The code for programming the OTP fuses on the PMIC PF0100 can only be
used in full U-Boot, so do not build / link it into SPL.
Cc: Max Krummenacher <max.krummenacher@toradex.com>
Cc: Fabio Estevam <fabio.estevam@nxp.com>
Reviewed-by: Fabio Estevam <fabio.estevam@nxp.com>
Tested-by: Max Krummenacher <max.krummenacher@toradex.com>
When building with W=1 errors like the one below is seen:
board/freescale/mx6sabresd/mx6sabresd.c:546:5: warning:
no previous prototype for ‘overwrite_console’
[-Wmissing-prototypes] int overwrite_console(void)
Fix the build warnings by including <input.h>.
Signed-off-by: Diego Dorta <diego.dorta@nxp.com>
There is no need call setup_display() from SPL code, so move it to
board_init(), which executes only in U-Boot proper.
Reported-by: Stefano Babic <sbabic@denx.de>
Signed-off-by: Fabio Estevam <fabio.estevam@nxp.com>
Instead of having every board file to add its own g_dnl_bind_fixup()
implementation, move it to the common imx6 SPL code.
Reviewed-by: Łukasz Majewski <lukma@denx.de>
Since the gpr_init() function is common for boards using MX6S, MX6DL, MX6D,
MX6Q and MX6QP processors move it to the soc.c file.
Signed-off-by: Breno Lima <breno.lima@nxp.com>
Reviewed-by: Lukasz Majewski <lukma@denx.de>
Use a completely independent USB Product ID for SPL. This allows
to differentiate a SDP running in SPL and SDP running in a U-Boot
which could not read the config block successfully.
We are now using an env_ prefix for environment functions. Rename these
two functions for consistency. Also add function comments in common.h.
Quite a few places use getenv() in a condition context, provoking a
warning from checkpatch. These are fixed up in this patch also.
Suggested-by: Wolfgang Denk <wd@denx.de>
We are now using an env_ prefix for environment functions. Rename setenv()
Use the env_save() function directly now that there is only one
implementation of saveenv().
Reviewed-by: Wolfgang Denk <wd@denx.de>
Change is consistent with other SOCs and it is in preparation
for adding SOMs. SOC's related files are moved from cpu/ to
mach-imx/<SOC>.
This change is also coherent with the structure in kernel.
CC: Fabio Estevam <fabio.estevam@nxp.com>
CC: Akshay Bhat <akshaybhat@timesys.com>
CC: Ken Lin <Ken.Lin@advantech.com.tw>
CC: Marek Vasut <marek.vasut@gmail.com>
CC: Heiko Schocher <hs@denx.de>
CC: "Sébastien Szymanski" <sebastien.szymanski@armadeus.com>
CC: Christian Gmeiner <christian.gmeiner@gmail.com>
CC: Stefan Roese <sr@denx.de>
CC: Patrick Bruenn <p.bruenn@beckhoff.com>
CC: Troy Kisky <troy.kisky@boundarydevices.com>
CC: Nikita Kiryanov <nikita@compulab.co.il>
CC: Otavio Salvador <otavio@ossystems.com.br>
CC: "Eric Bénard" <eric@eukrea.com>
CC: Jagan Teki <jagan@amarulasolutions.com>
CC: Ye Li <ye.li@nxp.com>
CC: Peng Fan <peng.fan@nxp.com>
CC: Adrian Alonso <adrian.alonso@nxp.com>
CC: Alison Wang <b18965@freescale.com>
CC: Tim Harvey <tharvey@gateworks.com>
CC: Martin Donnelly <martin.donnelly@ge.com>
CC: Marcin Niestroj <m.niestroj@grinn-global.com>
CC: Lukasz Majewski <lukma@denx.de>
CC: Adam Ford <aford173@gmail.com>
CC: "Albert ARIBAUD (3ADEV)" <albert.aribaud@3adev.fr>
CC: Boris Brezillon <boris.brezillon@free-electrons.com>
CC: Soeren Moch <smoch@web.de>
CC: Richard Hu <richard.hu@technexion.com>
CC: Wig Cheng <wig.cheng@technexion.com>
CC: Vanessa Maegima <vanessa.maegima@nxp.com>
CC: Max Krummenacher <max.krummenacher@toradex.com>
CC: Stefan Agner <stefan.agner@toradex.com>
CC: Markus Niebel <Markus.Niebel@tq-group.com>
CC: Breno Lima <breno.lima@nxp.com>
CC: Francesco Montefoschi <francesco.montefoschi@udoo.org>
CC: Jaehoon Chung <jh80.chung@samsung.com>
CC: Scott Wood <oss@buserror.net>
CC: Joe Hershberger <joe.hershberger@ni.com>
CC: Anatolij Gustschin <agust@denx.de>
CC: Simon Glass <sjg@chromium.org>
CC: "Andrew F. Davis" <afd@ti.com>
CC: "Łukasz Majewski" <l.majewski@samsung.com>
CC: Patrice Chotard <patrice.chotard@st.com>
CC: Nobuhiro Iwamatsu <iwamatsu@nigauri.org>
CC: Hans de Goede <hdegoede@redhat.com>
CC: Masahiro Yamada <yamada.masahiro@socionext.com>
CC: Stephen Warren <swarren@nvidia.com>
CC: Andre Przywara <andre.przywara@arm.com>
CC: "Álvaro Fernández Rojas" <noltari@gmail.com>
CC: York Sun <york.sun@nxp.com>
CC: Xiaoliang Yang <xiaoliang.yang@nxp.com>
CC: Chen-Yu Tsai <wens@csie.org>
CC: George McCollister <george.mccollister@gmail.com>
CC: Sven Ebenfeld <sven.ebenfeld@gmail.com>
CC: Filip Brozovic <fbrozovic@gmail.com>
CC: Petr Kulhavy <brain@jikos.cz>
CC: Eric Nelson <eric@nelint.com>
CC: Bai Ping <ping.bai@nxp.com>
CC: Anson Huang <Anson.Huang@nxp.com>
CC: Sanchayan Maity <maitysanchayan@gmail.com>
CC: Lokesh Vutla <lokeshvutla@ti.com>
CC: Patrick Delaunay <patrick.delaunay@st.com>
CC: Gary Bisson <gary.bisson@boundarydevices.com>
CC: Alexander Graf <agraf@suse.de>
CC: u-boot@lists.denx.de
Reviewed-by: Christian Gmeiner <christian.gmeiner@gmail.com>
At present CONFIG_CMD_SATA enables the 'sata' command which also brings
in SATA support. Some boards may wish to enable SATA without the command.
Add a separate CONFIG to permit this.
This header includes things that are needed to make driver build. Adjust
existing users to include that always, even if other dm/ includes are
present
The variable vga_pads is never referenced, drop.
This adds board support for the Toradex module family Apalis iMX6.
The familiy consists of a module with i.MX6 Dual, i.MX6 Quad with
commercial and industrial temperature range.
