path: root/board/toradex/colibri_imx7/Kconfig
2016-11-28apalis/colibri_imx7/pxa270/t20/t30/vf: integrate config block handlingMarcel Ziswiler
With our common code in place actually make use of it across all our modules. Signed-off-by: Marcel Ziswiler <marcel.ziswiler@toradex.com> Acked-by: Max Krummenacher <max.krummenacher@toradex.com>
2016-07-28colibri_imx7: add Colibri iMX7S/iMX7D module supportStefan Agner
This commit adds support for the Toradex Computer on Modules Colibri iMX7S/iMX7D. The two modules/SoC's are very similar hence can be easily supported by one board. The board code detects RAM size at runtime which is one of the differences between the two boards. The board also uses the UART's in DTE mode, hence making use of the new DTE support via serial DM. Signed-off-by: Stefan Agner <stefan.agner@toradex.com>
