This patch adds skew register settings for KSZ9131. It checks first
which phy is on the board and then applies the correct skew settings.
Skew settings calculation for the KSZ9131:
The i.MX6 SoC has an output skew tolerance of -100ps to 900ps. All
PCB traces where routed exactly the same length so we can calculate
the skew settings without taking the length into consideration.
RXC skew (PHY to MAC):
- We use the 2ns DLL controlled delay on the PHY
- We do not use the skew registers
This results in the following values:
RXC
PHY fixed Delay 2000ps
PHY Added Delay 0ps
T_setup_R min 2.00ns
T_setup_R typ 2.00ns
T_setup_R max 2.00ns
T_hold_R min 1.60ns
T_hold_R typ 2.00ns
T_hold_R max 2.40ns
That means we are well within RGMII specs.
TXC skew (MAC to PHY):
- We then substract ~0.6ns with TXD[0:3] and TXC clock pad skew
register in a resulting ~1.4ns delay.
This results in the following values under consideration of the
tolerances:
TXC min TXC typ TXC max
MAC min -100ps -100ps -100ps
MAC max 900ps 900ps 900ps
PHY fixed Delay 2000ps 2000ps 2000ps
PHY added Delay -340ps -600ps -859ps
T_setup_T min 1.56ns 1.30ns 1.04ns
T_setup_T typ 2.06ns 1.80ns 1.54ns
T_setup_T max 2.56ns 2.30ns 2.04ns
T_hold_T min 1.04ns 1.30ns 1.56ns
T_hold_T typ 1.94ns 2.20ns 2.46ns
T_hold_T max 2.84ns 3.10ns 3.36ns
This shows that T_hold_T min and T_setup_T min times are out of spec
for RGMII timing. However the KSZ9131 has a minimal value for this time
of 0.8ns which is met under all circumstances.
Related-to: ELB-1299
i.MX 7's Cortex-M4 core can run from DDR and uses DDR memory for
the rpmsg communication. Both use cases need a fixed location of
memory reserved. For the rpmsg use case the reserved area needs
to be in sync with the kernel's hardcoded vring descriptor location.
Use the linux,usable-memory property to carve out 1MB of memory
in case the M4 core is running. Also make sure that the i.MX 7
specific rpmsg driver does not get loaded in case we do not carve
out memory.
Signed-off-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
(cherry picked from commit c671d8af0bb07b028d808b994b83b2ec25578a44)
Introduce imx6ull-colibri-u-boot.dtsi for u-boot specific properties to
keep original imx6ull-colibri.dts in sync with Linux.
Move all contents of imx6ull-colibri.dts to imx6ull-colibri.dtsi +
additionally fix checkpatch warnings.
Reviewed-by: Fabio Estevam <festevam@gmail.com>
(cherry picked from commit 7d6ca12313377bad4ceafc3fa1da414d101f6b77)
Support the V1.2 hardware revision with the following pin muxing
changes:
Ddc_scl_pv4 and ddc_sda_pv5 previously used as Apalis GPIO3 and GPIO4
are now used as DDC pins.
Gen2_i2c_scl_pt5 and gen2_i2c_sda_pt6 previously used as DDC pins are
now used as USB power enable signals.
Usb_vbus_en0_pn4 and usb_vbus_en1_pn5 previously used as USB power
enable signals are now used as GPIO3 and GPIO4.
Additionally a new device tree file tegra124-apalis-v1.2-eval.dtb is
loaded on V1.2 and later modules and resp. USB power enable signals
activated.
Signed-off-by: Tom Warren <twarren@nvidia.com>
(cherry picked from commit 4c63a601b90db131e92d3f6f6da6a4bc2b287df1)
When mainline kernels reboot TK1 they use SW_RESET,
that reset mode does not reset PMIC. Some rails
need to be off for RAM Re-repair to work correctly.
(cherry picked from commit 5a20adf446bc248a8db02f6d262b43b14587812d)
Make sure the Apalis GPIO 8 aka FAN_EN is on when using Apalis TK1
modules.
(cherry picked from commit 538ab6c0a1a51da0caf9525607499e8cd6ef12b7)
By keeping RESET_MOCI_CTRL low we avoid explicitly releasing
RESET_MOCI#.
Please note that module hardware versions up to V1.1A will already
release RESET_MOCI# in hardware coming out of reset.
Please further note that with this change the USB hub on the Apalis
Evaluation board is kept in reset in U-Boot and therefore none of its
ports are operational in U-Boot.
