Fix issue as reported by checkpatch.pl. Leave long lines as line
continuation in text output is not recommended.
Reviewed-by: Igor Opaniuk <igor.opaniuk@toradex.com>
Reviewed-by: Oleksandr Suvorov <oleksandr.suvorov@toradex.com>
The Apalis iMX8 was missing the interactive part should a customer have
bricked his module and want to re-create the configuration block. Fix
this.
The Colibri iMX8X target got re-named late in the cycle which we forgot
to reflect here. Furthermore, it was missing the interactive part should
a customer have bricked his module and want to re-create the
configuration block. Fix this.
Make the interactive Wi-Fi/BT handling generic by pulling it out of the
Colibri iMX6ULL interactive part to be re-used for Apalis iMX8 and
Colibri iMX8X.
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
Add all the latest new SKUs:
- Apalis iMX8 QuadXPlus 2GB Wi-Fi / BT IT
- Apalis iMX8 QuadMax 4GB IT
- Apalis iMX8 QuadPlus 2GB Wi-Fi / BT
- Apalis iMX8 QuadPlus 2GB",
- Colibri iMX8 QuadXPlus 2GB IT
- Colibri iMX8 DualX 1GB Wi-Fi / Bluetooth
Clean-up handling of several SKUs.
Use CONFIG_TARGET_... at compile time to differentiate between
Apalis iMX6, Colibri iMX6 and Colibri iMX6ULL. Avoid code
duplication by moving question about Wi-Fi / Bluetooth before
IT/non-IT decision.
Add support for new Colibri iMX6ULL SKUs.
While at it also checkpatch fix the whole files.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Fix toradex_modules array off by one issue potentially leading to
spurious printout during boot e.g.
Model: Toradex V1.2A,
instead of
Model: Toradex UNKNOWN MODULE V1.2A.
If the config block is missing, various things may fail or behave
strangely on certain modules. This patch unifies that behaviour by
using a fake MAC address, until user updates the config block.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add an optional -y parameter to 'cfgblock create’ to simplify
automation.
If the NAND chip is missing get_nand_dev_by_index() returns NULL. Fail
gracefully in this case.
When U-Boot started using SPDX tags we were among the early adopters and
there weren't a lot of other examples to borrow from. So we picked the
area of the file that usually had a full license text and replaced it
with an appropriate SPDX-License-Identifier: entry. Since then, the
Linux Kernel has adopted SPDX tags and they place it as the very first
line in a file (except where shebangs are used, then it's second line)
and with slightly different comment styles than us.
In part due to community overlap, in part due to better tag visibility
and in part for other minor reasons, switch over to that style.
This commit changes all instances where we have a single declared
license in the tag as both the before and after are identical in tag
contents. There's also a few places where I found we did not have a tag
and have introduced one.
In order that we can use eth_env_* even when CONFIG_NET isn't set, move
these functions to environment code from net code.
This fixes failures such as:
board/ti/am335x/built-in.o: In function `board_late_init':
board/ti/am335x/board.c:752: undefined reference to `eth_env_set_enetaddr'
u-boot/board/ti/am335x/board.c:766: undefined reference to `eth_env_set_enetaddr'
which caters for use cases such as:
commit f411b5cca48f ("board: am335x: Always set eth/eth1addr environment
variable")
when Ethernet is required in Linux, but not U-Boot.
Signed-off-by: Alex Kiernan <alex.kiernan@gmail.com>
Thomas reported U-Boot failed to build host tools if libfdt-devel
package is installed because tools include libfdt headers from
/usr/include/ instead of using internal ones.
This commit moves the header code:
include/libfdt.h -> include/linux/libfdt.h
include/libfdt_env.h -> include/linux/libfdt_env.h
and replaces include directives:
#include <libfdt.h> -> #include <linux/libfdt.h>
#include <libfdt_env.h> -> #include <linux/libfdt_env.h>
Reported-by: Thomas Petazzoni <thomas.petazzoni@bootlin.com>
All these places seem to inherit the codes from the MMC driver where
a FIXME was put in the comment. However the correct operation after
read should be cache invalidate, not flush.
The underlying drivers should be responsible for the cache operation.
Remove these codes completely.
Reviewed-by: York Sun <york.sun@nxp.com>
Reviewed-by: Joe Hershberger <joe.hershberger@ni.com>
Tested-by: York Sun <york.sun@nxp.com>
Rename this function for consistency with env_get().
We are now using an env_ prefix for environment functions. Rename these
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Suggested-by: Wolfgang Denk <wd@denx.de>
Rename this function for consistency with env_set().
We are now using an env_ prefix for environment functions. Rename setenv()
As part of preparation for nand DM conversion the new API has been
introduced to remove direct access to nand_info array. So, use it here
instead of accessing to nand_info array directly.
Reviewed-by: Marcel Ziswiler <marcel.ziswiler@toradex.com>
Signed-off-by: Grygorii Strashko <grygorii.strashko@ti.com>
Include this header where needed so we do not need to rely on common.h.
Rather than relying on common.h to provide this include, which is going
away at some point, include it explicitly in each file.
Enable CONFIG_DM_MMC_OPS and CONFIG_BLK for all Tegra devices. This moves
Tegra to use driver model fully for MMC.
The config block support currently uses the ft_board_setup function
to patch the device tree with config block information. However, this
does not allow to patch the device tree with board specific information.
Rename the common setup function to ft_common_board_setup and use the
call it from the board files directly.
Use the proper config option to guard the USB Download Function
fixup callback.
Add Toradex factory configuration block handling. The config block is a
data structure which gets stored to flash during production testing. The
structure holds such information as board resp. hardware revision,
product ID and serial number which is used as the NIC part of the
Ethernet MAC address as well. The config block will be read upon boot by
the show_board_info() function, displayed as part of the board
information and passed to Linux via device tree or ATAGs.
