U-boot might display wrong module revision information
for modules with an assembly version 'K'. "cfgblock create"
does not takes into account all revision digits from PID8.
This fix takes into account 6th,7th digits of PID8
to store module revision.
Related-to: ELB-3893
Signed-off-by: Denys Drozdov <denys.drozdov@toradex.com>
Allow setting Toradex Easy Installer aka Tezi specific configuration
options like not enabling SATA, directly continuing with the SDP command
upon recovery, distrobooting otherwise or not storing the environment.
Use CONFIG_TARGET_... at compile time to differentiate between
Apalis iMX6, Colibri iMX6 and Colibri iMX6ULL. Avoid code
duplication by moving question about Wi-Fi / Bluetooth before
IT/non-IT decision.
Signed-off-by: Gerard Salvatella <gerard.salvatella@toradex.com>
Fix toradex_modules array off by one issue potentially leading to
spurious printout during boot e.g.
Model: Toradex V1.2A,
instead of
Model: Toradex UNKNOWN MODULE V1.2A.
This adds support for Colibri iMX7 Dual 1GB modules which come
with on-board eMMC storage (whereas the other Colibri iMX7
modules use raw NAND). A subselection (variant) for the
Colibri iMX7 target is used to maximize sharing.
If the config block is missing, various things may fail or behave
strangely on certain modules. This patch unifies that behaviour by
using a fake MAC address, until user updates the config block.
Signed-off-by: Bhuvanchandra DV <bhuvanchandra.dv@toradex.com>
Add an optional -y parameter to 'cfgblock create’ to simplify
automation.
If config block support is enabled, USB gadget modes unconditionally
use Toradex Product ID as USB PID. Some applications might prefer a
different and/or static USB PID. Add a Kconfig configuration option
to descide whether to use USB PID from config block or the fallback
config option CONFIG_G_DNL_PRODUCT_NUM.
Acked-by: Brandon Shibley <brandon.shibley@toradex.com>
This adds a Kconfig SPL_SILENCE_CONSOLE which allows to suppress any
console output which in the normal program flow is printed in the SPL.
Error messages and the likes will still be printed.
This adds a command which parses the SPL version from eMMC and
optionally compares it against a version string.
Usage:
Colibri iMX6 # splver
U-Boot SPL 2016.11-rc3-00017-gdf36bb9-dirty (Nov 01 2016 - 12:31:34)
Colibri iMX6 # splver "U-Boot SPL 2016" || echo update
Colibri iMX6 # splver "U-Boot SPL 2017" || echo update
update
Colibri iMX6 # splver "U-Boot SPL 2016.11-rc4" || echo update
update
Colibri iMX6 #
Use the proper config option to guard the USB Download Function
fixup callback.
(cherry picked from commit beaf40688ba7303e9db50558b3852c79437eecad)
If the module is in serial downloader mode, we do no longer read the
environment from eMMC. Therefor, the eMMC is unitialized when trying
to read the config block. Use mmc_init to initialize the selected
MMC device before using it.
Note: In case the MMC has already been initialized, the mmc_init
detects that and returns immediately.
board/toradex/common/configblock.c
The config block support currently uses the ft_board_setup function
to patch the device tree with config block information. However, this
does not allow to patch the device tree with board specific information.
Rename the common setup function to ft_common_board_setup and use the
call it from the board files directly.
(cherry picked from commit 37fa41256bd756f3652e7479b976982092a4f9bc)
Add Toradex factory configuration block handling. The config block is a
data structure which gets stored to flash during production testing. The
structure holds such information as board resp. hardware revision,
product ID and serial number which is used as the NIC part of the
Ethernet MAC address as well. The config block will be read upon boot by
the show_board_info() function, displayed as part of the board
information and passed to Linux via device tree or ATAGs.
(cherry picked from commit a2777ecb9d11882dba696035defa35c70dd26733)