(cherry picked from commit 5b5de78b4a6ff8c2bbd71a6b51d6fdf32f420eef)
Fix issue as reported by checkpatch.pl. Leave long lines as line
continuation in text output is not recommended.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
The Apalis iMX8 was missing the interactive part should a customer have
bricked his module and want to re-create the configuration block. Fix
this.
The Colibri iMX8X target got re-named late in the cycle which we forgot
to reflect here. Furthermore, it was missing the interactive part should
a customer have bricked his module and want to re-create the
configuration block. Fix this.
Make the interactive Wi-Fi/BT handling generic by pulling it out of the
Colibri iMX6ULL interactive part to be re-used for Apalis iMX8 and
Colibri iMX8X.
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
Extend the driver to build with DM_VIDEO enabled. DTS files
must additionally include 'u-boot,dm-pre-reloc' property in
soc and child nodes to enable driver binding to fsl_dcu_fb device.
Currently display timings aren't obtained from DT.
Move dcu-related code to fsl_dcu_probe_common, keep in video_hw_init()
only legacy video stack (filling GraphicPanel struct etc.).
Add wrappers for all init functions, that will let to provide
struct fb_info as an additional param (needed for further moving it from
the global scope to driver private data struct in DM converted driver).
This commit adds initial support for the Toradex Apalis iMX8QM 4GB WB IT
V1.0B module. Unlike the V1.0A early access samples exclusively booting
from SD card, they are now strapped to boot from eFuses which are
factory fused to properly boot from their on-module eMMC. U-Boot
supports either booting from the on-module eMMC or may be used for
recovery purpose using the universal update utility (uuu) aka mfgtools
3.0.
Functionality wise the following is known to be working:
- eMMC, 8-bit and 4-bit MMC/SD card slots
- Gigabit Ethernet
- GPIOs
- I2C
Unfortunately, there is no USB functionality for the i.MX 8QM as of yet.
Reviewed-by: Max Krummenacher <max.krummenacher@toradex.com>
Drop the ad-hoc AHCI binding code, this is superseded by
CONFIG_DWC_AHSATA_AHCI=y resp. drivers/ata/dwc_ahsata.c
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Cc: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Cc: Max Krummenacher <max.krummenacher@toradex.com>
Cc: Stefan Agner <stefan.agner@toradex.com>
This commit adds initial support for the Toradex Colibri iMX8QXP 2GB WB
IT V1.0B module. Unlike the V1.0A early access samples exclusively
booting from SD card, they are now strapped to boot from eFuses which
are factory fused to properly boot from their on-module eMMC. U-Boot
3.0.
- eMMC and MMC/SD card
- Ethernet
- GPIOs
- I2C
Unfortunately, there is no USB functionality for the i.MX 8QXP as of
yet.
Drop Toradex ARM Support <support.arm@toradex.com> from maintainer email
list as this just clogs our support ticketing system.
Add all the latest new SKUs:
- Apalis iMX8 QuadXPlus 2GB Wi-Fi / BT IT
- Apalis iMX8 QuadMax 4GB IT
- Apalis iMX8 QuadPlus 2GB Wi-Fi / BT
- Apalis iMX8 QuadPlus 2GB",
- Colibri iMX8 QuadXPlus 2GB IT
- Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth
Clean-up handling of several SKUs.
Migrate USB to using driver model.
Add USBH_PEN GPIO regulator.
While at it also add alias e.g. as required for UMS.
Migrate MMC to using driver model.
Migrate USDHC to using pinctrl.
While at it also add GPIO1_IO03__OSC32K_32K_OUT pin muxing.
While at it also update copyright period.
Migrate pinctrl and regulators to device tree resp. driver model:
Ethernet, NAND and UART.
Drop BOARD_EARLY_INIT_F as it is anyway no longer used.
Enable CMD_DM, CMD_MTD, CMD_REGULATOR and DM_REGULATOR_FIXED.
Disable output driver of PAD CCM_PMIC_STBY_REQ. This prevents the
SOC to request for a lower voltage during sleep. This is necessary
because the voltage is changing too slow for the SOC to wake up
properly.
Just give the new Ethernet PHY power save mode circuitry time to settle.
Using CPU temperature grading as a discriminator if the Wi-Fi /
Bluetooth chip is populated is no longer possible due to upcoming
SKUs. Set variant to -wifi only if a valid config block is present
and the product id mentions a SKU with Wi-Fi / Bluetooth.
Use CONFIG_TARGET_... at compile time to differentiate between
Apalis iMX6, Colibri iMX6 and Colibri iMX6ULL. Avoid code
duplication by moving question about Wi-Fi / Bluetooth before
IT/non-IT decision.
Add support for new Colibri iMX6ULL SKUs.
While at it also checkpatch fix the whole files.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Fix indentation using tab vs. spaces.
