path: root/board/toradex
2015-10-15colibri_vf: Fix bstlen fieldFabio Estevam
Commit 3f353cecc ("vf610: refactor DDRMC code") changed the original bstlen field from 3 to 0. Restore the original value for proper behaviour. Based on the patch from Anthony Felice <tony.felice@timesys.com> for the vf610twr board. Reported-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Fabio Estevam <fabio.estevam@freescale.com>
2015-10-02vf610: refactor DDRMC codeAlbert ARIBAUD \\(3ADEV\\)
The VF610 DDRMC driver code contains settings which are board-specific. Move these out to boards so that new boards can define their own without having to modify the driver. Signed-off-by: Albert ARIBAUD (3ADEV) <albert.aribaud@3adev.fr>
2015-08-13colibri_t20: fix reset out pinMarcel Ziswiler
Make sure SODIMM pin 87 nRESET_OUT is released properly by explicitly setting its pin mux function to GMI. This solves some issues with e.g. USB not being fully operational on carrier boards with USB hubs connected to reset if U-Boot got loaded via recovery mode aka rcm. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13apalis/colibri_t20/30: clean-upMarcel Ziswiler
Various clean-ups either in comments, order or spacing without any functional impact: - Add some comments in the device trees resp. reorder some parameters for consistency across all our modules. - Sort some include files alphabetically (while leaving common.h on top of course). - Streamline some comments in the configuration files and fix the spacing from using spaces to tabs. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13colibri_t20: disable PMIC sleep mode on low supply voltageMarcel Ziswiler
The Colibri T20's PMIC enters a sleep mode on low supply voltage < 3.0V ±2.5% (2.92...3.08V). Rising the main supply voltage again does not bring it back to regular operation. Not even a full reset does bring the module back. A full power cycle was required to reboot the system. A long positive pulse on the PMICs resume pin also reboots the system but this pin is only accessible as a test point on the module. This patch configures the PMIC through I2C to not enter this sleep mode plus force it to normal state upon sleep request exit should this ever happen. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13colibri_t20: add lcd display supportMarcel Ziswiler
Add LCD display support defaulting to VESA VGA resolution. Different resolutions configurable via device tree. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Reviewed-by: Simon Glass <sjg@chromium.org> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-08-13apalis/colibri_t20/t30: integrate recovery mode detectionMarcel Ziswiler
Allow detecting whether or not U-Boot was launched through the recovery mode of the resp. NVIDIA SoC. Make use of a board specific arch_misc_init() and enable the same via CONFIG_ARCH_MISC_INIT configuration option. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-06-08colibri_vf: Enable board specific USB initialisation for USB pen gpioSanchayan Maity
Add IOMUX for the pad used as USB pen. This needs to be driven low for the Iris and Viola boards where it is pulled up high by default. This is required for the USB host functionality to work on these boards. Use the board specific weak initialisation function, to drive the pin low which would be called on "usb start". Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com>
2015-06-08colibri_vf: Add separate defconfig for device tree supportBhuvanchandra DV
Most of the drivers available for Vybrid are not yet converted to OF model to use device tree model, only few drivers like SPI and GPIO drivers use device trees. Add separate defconfig for who needs to use device tree model. Later this can be integrated to single defconfig. Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-06-08arm: vf610: Add iomux support for DSPIBhuvanchandra DV
