2013-10-03 | colibri_vf50: migrate nand vs. sdboot configuration | Marcel Ziswiler | |
Migrate to default NAND boot configuration (e.g. colibri_vf50_config) and SD card boot on request (e.g. colibri_vf50_sdboot_config). Automatically do the padding required for NAND boot image (e.g. u-boot.nand). This is also more in-line with how we did stuff back on the Colibri T20. | |||
2013-09-09 | colibri_vf50: initial integration | Marcel Ziswiler | |
Add initial Colibri VF50 support based off Timesys' implementation for Freescale's Vybrid Tower System TWR-VF65GS10: - New machine ID. - Default UART_A on SCI0. - ESDHC2 only. - 8-bit NAND. - No quad SPI. - FEC1 only. - Enabled command line editing. - PLL5 based RMII clocking (e.g. no external crystal). - UART_A, UART_B and UART_C I/O muxing. Tested on early Colibri VF50 prototypes V1.0a using SD card (mandatory for initial loading) as well as NAND boot. |
