Fix possible overflow condition in serial number to hexadecimal coded
decimal conversion routine.
Add initial Apalis T30 support based off our current Colibri T30
implementation:
- Updated machine ID.
- USB host USBH2 and USBH3 support. Note: USBO1 support is currently broken.
- Updated MMC and SD card support.
- Adjusted available amount of memory.
Rather than relying on hard-coded offsets actually make use of
partition table parsing implementation.
This is a purely cosmetic clean-up of the common Toradex board file.
- board.c: changes required by different PMIC variant
Fix build issues introduced with NVIDIA partition table parsing
integration.