Fix toradex_modules array off by one issue potentially leading to
spurious printout during boot e.g.
Model: Toradex V1.2A,
instead of
Model: Toradex UNKNOWN MODULE V1.2A.
If the config block is missing, various things may fail or behave
strangely on certain modules. This patch unifies that behaviour by
using a fake MAC address, until user updates the config block.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add an optional -y parameter to 'cfgblock create’ to simplify
automation.
The DDR validation tool (which is part of Processor Expert) allows
to evaluate leveling parameters for CR105/CR106/CR110. Several
runs have been made with Colibri VF50 and VF61 and it seems to
evaluate very similar values. Use this values by default.
Note: The newly evaluated parameters seem to require CTLUPD_AREF
to be enabled!
Note 2: The tool also evaluated 6 as a new value for PHY02/18
GATE_CFG (Coarse adjust of gate open time). However, this seems
not to work in practise.
Using the DDR Validation tool in Processor Expert uncovered two
timing inconsistencies. Since those timings are related to the
suspend mode they do not affect or change regular memory behaviour.
Use similar info message as on other modules.
Migrate FEC, ESDHC, NFC and USB to driver model.
While at it also do no longer enable optional I2C clock in board file as
the generic clock code now handles this. Note for space reason and as
it is not required just for booting we do not enable I2C in U-Boot by
default.
Migrate pinctrl and regulators to device tree resp. driver model: DDR,
DSPI, ENET, ESDHC, I2C, NFC and UART.
Enable CMD_DM, PINCTRL and DM_REGULATOR.
While at it also update copyright period and sort include files.
Update device tree in preparation of further driver model migration:
Ethernet FEC, ESDHC aka MMC/SD card, I2C, NFC aka NAND flash controller,
Add iomux resp. pinctrl entries to be removed from proprietary platform
data: DSPI, ESDHC, FEC, I2C, NFC, UART, USBH_PEN GPIO.
Introduce a U-Boot specific device tree with some required
u-boot,dm-pre-reloc properties: soc, aips0, pinctrl_ddr and uart0 incl.
pinctrl.
While at it also update the MAINTAINERS file.
The PMIC on the Colibri iMX6 may have ECC errors in fuses that will
prevent correct settings. Up to one bit error per fuse bank can be
reported and corrected by the ECC logic. Two bit errors can only be
reported.
RGMII_RD1 pin (active high, GPIO6_IO27) is triggered on reboot during
the SPL phase. This asserts (active low) nReset_Out from the PMIC.
Only V1.1 and later Colibri iMX6 modules implement this in hw. Previous
versions do not use this pin, so it is safe to leave it enabled at all
times.
In case USB serial downloader has been used to load U-Boot start the
serial download protocol (SDP) emulation. This allows to download
complete images such as Toradex Easy Installer over USB SDP as well.
This code uses the boot ROM provided boot information to reliably
detect USB serial downloader.
Make sure CMA memory is not greater than 50% of available physical
memory.
Allow user to change the CMA memory via 'cma-size' U-Boot environment
variable.
We have two commands to change the bootmode fuses:
mfgr_fuse which set fuse 0/5 and 0/6
and
updt_fuse which burns bit 4 of 0/5.
Before Image 2.6 we fused in mfgr_fuse 0x5062, which boots
from the user partition of the eMMC.
To workaround certain hangs we moved to fastboot mode and
using the first bootpartition of the eMMC requiring a fuse
value of 0x5072 which could be achived by the then added
updt_fuse command. At the same time the mfgr_fuse command
was changed to also fuse 0x5072, revert that second change
so that one can fuse both values, one with just mfgr_fuse
and the later with mfgr_fuse;updt_fuse.
Note that the mfgr_fuse command is only needed at module
production time, a customer might need to use updt_fuse
when upgrading an older module to be compatible with a
newer image. The command is integrated into the image
update scripts.
Colibri iMX6 V1.1 HW can use the PMIC GEN3 to power the NVCC_SD1.
Change the settings fused into the PMIC's OTP to powerup with
GEN3 set to output 3.3V.
If the UART is used in DTE mode the RI and DCD bits in UCR3 become
irq enable bits. Both are set to enabled after reset and both likely
are pending.
Disable the bits also on UARTs not used in the boot loader to prevent
an interrupt storm when Linux enables the UART interrupts.
Keep debug code at the end of the function.
Use a one line informational message for the PMIC only.
In the linux device tree we use 40Ohm drive strenght. So use the same
value in U-Boot.
Print also for Colibri iMX6 512MB IT with 64-bit RAM bus.
This doesn't do anything anymore, probably never did.
