if=iMX8M/flash.bin of=/dev/mmcblk0 bs=1024 seek=33
Fix CONFIG_TARGET_COLIBRI_IMX8QXP vs. CONFIG_TARGET_COLIBRI_IMX8X
ifdefs.
Initial board support for Apalis iMX8QXP using a copy of Colibri iMX8QXP.
Toradex will use product-id 2600 upwards as id's for prototypes. This
commit adds this functionality to the config block.
The Apalis iMX8X is as well added in the same commit as it is the first
prototype and the first prodid in that range.
Make sure the config block information are passed to the kernel
using the device tree properties toradex,product-id, board-rev
and serial-number.
Signed-off-by: Ming Liu <liu.ming50@gmail.com>
Re-sync with mainline which fixes missing Apalis iMX8 and Colibri iMX8X
SKU and their interactive handling.
Improve QP vs. QM resp. DX vs. QXP detection based on core disable
fuses.
Implement proof of concept 1 GB resp. 2 GB vs. 2 GB resp. 4 GB DDR SKU
handling based on fuses indicating SoC being i.MX 8QP resp. 8DX vs. 8QM
resp. 8QXP. This overrides the newly introduced weak
board_mem_get_layout() function.
and serial-number.
These are now configured out of the device tree.
Clean-up board file.
Adjust copyright/licensing headers e.g. universally using SPDX license
identifier.
Fix Ethernet functionality. The FEC clock on i.MX 8X really has an
additional by 2 divider plus our design requires the ENET0_RCLK50M_OUT
on the ENET0_RGMII_TXC pin to be turned on for the Micrel PHY.
Fix USB device aka UMS as well as USB host functionality.
In wake of future PMIC silicon version changes, make sure complete PMIC
information is printed upon boot.
Clean-up board file synching with i.MX 8QuadXPlus MEK board one as
well.
identifier.
This also enables pullups on the uart forceoff pins.
The UART transceivers on an Iris carrier board can be disabled by
controlling SODIMM pins 102 and/or 104. Make sure that the pins by
default have pullups to have the debug UART working.
(cherry picked from commit eb0ed0e4283385700db1e5080d78f9a2684f98a5)
(cherry picked from commit 3a5cc1cf85b8e22da78d794a2d71c03490f500b6)
(cherry picked from commit cba518b4bbe4b9dfccb21ffe3cd0929c1a420719)
(cherry picked from commit 5721e405c34985f5faa1e6ff4e0d3ca32dffa6e5)
Note that this requires the SCFW in a version which provides access
to the PMIC I2C. Something which the regular SCFW should not do.
(cherry picked from commit 582a98a218dab6ac5a13ebd1cbd7a16e4b8305f3)
(cherry picked from commit 906059a7abf413bc165101812fb916743dd8eee7)
(cherry picked from commit 6557f1c6c8f5c5e6a5585459ab77e3d994ffff81)
(cherry picked from commit 6efbcb8cd6740e60fc53f9033d60cc27f62b3c74)
(cherry picked from commit 969f430f983d602afd83b6dd75b299e51463eae9)
(cherry picked from commit 2963361493e0f3df76f3a25202a56a76e69fd63f)
Initial board support for Colibri iMX8QXP using a copy of Apalis iMX8.
(cherry picked from commit 62f0f03e1acb4bb6b0fcca8d4e9bd4d2df04ad33)
(cherry picked from commit be14c3ea1850e2614883c86b62fd1c3a1828eac2)
(cherry picked from commit 200ed432e13e93c4c094031fe4d4481998227139)
(cherry picked from commit ba4474ab3cf4ff30ebcfa58b15b5f95746346d07)
Add support for interactive recovery of Apalis iMX8 QuadMax
config block.
(cherry picked from commit 70cf26d9f5edcb6de6b2b70f1bf6a821e46be3dd)
(cherry picked from commit afc3024a826e61dc0ecc5d55b8dea96544ca9487)
(cherry picked from commit b15393500e633a40319c5f8cf3ad02010f4acddd)
(cherry picked from commit 5ada977a2dd9240d2dd071468d310af79379abfd)
Add an optional -y parameter to 'cfgblock create’ to simplify
automation.
(cherry picked from commit d909b68d7f9da189a16e3ead0a6454b715201e23)
(cherry picked from commit ace5cf96413d3c736148dcecd1481e4249b7c5f1)
(cherry picked from commit 31091506e79e4924f47bc20b1830d6beef9bd1d7)
(cherry picked from commit 674ffe96fb6d9264f2e9019c8d26fce5fb3588e3)
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
board/toradex/common/configblock.c
(cherry picked from commit 0520b532d77d238be8015d3041a95188e47945cc)
(cherry picked from commit 3cb5f6450c39678a6361620bd45c423a503895cd)
(cherry picked from commit 79d3008acaebc0d33ba8fc21ffe46f058416d4a3)
board/toradex/common/tdx-cfg-block.c
(cherry picked from commit cdcc3a8660fa4254d6d3ca6932a7cd599c0f1662)
Add Toradex config block support for i.MX8QM.
(cherry picked from commit 18426b50681e6cd64ab5977f0ba84efd3f7c4495)
(cherry picked from commit c6d0e1042170d273a5b5434abe867213155d5582)
(cherry picked from commit ae31e946da33510a352795de09aa1c0ea9fc8280)
(cherry picked from commit 0798437c661ef3ca11f84fb45b4cce5b7ac145d9)