Add iomux definitions for DSPI second instance. Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-06-08colibri_vf: Add pinmux entries for GPIOsBhuvanchandra DV
Inorder to use the pins as GPIO, apart from setting the alt-function, pinmuxing need to be done, this patch adds pinmux entries of few GPIOs. Acked-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
2015-05-13ARM: tegra: move NVIDIA common files to arch/arm/mach-tegraMasahiro Yamada
All the Tegra boards borrow the files from board/nvidia/common/ directory, i.e., board/nvidia/common/* are not vendor-common files, but SoC-common files. Move NVIDIA common files to arch/arm/mach-tegra/ to clean up Makefiles. As arch/arm/mach-tegra/board.c already exists, this commit renames board/nvidia/common/board.c to arch/arm/mach-tegra/board2.c, expecting they will be consolidated as a second step. Signed-off-by: Masahiro Yamada <yamada.masahiro@socionext.com> Acked-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Cc: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com> Cc: Simon Glass <sjg@chromium.org> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-04-23colibri_vf: Enable USB support for Colibri VybridSanchayan Maity
Enable USB support on Toradex Colibri Vybrid Modules. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Marek Vasut <marex@denx.de>
2015-04-23ARM: vf610: Initial integration for Colibri VF50/VF61Sanchayan Maity
This adds initial support for Colibri VF50/VF61 based on Freescale Vybrid SoC. - CPU clocked at 396/500 MHz - DDR3 at 396MHz - for VF50, use PLL2 as memory clock (synchronous mode) - for VF61, use PLL1 as memory clock (asynchronous mode) - Console on UART0 (Colibri UART_A) - Ethernet on FEC1 - PLL5 based RMII clocking (E.g. No external crystal) - UART_A and UART_C I/O muxing - Boot from NAND by default Tested on Colibri VF50/VF61 booting using serial loader over UART. Signed-off-by: Sanchayan Maity <maitysanchayan@gmail.com> Acked-by: Stefan Agner <stefan@agner.ch>
2015-03-30ARM: tegra: colibri_t20: fix nand pinmuxMarcel Ziswiler
Pingroup ATC seems to come out of reset with config set to NAND, so we need to explicitly configure some other function to this group in order to avoid clashing settings. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-30ARM: tegra: fix colibri_t20 asix resetMarcel Ziswiler
Fix ASIX USB to Ethernet chip reset. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-30ARM: tegra: rename colibri_t20 board/configuration/device-treeMarcel Ziswiler
In accordance with our other modules supported by U-Boot and as agreed upon for Apalis/Colibri T30 get rid of the carrier board in the board/ configuration/device-tree naming. While at it also bring the prompt more in line with our other products. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-30ARM: tegra: get rid of colibri_t20-commonMarcel Ziswiler
As a preparatory step to renaming the board folder as well first get rid of the colibri_t20-common after having integrated it into colibri_t20_iris for now. While at it also migrate to using NVIDIA's common.mk magic. Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2015-03-02pxa: fix wrong comment about vpac270 being the arch numberMarcel Ziswiler
2015-01-29dm: i2c: Provide an offset length parameter where neededSimon Glass
Rather than assuming that the chip offset length is 1, allow it to be provided. This allows chips that don't use the default offset length to be used (at present they are only supported by the command line 'i2c' command which sets the offset length explicitly). Signed-off-by: Simon Glass <sjg@chromium.org> Acked-by: Heiko Schocher <hs@denx.de>
2015-01-29dm: i2c: Rename driver model I2C functions to permit compatibilitySimon Glass
Add a dm_ prefix to driver model I2C functions so that we can keep the old ones around. This is a little unfortunate, but on reflection it is too difficult to change the API. We can undo this rename when most boards and drivers are converted to use driver model for I2C. Signed-off-by: Simon Glass <sjg@chromium.org>
