2014-10-30 | colibri_imx6.c: enable USB host power consistently | Max Krummenacher | |
2014-10-29 | apalis_imx6.c/colibri_imx6.c: use get_ram_size() | Max Krummenacher | |
This gives a fast basic ram test. While at it clean up whitespace | |||
2014-10-28 | do_fuse: enable the fusing | Max Krummenacher | |
2014-09-18 | colibri-imx6: pf0100.c: fix pin assignment for VPGM en | Max Krummenacher | |
2014-09-04 | colibri_imx6.c: add patch_ddr_size cmd | Max Krummenacher | |
Adds the patch_ddr_size cmd which patches the DCD data structure settings for the DDR memory controller optimized for the module. Currently this is only the bus width which is changed from 32bit to 64bit on DL modules. This allows to use a unified U-Boot for S and DL modules. Right after flashing the U-Boot to eMMC this cmd will be run to complete the update. | |||
2014-09-04 | colibri_imx6.c: get the RAM size from the MMDC's config | Max Krummenacher | |
2014-09-04 | colibri-imx6.cfg: fix config variable name | Max Krummenacher | |
2014-09-01 | colibri-imx6: initial support for dual-light | Max Krummenacher | |