2014-12-11dm: i2c: tegra: Convert to driver modelSimon Glass
This converts all Tegra boards over to use driver model for I2C. The driver is adjusted to use driver model and the following obsolete CONFIGs are removed: - CONFIG_SYS_I2C_INIT_BOARD - CONFIG_I2C_MULTI_BUS - CONFIG_SYS_MAX_I2C_BUS - CONFIG_SYS_I2C_SPEED - CONFIG_SYS_I2C This has been tested on: - trimslice (no I2C) - beaver - Jetson-TK1 It has not been tested on Tegra 114 as I don't have that board. Acked-by: Heiko Schocher <hs@denx.de> Signed-off-by: Simon Glass <sjg@chromium.org>
2014-10-29kconfig: arm: introduce symbol for ARM CPUsGeorges Savoundararadj
This commit introduces a Kconfig symbol for each ARM CPU: CPU_ARM720T, CPU_ARM920T, CPU_ARM926EJS, CPU_ARM946ES, CPU_ARM1136, CPU_ARM1176, CPU_V7, CPU_PXA, CPU_SA1100. Also, it adds the CPU feature Kconfig symbol HAS_VBAR which is selected for CPU_ARM1176 and CPU_V7. For each target, the corresponding CPU is selected and the definition of SYS_CPU in the corresponding Kconfig file is removed. Also, it removes redundant "string" type in some Kconfig files. Signed-off-by: Georges Savoundararadj <savoundg@gmail.com> Acked-by: Albert ARIBAUD <albert.u.boot@aribaud.net> Cc: Masahiro Yamada <yamada.m@jp.panasonic.com>
2014-10-22tegra: apalis_t30: master revampMarcel Ziswiler
Update Apalis T30 as per the following commits c369139234c03b1494394d12cd27009f47aa6606 tegra: dts: Add serial port details 461be2f96e4b87e5065208c6659a47dd0ad9e9f8 kconfig: remove redundant "string" type in arch and board Kconfigs f1ef2b62339526df3b921bcfefd174ce76d4c624 kconfig: move CONFIG_DEFAULT_DEVICE_TREE to kconfig Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-10-22tegra: colibri_t30: asix usb ethernet reset regressionMarcel Ziswiler
Fix ASIX USB to Ethernet reset which due to the new driver model Tegra GPIO driver changes now requires a label string to be provided otherwise the reservation and subsequent direction/value calls will fail. This fixes a regression introduced by commit: 2fccd2d96badcdf6165658a99771a4c475586279 tegra: Convert tegra GPIO driver to use driver model Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-10-22arm: tegra: initial support for apalis t30Marcel Ziswiler
This patch adds board support for the Toradex Apalis T30 a computer on module which can be used on different carrier boards. For the sake of ease of use we do not distinguish between different carrier boards for now as the base module features are deemed sufficient enough for regular booting. The following functionality is working so far: - eMMC boot and environment storage - Gigabit Ethernet (once Thierry's PCIe as well as my E1000 resp. i210 fixes hit mainline) - MMC/SD cards (both 8-bit as well as 4-bit slot) - USB client/host (dual role port as client e.g. for DFU/UMS, other two ports as host) Signed-off-by: Marcel Ziswiler <marcel@ziswiler.com> Acked-by: Stephen Warren <swarren@nvidia.com> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-08-30tegra: kconfig: move board select menu and common settingsMasahiro Yamada
Becuase the board select menu in arch/arm/Kconfig is too big, move the Tegra board select menu to tegra/Kconfig. Insert the Tegra SoC select menu between the arch select and the board select. Architecture select |-- Tegra Platform (Tegra) |- Tegra SoC select (Tegra20 / 30 / 114 / 124) |- Board select Consolidate also common settings (CONFIG_SYS_CPU="armv7" and CONFIG_SYS_SOC="tegra*") and always "select" CONFIG_SPL as follows: config TEGRA bool select SPL Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com> Acked-by: Stephen Warren <swarren@nvidia.com> Cc: Tom Warren <twarren@nvidia.com>
2014-08-18ARM: tegra: add Colibri T30 board supportStefan Agner
This adds board support for the Toradex Colibri T30 module. Working functions: - SD card boot - eMMC environment and boot - USB host/USB client (on the dual role port) - Network (via ASIX USB) Signed-off-by: Stefan Agner <stefan@agner.ch> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-04-17ARM: tegra: Tegra20 pinmux cleanupStephen Warren
This renames all the Tegra20 pinmux pins and functions so they have a prefix which matches the type name. The entries in tegra20_pingroups[] are all updated to remove the columns which are no longer used. All affected code is updated to match. Signed-off-by: Stephen Warren <swarren@nvidia.com> Acked-by: Simon Glass <sjg@chromium.org> Signed-off-by: Tom Warren <twarren@nvidia.com>
2014-02-19dts: move device tree sources to arch/$(ARCH)/dts/Masahiro Yamada
Unlike Linux Kernel, U-Boot historically had *.dts files under board/$(VENDOR)/dts/ and *.dtsi files under arch/$(ARCH)/dts/. I think arch/$(ARCH)/dts dicretory is a better location to store both *.dts and *.dtsi files. For example, before this commit, board/xilinx/dts directory had both Microblaze dts (microblaze-generic.dts) and ARM dts (zynq-*.dts), which are totally unrelated. This commit moves *.dts to arch/$(ARCH)/dts/ directories, allowing us to describe nicely mutiple DTBs generation in the next commit. Signed-off-by: Masahiro Yamada <yamada.m@jp.panasonic.com>
2013-11-17Makefile: make directories by Makefile.buildMasahiro Yamada
2013-10-20usb: rename board_usb_init_type to usb_init_typeTroy Kisky
This will be used by usb_lowlevel_init so it will no longer be used by only board specific functions. Move definition of enum usb_init_type higher in file so that it will be available for usb_low_level_init. Signed-off-by: Troy Kisky <troy.kisky@boundarydevices.com>
2013-10-20usb: new board-specific USB init interfaceMateusz Zalega
This commit unifies board-specific USB initialization implementations under one symbol (usb_board_init), declaration of which is available in usb.h. New API allows selective initialization of USB controllers whenever needed. Signed-off-by: Mateusz Zalega <m.zalega@samsung.com> Signed-off-by: Kyungmin Park <kyungmin.park@samsung.com> Reviewed-by: Lukasz Majewski <l.majewski@samsung.com> Cc: Marek Vasut <marex@denx.de> Cc: Lukasz Majewski <l.majewski@samsung.com>
2013-03-14Tegra: MMC: Add DT support to MMC driver for all T20 boardsTom Warren
tegra_mmc_init() now parses the DT info for bus width, WP/CD GPIOs, etc. Tested on Seaboard, fully functional. Tamonten boards (medcom-wide, plutux, and tec) use a different/new dtsi file w/common settings. Signed-off-by: Tom Warren <twarren@nvidia.com> Signed-off-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Add/enhance sdhci (mmc) nodes for all T20 DT filesTom Warren
Linux dts files were used for those boards that didn't already have sdhci info populated. Tamonten has their own dtsi file with common sdhci nodes (sourced from Linux). Signed-off-by: Tom Warren <twarren@nvidia.com> Tested-by: Thierry Reding <thierry.reding@avionic-design.de> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2013-03-14Tegra: fdt: Change /include/ to #include for C preprocessorTom Warren
dts Makefile has the arch & board include paths added to DTS_CPPFLAGS. This allows the use of '#include "xyz"' in the dts/dtsi file which helps the C preprocessor find common dtsi include files. Signed-off-by: Tom Warren <twarren@nvidia.com> Reviewed-by: Stephen Warren <swarren@nvidia.com>
2012-10-29tegra: add Colibri T20 board supportLucas Stach
This adds board support for the Toradex Colibri T20 module. Working functions: - SD card boot - USB boot - Network - NAND environment Signed-off-by: Lucas Stach <dev@lynxeye.de> Signed-off-by: Tom Warren <twarren@nvidia.com>
2012-10-15serial: pxa: Make use of default_serial_console in serial_pxaMarek Vasut
Make use of the newly implemented weak default_serial_console in the serial_pxa driver. This removes all reimplementations of this function from board files. Signed-off-by: Marek Vasut <marex@denx.de> Cc: Marek Vasut <marek.vasut@gmail.com> Cc: Tom Rini <trini@ti.com>
2011-12-06PXA: Move colibri_pxa270 to board/toradex/Marek Vasut
